02-10-2017, 12:15pm | #1 | ||||||
Who has stacked full size washer/dryer ?
I saw that you can stack these and if and when we need new I was thinking of doing that.....
02-10-2017, 12:26pm | #2 | ||||||
stacked LG. pretty small utility room, frees up space for storage and folding table.
02-10-2017, 1:04pm | #3 | ||||||
Barn Stall Owner #3
Gameroom Barn Bucks: $2324642
02-10-2017, 1:05pm | #4 | ||||||
wonder why she hates them,they are easier on clothes and gets them cleaner too
02-10-2017, 1:06pm | #5 | ||||||
Barn Stall Owner #3
The Following User Says Thank You to C5SilverBullet For This Useful Post: |
02-10-2017, 1:18pm | #6 | ||||||
Gameroom Barn Bucks: $406058
Hadn't thought much about stacking, but I think the pedestal mounts under the machines might make it a little easier to load & unload. So we're thinking about that ourselves with an upcoming purchase.
02-10-2017, 1:47pm | #7 | ||||||
Barn Stall Owner #82 BR Car Washer II,III NCM Supporter '11,'12,'13 Bantayan Kids '14
Gameroom Barn Bucks: $5504001
I had no choice but to get a stacked set up.....
I've had no issues, washer on bottom and dryer on top. My washer does make more of a rocus with a dryer on top, but could be the echo of such a small area and weight on top. The only PIA is the fact that if you keep your washer closed after a cycle, they get mildew and moldy on the inside. Essentially can't close the front door for a day after a load. Needs a good air dry. These are much more efficient in all aspects than the standard top loaders I've had in the past. |
02-10-2017, 3:50pm | #8 | ||||||
2016 Election Expert
Barn Stall Owner #64
The other day (I posted a thread about it IIRC) my front loading washing machine was throwing an error code and wouldn't start. After a bit of googling it looked like the fault was with the main computer board and that it was possible that it would be just a bad solder joint on the main power relay. Sure enough that was all it was, an easy fix. But it would have been a total PITA if I had the take the dryer off it before I could remove the top of the washer. Would have turned a 15 minute job into a two person 90+ minutes job.
02-10-2017, 4:19pm | #9 | ||||||
02-14-2017, 8:02pm | #10 | ||||||
Banned
Gameroom Barn Bucks: $1502
02-16-2017, 8:52am | #11 | |||||||
Barn Stall Owner #6
Gameroom Barn Bucks: $437465
I'd much prefer to have unstacked and enough space, but with the small space the stacking is nice. I can say it sucks for the repair guy when the washer (on the bottom) splits a hose...twice... He has to bring along a big helper. |
02-16-2017, 9:10am | #12 | ||||||
Probably easier to put an access panel in wall behind it if you can to change hoses.
Wall behind ours is a closet so that's what I will do |
