Old 09-30-2011, 10:38pm   #1
69camfrk
Barn Stall Owner #6969
Points: 69,699, Level: 100
Activity: 4.0%
69camfrk's Avatar
Gameroom Barn Bucks: $1071547
Default Factory resistor ignition wire on '72
How much of a problem is this going to be now that I've switched to HEI? My'69 Camaro had a resistor block that I removed, so no problem. Should I just run another wire off the fuse block, take my chances, or what. Someone here has to have experienced this. Hook a brother up!! TIA!
69camfrk is online now   Reply With Quote
Old 10-08-2012, 3:02pm   #2
Fastguy
Barn Stall Owner #92
Bantayan Kids '13,'15
Points: 24,533, Level: 100
Activity: 0.8%
Fastguy's Avatar
Gameroom Barn Bucks: $7534993
When switching a points style car to HEI, I remove the resistor wire and run a new 12V from the same spot on the fuse block. If you run the resistor wire, the car will load up and run awful due to weak spark.
Fastguy is offline   Reply With Quote
Old 10-08-2012, 8:16pm   #3
jda67gta
Barn Stall Owner #37
Barn Raising I,II,III
NCM Supporter '11,'12,'13,'15,'17
Points: 13,214, Level: 79
jda67gta's Avatar
Gameroom Barn Bucks: $514865
jda67gta is offline   Reply With Quote
