Old 05-26-2016, 8:39pm   #1
PortDawg
Charter Member - C3 Mod
Barn Stall Owner #34
NCM Supporter '15
Points: 30,980, Level: 100
PortDawg's Avatar
Gameroom Barn Bucks: $173
Default I think I have a temperature problem again,,,
In traffic, my temp goes up to above 230. You guys think that cleaning the fins would make a huge difference?
It blew a hose the other day when it seriously overtemped. It has a new Thermostat, new Antifreeze new hoses and the Dewitt Double radiator.
Distant memories of a spirited drive in Bowling Green come to mind trying to keep it cool. It seems to do okay when moving...
The Following User Says Thank You to PortDawg For This Useful Post:
Old 05-27-2016, 7:22am   #2
Norm
Barn Stall Owner #1776
Bantayan Kids '13,'17
Points: 88,143, Level: 100
Activity: 29.2%
Norm's Avatar
No fan? Operating?
JCS USA USN USMC USCG USAF USSF USAR USNR USMCR USCGR USAFR ARNG ANG USPHS NOAA USMM AUS CSA Police/Fire/EMS/EMT
Thank You For Your Service
Old 05-27-2016, 7:32pm   #3
RonC5
Barn Stall Owner #1969
NCM Supporter '12,'13,'14,'15,'17,'21
Points: 21,234, Level: 100
RonC5's Avatar
Gameroom Barn Bucks: $132003
Can't hurt. These things suck all kinds of crap up in there. Use air and pressured water.
RonC5 is offline   Reply With Quote
Old 05-28-2016, 7:18am   #4
Since it only does it when the is a low amount of air moving through the radiator, I would think blockage, or lack of fan function.
Check between the radiator and AC condenser, to see if there is a bunch of junk in there. Remove the air bridge, take off the top of the fan shroud, and shoot air between there, then run water all in there to remove anything that might be blocking the fins.
If that doesnt do the trick, then Turn the AC on max and see if both Fans kick on. Both fans should automatically kick on whenever the AC is turned on. If both fans arent running, then there is a a good place to start. Could be a bad relay.
Also check the relay connections for anything loose or broken.
Old 05-28-2016, 4:03pm   #5
PortDawg
NCM Supporter '15
PortDawg's Avatar
Thanks everyone. Just didn't want to miss anything obvious
Old 05-29-2016, 7:05am   #6
I spent all afternoon cleaning out the radiator/condenser area on mine yesterday. Got a shit ton of grass and crap blown outa there. Its been a couple years since I cleaned it and its amazing how much crap these things suck up between the radiator and condenser.
Old 05-31-2016, 7:03am   #7
RonC5
RonC5's Avatar
I have heard that these work well, I just have never ordered one.
Radiator Genie Cleans out Clogged Radiators
Old 06-01-2016, 7:39am   #8
That looks like a nice piece to have.
Old 06-06-2016, 8:46pm   #9
PortDawg
NCM Supporter '15
PortDawg's Avatar
Might be ordering one..
Old 06-07-2016, 6:40pm   #10
I expect a full product review complete with pics and bikini clad model holding your wand. Not THAT wand ya perv!
Old 06-22-2016, 9:27pm   #11
garebear
Points: 44, Level: 1
Activity: 0.8%
garebear's Avatar
Gameroom Barn Bucks: $505
Installed this wireless gadget in 15 minutes and it drops the temps from 226 to 195 at a standstill on the freeway without energizing the AC. On sale now @ $99.00, I paid $119.00. Well worth it.
products
garebear is offline   Reply With Quote
The Following 2 Users Say Thank You to garebear For This Useful Post:
Old 06-23-2016, 9:28am   #12
Crowvet
Points: 8,497, Level: 64
Crowvet's Avatar
Gameroom Barn Bucks: $2194
The cooling fan does not come on until around 232 to 235% F. Make sure the fan is running when it is hot (above 232) if so clean out the fins. If problem still exists replace that radiator.
Crowvet is offline   Reply With Quote
Old 09-08-2017, 2:30pm   #13
Jimmy b
Points: 16, Level: 1
Activity: 1.5%
Jimmy b's Avatar
Gameroom Barn Bucks: $515
I had to take every thing apart and clean radiator with foam cleaner an that did the trick for me.
Jimmy b is offline   Reply With Quote
