Old 06-13-2022, 10:03pm   #1
jbost6
Points: 41, Level: 1
Activity: 2.6%
jbost6's Avatar
Default Hello I am new to this discussion and a new corvette owner of a 2003 50th anniversary
My bright light switch does not work when pushing it forward. It does work when pulling it towards me for the temporary brightness though. Any suggestions on a fix?
jbost6 is offline   Reply With Quote
Old 06-14-2022, 6:40am   #2
snide
NCM Supporter '13
Points: 216,817, Level: 100
Activity: 53.6%
Welcome to the Vette Barn.
You probably won't get too many responses, as we mostly bullshit in the Off Topic section.
But if the high beams work with the flash to pass feature, there is likely some crud in the steering column, around the turn signal stalk. Try blowing it out with a can of compressed air. If that doesn't work, you'll need to disassemble the housing to clean it.
Oh, and pics of C5? Or wife? Or girlfriend? Or both?
The Following 2 Users Say Thank You to snide For This Useful Post:
Old 06-21-2022, 9:13pm   #3
jbost6
Activity: 2.6%
jbost6's Avatar
Thanks for your help. I’ll try it.
The Following User Says Thank You to jbost6 For This Useful Post:
Old 06-22-2022, 11:37am   #4
snide
NCM Supporter '13
Activity: 53.6%
Beauty.
Old 06-22-2022, 5:33pm   #5
Rikki Z-06
Barn Stall Owner #747-400
Points: 78,338, Level: 100
Activity: 16.2%
Rikki Z-06's Avatar
Originally Posted by snide View Post
Beauty.
Rikki Z-06 is offline   Reply With Quote
The Following User Says Thank You to Rikki Z-06 For This Useful Post:
Old 06-22-2022, 6:04pm   #6
Aerovette
Barn Stall Owner #7734
Points: 106,544, Level: 100
Aerovette's Avatar
If you have ever disassembled a stalk, you'd find the wires are VERY small and most likely one of them broke. It could be mechanical as well. You really won't know until you take it apart OR if you know someone with a C5, switch theirs and see if it feels different. If it fells the same, I'd look for a wire issue. If it clicks differently, look for a mechanical issue with the stalk or switch.
Aerovette is online now   Reply With Quote
The Following User Says Thank You to Aerovette For This Useful Post:
Old 06-22-2022, 6:13pm   #7
MadInNc
Points: 195,313, Level: 100
Activity: 23.7%
MadInNc's Avatar
First question is if ya push forward does it click and lock? If open column, replace with new switch and try before final install
If still doesn’t work - wiring, but that could also if switch latches and no brights
Wiring or fuse?
MadInNc is online now   Reply With Quote
The Following User Says Thank You to MadInNc For This Useful Post:
Old 06-23-2022, 8:51am   #8
jbost6
Activity: 2.6%
jbost6's Avatar
Thanks for your help. I’ll try it. The switch definitely pushes forward and locks in place. I guess I’ll try the easy things first.
Old 12-25-2022, 11:46am   #9
Goodtogo32
Points: 2,321, Level: 31
Goodtogo32's Avatar
That's a nice C5, I've always liked that color
Goodtogo32 is offline   Reply With Quote
