06-24-2015, 8:41pm | #1 | ||||||
Gameroom Barn Bucks: $3694
1993 LT1 gear selector switch circuit Code 72 cause surging?
I know its I have a code 72, and a fresh rebuild on transmission.. Transmission runs great and pulls through 4th gear behind my 396LT1. States gear selector switch circuit. Neutral safety sswitch part of circuit?
But at part throttle/cruise I get a slight surge. Engine is new, sensors are all new within engine, tuned by good reputable company, never any problems. But now I have this code, can it cause a surge with a 4L60? Last edited by Vette40th; 06-25-2015 at 7:13am. |
06-25-2015, 7:09am | #2 | ||||||
One other symptom is imtermittent start. If i jump it fires right up. Battery is new and always on tender.
06-25-2015, 8:08am | #3 | |||||||
Barn Stall Owner #49
Gameroom Barn Bucks: $1025197
problem or engine problem? My 'expertise stops at 1984. I'd go back to the shop that tuned it and see if they can check it over. As for the intermittent start, does it turn over or just sit there? Do you hear the starter solenoid engage? |
06-25-2015, 8:40am | #4 | |||||||
The car has no clicking sounds at all when it intermiittently doesnt start. Same if you dont put clutch in on stick or are in gear when you try to start. |
06-25-2015, 8:14pm | #5 | |||||||
With key ON, you should have a standing 12v on the feed side of your clutch start switch and no voltage on the out going term UNTIL the clutch pedal is fully depressed. Clutch pedal down and you should see 12v on both terms of clutch switch. From there, it's off to your starter solenoid. Hopefully you have a FSM for the car. The electrical schematics are VERY useful!!!! |
06-25-2015, 8:40pm | #6 | ||||||
I do have the FSM, and TTS datamaster to log, and CATS to burn my chips. I will datalog tomorrow. And I will troubleshoot via FSM..
Hopefully I can find a smoking gun. It could be something simple.. |
06-26-2015, 7:46pm | #7 | ||||||
Went out and data logged the car. When I am at converter lock up speed, 45-40 mph, it is where I am having surging, in my mind issues. It is the converter locking and my cam causing it to chug along and surge. Its a 230/236 544 555 114 LSA cam. Not huge, but kinda big and idles a little rough.
I am thinking I need to raise the speed for lock up and be done with it. I have a B&M stack cooler along with BeCool radiator internal cooler. Thoughts? |
06-26-2015, 8:19pm | #8 | ||||||
No thoughts as I'm not familiar with your cam or setup. Have you tried
"the other place" such as C4 Tech/Performance or C4 Scan/Tune? Other members, feel free to chime in. I know this thread is viewed... (over 48 views) |
06-26-2015, 8:21pm | #9 | ||||||
06-26-2015, 8:28pm | #10 | ||||||
Looks like you may have your answer in #7...
All Greek to me. I'm glad we were able to help you out.. |
06-27-2015, 8:06pm | #11 | ||||||
When I installed my 383 with a bigger cam in my 89 Vette, I had the same problem..You could feel the cam surging at certain lower rpms in high gear with the convertor locked up , mine was always at 1100- 1150 rpms...I reburned my chip to set my high speed convertor lockup at 53 mph and unlock at 49 mph and the symptom went away... I'm also running a stock torque convertor, if my convertor had a higher stall speed like 2200-2400 I may not of had the problem in the first place.....WW.
