Old 08-10-2014, 9:55am   #41
Pete K
Points: 9,579, Level: 67
Pete K's Avatar
Gameroom Barn Bucks: $101055
On my 87, headlights will still work when the Vats has been triggered.
I would be looking towards the ignition switch contacts, ignition switch relay, or clutch pedal switch.
Pete K is offline   Reply With Quote
Old 08-21-2014, 9:12pm   #42
Frizlefrak
Barn Stall Owner #46
Points: 38,732, Level: 100
Activity: 1.0%
Frizlefrak's Avatar
Gameroom Barn Bucks: $4309769
Originally Posted by Iron Chef View Post
...I think my VATS ate my lunch this weekend.
Got in the ZR...started...backed out of the garage...turned it off to go in the house. 2 minutes later I come out, turn the key...nothing. And I mean not even a click. Can't roll the headlights...no joy. Tried to jump start...nothing. Battery is less than a year old and when I touched the jumpers together I got plenty of spark.
So my questions are a) Does this sound like the dreaded VATS problem and b) Friz...do any pics exist of the install? I take it it's easy (my ZR is a '94).
Corvette mods sells the bypass also. They are asking for a code (1-15...I'll assume this is the resistor code?). Do I need to go to the dealer to find out what it is?
Any help is appreciated. And yes I know I haven't posted in a long time. And no I didn't sell the Z. Thankfully.
Doesn't sound like a VATS problem....Sounds like either a loose ground connection, loose cable on starter, or a fusible link has gone bad. If it were VATS, you'd have full power to all accessories...it just wouldn't crank.
But the module takes all of 5 minutes to install....lower bottom cover under column, unplug connection and plug both ends into module.
Frizlefrak is offline   Reply With Quote
