Old 08-09-2014, 8:51pm   #1
Black95
Barn Stall Owner #204
Points: 13,742, Level: 80
Activity: 1.4%
Black95's Avatar
Gameroom Barn Bucks: $403724
Default Wheel Problem
I just have two new tires mounted on the rear of my 1995 sawblades and they mounted them on backwards. Can I just switch them?
Black95 is offline   Reply With Quote
Old 08-09-2014, 9:31pm   #2
DukeAllen
Points: 42,433, Level: 100
Activity: 99.5%
DukeAllen's Avatar
You'd be coming and going. I'd take them back and raise hell and get it done right. And next time don't leave without making sure it is right
DukeAllen is offline   Reply With Quote
The Following User Says Thank You to DukeAllen For This Useful Post:
Old 08-10-2014, 8:04am   #3
Black95
Activity: 1.4%
Black95's Avatar
Thanks for the advice, but it probably ain't going to happen because of location. I was attending the Black Hills Corvette Classic in Sioux Falls, SD which is 250 miles away. I picked up a nail at the very edge of the tread where it curves up into the sidewall and was advised that the patch would probably not hold and the next day was the drive to Spearfish, SD for the week of the rally. Since the tread was getting thin, I had them put on two new tires on the rear, hence my problem. Wasn't astute enough to catch the switch at the time as I was so relieved that they even had tires the correct size and I could continue on from Sioux Falls in the Corvette caravan to Spearfish, SD. No one at the rally brought it to my attention either, which surprises me. Maybe they just thought I was a dork and didn't know any better. Dork part, I am not so surre of but now I will know better about the wheels.
Old 08-10-2014, 9:27am   #4
DukeAllen
Activity: 99.5%
DukeAllen's Avatar
We're both dorks, that's why we still hang out in the dead C4 section
Old 08-10-2014, 9:43am   #5
Black95
Activity: 1.4%
Black95's Avatar
It has been pretty dead lately!
Old 08-10-2014, 11:07am   #6
five-oh
Points: 11,522, Level: 74
five-oh's Avatar
Gameroom Barn Bucks: $429031
Dorks.
five-oh is offline   Reply With Quote
The Following 2 Users Say Thank You to five-oh For This Useful Post:
Old 08-10-2014, 11:35am   #7
Points: 35,189, Level: 100
Assuming directional tires here...
If both rears are currently rotating backwards, then yes, you simply switch the wheels side-to-side on the car. Easy DIY fix.
However, if only one tire is running backwards but the other side is pointed correct, then the incorrect-rotation tire will need to be dismounted, flipped on the wheel, and remounted/balanced by a tire shop.
Tire shops generally know sets of tires have to be mirror-mounted on the wheels to achieve correct rotation orientation once the car....Once directional tires are mounted on the wheels, there becomes a defined "right" and "left". You obviously need one of each. If only one is off, they mounted both tires in a "left" configuration, for example.
But if both sides are currently wrong, then the wheels were just bolted on the car wrong, something you can fix yourself at home.
Old 08-10-2014, 11:58am   #8
Black95
Activity: 1.4%
Black95's Avatar
Thanks. I checked and the tires are on the correct side (each tire is marked "left" and "right") so they switched the rims before mounting tires and mounting on car. I guess I will have to have them remounted on the wheels and balanced. Back to their shop!
Old 08-10-2014, 11:59am   #9
Black95
Activity: 1.4%
Black95's Avatar
Originally Posted by five-oh View Post
Dorks.
DukeAllen and me or the tire mounting guys?
The Following 2 Users Say Thank You to Black95 For This Useful Post:
Old 08-10-2014, 12:12pm   #10
SQUIRMIN VERMIN 84
Barn Stall Owner #49
Points: 23,623, Level: 100
Activity: 1.8%
SQUIRMIN VERMIN 84's Avatar
Gameroom Barn Bucks: $1025197
It's not clear who Bobby was referring to, but you already thanked him for the comment......
SQUIRMIN VERMIN 84 is offline   Reply With Quote
The Following 2 Users Say Thank You to SQUIRMIN VERMIN 84 For This Useful Post:
Old 08-10-2014, 12:16pm   #11
Can you tell me which tires are on it? (brand/model/size)
Tires marked and sold as "left" and "right" would also be asymmetrical (specific inner and outer tread pattern). It sounds like this is what you have, and if so, you'd be correct...Both tires would need to be flipped on the wheels to achieve correct inner/outer orientation, as well as proper rotation direction.
Directional (only) tires can be a left or right until mounted, the tire itself is no different...They usually just have an arrow indicating proper direction.
Old 08-10-2014, 9:06pm   #12
five-oh
five-oh's Avatar
Allow me to clarify- You and Duke are dorks. I am qualified in saying this, as I know you and the evidence is ample in this forum.
I don't know the shop guys, thus no judgement- but evidence is looking to show that they are not only dorks, but morons.
In any case- Duke and the teacher from the Dakotas are dorks.
There. That should wake things up.
The Following User Says Thank You to five-oh For This Useful Post:
Old 08-10-2014, 9:54pm   #13
Black95
Activity: 1.4%
Black95's Avatar
DORK = Delightfully Organized Reliable Knight
Old 08-10-2014, 10:27pm   #14
DukeAllen
Activity: 99.5%
DukeAllen's Avatar
I should give the rat your donuts!
The Following 2 Users Say Thank You to DukeAllen For This Useful Post:
Old 08-10-2014, 11:52pm   #15
SQUIRMIN VERMIN 84
Activity: 1.8%
No Mikey, DORK= Drastically Over Rated Kornhole
The Following User Says Thank You to SQUIRMIN VERMIN 84 For This Useful Post:
Old 08-11-2014, 12:21am   #16
DukeAllen
Activity: 99.5%
DukeAllen's Avatar
Originally Posted by SQUIRMIN VERMIN 84 View Post
No Mikey, DORK= Dirty Old Rat's Kornhole
fify
Old 08-11-2014, 12:29am   #17
SQUIRMIN VERMIN 84
Activity: 1.8%
hahaha....works for me!
Old 08-11-2014, 12:37am   #18
SQUIRMIN VERMIN 84
Activity: 1.8%
I meant to ask Bobby if he knew one of my rat relatives over in his neck of the woods..
Awesome Possum...
Old 08-11-2014, 12:49am   #19
DukeAllen
Activity: 99.5%
DukeAllen's Avatar
Cover it in chocolate and he'll order a dozen
Old 08-11-2014, 8:41am   #20
Black95
Activity: 1.4%
Black95's Avatar
Based on the timestamps on your forum postings, you guys must do your best work after midnight!
