12-19-2021, 4:14pm | #1 | ||||||
Rough as HELL......
I readjusted the valves, pushed the down 1/4 turn and locked them tight.....as suggested by DJ Crit......and really no diff in the rough running.....I have no clue as to watt is the problem......getting into an issue of cam timing off a tooth or what???
'89 4 bolt main block, roller cam-L98, LT1 intake with HEI up top where is belongs.....I do have ceramic plug boots on there......and they are a bit loose feeling, but never an issue in the past.....tired of spending money, and getting tired of working on it..... Any suggestions??? |
12-19-2021, 4:24pm | #2 | ||||||
Only one thing guaranteed to make a person happy in that kind of situation... Get a new one. Smiles for miles
12-19-2021, 4:31pm | #3 | ||||||
12-19-2021, 7:27pm | #4 | ||||||
Just drop in a simple small block crate engine with a carb, mechanical fuel pump and HEI Distributor. It will be reliable enough for your purposes.
The Following 2 Users Say Thank You to StaticCling For This Useful Post: |
12-19-2021, 9:08pm | #5 | ||||||
Nuke it from orbit. Many of us here have tried to advise you. You are a stubborn man.
The Following 2 Users Say Thank You to markids77 For This Useful Post: |
12-19-2021, 9:56pm | #6 | ||||||
Gameroom Barn Bucks: $406058
The Following User Says Thank You to Stevedore For This Useful Post: |
12-19-2021, 10:12pm | #7 | ||||||
Gameroom Barn Bucks: $1064
I thought this was another Knooger colonoscopy thread
12-20-2021, 3:34am | #8 | ||||||
Barn Stall Owner #49
Gameroom Barn Bucks: $1025197
Since you first started on this, it's been quite an adventure in disappointment.
At this stage, I'd do a compression check just to see what cylinders are affected. I would pop the water pump and pull the timing cover and check the cam/crank index marks. That would rule out valve timing. If that's good, your distributor may be a tooth or two off. verify with timing mark. I feel your pain, Gene. |
12-20-2021, 6:16am | #9 | ||||||
Call DJ's fam.
Ask them what could you have messed up after the work. I have had good help from family shops that have worked on my stuff. |
12-20-2021, 7:23am | #10 | ||||||
Gameroom Barn Bucks: $2001216
Spark
Compression Fuel Air You said its running but rough, so you do have "spark" Compression and air.... Get back to the injectors/rail O rings and regulator. To repeat others, again while its running pull off one plug wire at a time, if no change that cylinder is not operating/firing/ or getting fuel..... |
12-20-2021, 8:27am | #11 | ||||||
SOME Real Barner
Gameroom Barn Bucks: $2034428
12-20-2021, 9:05am | #12 |
My suggestion is he removes the hood, pull the air filter cover off, hold it just above the engine bay, then roll the vette out from under it. Roll a newer running vette in place and secure the air filter cover. Problem solved.
The Following 5 Users Say Thank You to DJ_Critterus For This Useful Post: |
12-20-2021, 11:20am | #13 | ||||||
Moderator
Gameroom Barn Bucks: $988270
The Following User Says Thank You to 73sbVert For This Useful Post: |
01-16-2022, 3:38pm | #14 | ||||||
Any test gear out there to say which cyl is running rough/not firing right??
like a timing light on #1 and so to take the count off the tach pulse, and ID the bad cyl?? |
01-16-2022, 3:40pm | #15 | ||||||
01-16-2022, 3:43pm | #16 | ||||||
01-18-2022, 11:42am | #17 | |||||||
Gameroom Barn Bucks: $856744
Firing order in sync with he cam?
I put a 351 Windsor cam in my 302 and had to change the firing order. Quote:
01-18-2022, 11:49am | #18 |
He's got a mild mid range cam for a 350 sb. I'm sure it didn't jump time or that the cam was installed wrong because he's not hearing any metal on metal stuff banging into itself when the engine tries to run.
Gene, you got fuel. check the spark first. You could have a bad distributor. |
01-18-2022, 12:28pm | #19 | |||||||
01-18-2022, 12:32pm | #20 | ||||||
Moderator
Kinda sounds like a vacuum leak somewhere to me...
