Old 05-25-2012, 8:41pm   #1
JRD77VET
NCM Supporter '16,'17,'19,'20
Points: 116,308, Level: 100
Activity: 8.3%
JRD77VET's Avatar
Default cam? Crane-Lunati -Comp or ?????
Getting another engine for my '77 since the current one (nom) makes very bad noises.
I'm getting a 305 that runs good for free. The only known problem is the fuel pump lobe is "compromised",
I'm just going low budget, very mild cam and lifters wqith new timing chain/gears.
Headers,true duals, 3.08 gears on a 4 speed car. I willbe running the stock intake & carb.
Thanks
Jeff
Old 05-28-2012, 7:15pm   #2
Aflac
Barn Stall Owner #43
Barn Raising I
Points: 9,337, Level: 66
Activity: 1.5%
Aflac's Avatar
Gameroom Barn Bucks: $3903623
in my 77 (350), I have the 350/350 cam that came in the 70 LT-1s.. good power and torque and good vacuum to boot.
Aflac is offline   Reply With Quote
The Following User Says Thank You to Aflac For This Useful Post:
Old 05-28-2012, 7:51pm   #3
JRD77VET
Activity: 8.3%
JRD77VET's Avatar
GM cam or aftermarket? If aftermarket, what brand?
Old 05-28-2012, 8:19pm   #4
73sbVert
Moderator
Barn Stall Owner #20
Barn Stall Owner #33
Points: 30,625, Level: 100
Activity: 4.0%
73sbVert's Avatar
Gameroom Barn Bucks: $988270
Get the 268H (Comp Cams) or I think better, the Crane (http://www.summitracing.com/parts/CRN-113941/) and add L98 aluminum heads (#113's) with the 58cc chambers, and medium thickness (sorry, can't remember the crush depth right now) head gaskets.
I'd get the chambers polished too, new valves, guides, seats, etc. Roller rockers suggested.
You'll be able to make 300 hp fairly easily, and totally streetable.
The 305 is not really THAT bad of an engine, especially if that's all you have. Plus, when you step up into the 350 later, the heads will bolt right on too.
ETA: Found my bookmarked sites that might help ya!
Main page: http://www.hioutput.com/tech.html
290hp buildup: http://www.hioutput.com/tech/290hp/290hp.html
343hp buildup: http://www.hioutput.com/tech/343hp/343hp.html
400hp buildup: http://www.hioutput.com/tech/400hp/400hp.html
hth
73sbVert is offline   Reply With Quote
