Old 01-19-2011, 8:49pm   #1
PortDawg
Charter Member - C3 Mod
Barn Stall Owner #34
NCM Supporter '15
Points: 30,980, Level: 100
PortDawg's Avatar
Gameroom Barn Bucks: $173
Default Emergency Brake
Any suggestions on getting the e-brake pads out?
Old 01-20-2011, 8:37pm   #2
JRD77VET
NCM Supporter '16,'17,'19,'20
Points: 116,308, Level: 100
Activity: 8.3%
JRD77VET's Avatar
Have you succeded in getting the rear rotors off?
Jeff
Old 01-20-2011, 9:35pm   #3
Dave
Barn Raising I,II,III
Points: 9,466, Level: 67
Activity: 10.7%
Dave's Avatar
Gameroom Barn Bucks: $509371
Should not be too difficult provided you can get the rear rotors off. Have you got a service manual of any kind?
Dave is offline   Reply With Quote
Old 01-20-2011, 9:42pm   #4
PortDawg
NCM Supporter '15
PortDawg's Avatar
Jeff
Yeah, that was easy.... It's the crap behind the hub that worries me...
Old 01-20-2011, 9:43pm   #5
PortDawg
NCM Supporter '15
PortDawg's Avatar
Assembly Manual and Chiltons...
I think I'm over thinking this project...
Old 01-20-2011, 10:14pm   #6
Dave
Activity: 10.7%
Dave's Avatar
or you just need a bigger hammer.
What kind of shape is the brake hardware in? Lots of rust?
Old 01-21-2011, 3:17am   #7
Kevin_73
Points: 19,395, Level: 96
Kevin_73's Avatar
Gameroom Barn Bucks: $313284
I just did this on Liz's 68.
You have to pull the brake shoes apart enough to get needle nose pliers in there and grab the end of the springs that go between the top and bottom of the two shoes. Then disconnect the springs from the brake shoes and remove the star wheel adjuster from the bottom. Note the direction that they were installed on each side.
Next you need to use a screwdriver compress the cup on the spring that holds each shoe to the dust cover. Once you have that compressed you need to grab the pin with your needle nose pliers and turn it 1/4 turn to release it. Then remove the shoes.
There are some decent tutorials available online.
Here is one that I used:
Corvette Parking Brake Rebuild | CorvetteMagazine.com
Good luck
Kevin_73 is offline   Reply With Quote
Old 02-21-2011, 7:23am   #8
PortDawg
NCM Supporter '15
PortDawg's Avatar
Okay, got it all apart. Now how the f(*^ do you put the springs and locks back in. Spent 2 hours trying.
Any suggestions?
Old 02-22-2011, 5:34pm   #9
Kevin_73
Kevin_73's Avatar
Any suggestions?
Two pairs of needle nose pliers and a lot of really bad language.
Old 02-22-2011, 9:53pm   #10
PortDawg
NCM Supporter '15
PortDawg's Avatar
BTDT....made me want to off myself.... I need to get longer pliers....
