Old 03-28-2011, 7:19pm   #1
skyzzics
Points: 1,488, Level: 22
skyzzics's Avatar
Gameroom Barn Bucks: $627
Default torx bit size?
Can anyone tell me the size torx bit to remove the fuel pressure regulator on an 1989 coupe? I have a few assorted bits but none seem to fit.
skyzzics is offline   Reply With Quote
Old 03-28-2011, 8:50pm   #2
skyzzics
skyzzics's Avatar
Default took some pix
Looking at it a little closer like with a magnifying glass It looks like there's a little nub in the middle. What the heck is that?
Old 03-28-2011, 9:40pm   #3
C4fan
Points: 11,943, Level: 75
C4fan's Avatar
Gameroom Barn Bucks: $882805
Do a google search on "tamper proof torx bit" I'm guessing GM doesn't want you to mess with it.
Old 03-28-2011, 10:31pm   #4
skyzzics
skyzzics's Avatar
Default Tamper Proof?
Oh, man! do you mean I'm going to have to buy a set of tamper proof torx bits for this job? Or do you think I can buy just the one size at my local NAPA?
What have you guys done?
Old 03-28-2011, 10:51pm   #5
C4fan
C4fan's Avatar
I just bought an E4 torx socket to work on my opti. You can usually buy single bits or sockets. Look around though, I came across prices as high as $20 but bought it for $7 after shipping. Once you figure out what size you need just type it in on your search bar.
Old 03-28-2011, 11:41pm   #6
skyzzics
skyzzics's Avatar
Default Thank you General Motors
It's about impossible to know what size I need if I can't even get one in there. I need to know what the size is beforehand so I can buy one at the local auto store. At least I now know it's a tamper proof bit. Thanks GM. Maybe I should just leave it alone. Changing the part will probably not make any difference in performance anyway. And by performance I mean normal running. It's embarrassing to be so slow.
Old 03-29-2011, 2:16am   #7
skyzzics
skyzzics's Avatar
Default Found the answer, sort of.
Ok, a little research on another site reveals that it is possible to knock out those "security" nubs. Or one can buy a security torx bit. The right size torx bit is t10. If anyone looks at this thread in the years to come they will have an answer.
As for me, I plan to leave it alone and look elsewhere for the answer to my problem. I'll come back to it if need be.
Old 03-20-2012, 1:28pm   #8
sundown
Points: 119, Level: 2
sundown's Avatar
Gameroom Barn Bucks: $25
You can buy a regulator for a little bit more than the wrenches will cost, then you know it is right. They don't call it tamper proof for no reason.
sundown is offline   Reply With Quote
Old 03-20-2012, 4:41pm   #9
skyzzics
skyzzics's Avatar
Default old thread
Sundown, although this thread is over a year old I will respond. Even when I bought a new FPR I still needed to take off the cover with the torx screw to get the new piece installed. This I did and the car is running very smoothly. The right torx bit cost me a buck at Autozone.
Old 12-11-2012, 1:58pm   #10
scorp508
Points: 8,643, Level: 64
scorp508's Avatar
Gameroom Barn Bucks: $1580
Another option I've seen people do is buy a cheap junky bit and dimple or drill a small hole in the middle to go over the tamper pin.
scorp508 is offline   Reply With Quote
