06-04-2012, 8:39pm | #21 | ||||||
Gameroom Barn Bucks: $1524159
Hi Pete. As of this posting, I'm in San Diego right across Interstate 5 about 3 miles from the airport. My flight leaves at 9am tomorrow. My wife and daughter's flight is at 10am. I should be arriving in VB by 5-6pm.
Bill & Bob: I hope I can stop and meet some of you guys, but it's dependent on time. My son has to leave my house in Hemet on Sunday, so if we arrive on Saturday early, then we should be able to stop by for an hour at least. |
06-04-2012, 9:08pm | #22 | |||||||
Gameroom Barn Bucks: $429031
06-04-2012, 10:48pm | #23 | ||||||
Gameroom Barn Bucks: $882805
Same goes here. Except for the work part. TMT only knows I work my azz off everyday.
06-05-2012, 9:20am | #24 | ||||||||
Gameroom Barn Bucks: $741437
In true oil patch fashion Bill |
06-05-2012, 10:20am | #25 | ||||||
The Following User Says Thank You to five-oh For This Useful Post: |
06-05-2012, 1:04pm | #26 | ||||||
06-05-2012, 7:15pm | #27 | ||||||
I'm in VB and ready to leave in the morning.
I do have a question for some of you gear heads. My son has a F150, 2008, and we are pulling a small trailer, probably weighing in at 5,000lbs. If we are driving on a FLAT area with no hills, can we use overdrive? |
06-05-2012, 7:25pm | #28 | |||||||
Most Definitely,Maybe..I have a F150 with the 4.6 V8 and automatic, I do tow with it in overdrive...WW This is from the Ford site.... DRIVING WITH AN AUTOMATIC OVERDRIVE TRANSMISSION With automatic overdrive transmissions, towing – especially in hilly areas – may cause excessive shifting between overdrive and the next lower gear. • To eliminate this condition and achieve steadier performance, overdrive can be locked out (see vehicle Owner Guide) • If excessive shifting does not occur, use overdrive to optimize fuel economy • Overdrive may also be locked out to obtain engine braking on downgrades • When available, select Tow/Haul mode to automatically eliminate unwanted gear search and help control vehicle speed when going downhill |
06-05-2012, 7:27pm | #29 | |||||||
06-05-2012, 7:31pm | #30 | ||||||
On flat areas I use OD, when I hit hills I turn it off on my F-150 with Auto. If you have it on and hit a hill it will come out of OD itself, but like the site says it may shift back and forth when it hits a less hilly area....WW
06-05-2012, 8:17pm | #31 | ||||||
When we pulled our small travel trailer from TX to OK driving a 96 Chevy 1500 the tranny started whinning. It took me a while to figure it out but when I did and turned off the OD it quieted down.
06-06-2012, 6:45pm | #32 | ||||||
We are in Crossville, TN. Tomorrow we drive 14 hours and try to make it to the border of OK and TX to spend the night.
I must say that the highways in Virgina, North Carolina, and Tennessee are the best I've ever seen. Even the rest stops are immaculate and beautiful. |
06-06-2012, 7:15pm | #33 | |||||||
06-06-2012, 7:40pm | #34 | ||||||
06-06-2012, 9:30pm | #35 | |||||||
06-06-2012, 9:39pm | #36 | ||||||
You forget the most important reason Pete, winters, especially the countless freeze thaw cycles, completely murderous on asphalt
06-06-2012, 9:46pm | #37 | ||||||
The Following 2 Users Say Thank You to C4fan For This Useful Post: |
06-06-2012, 9:50pm | #38 | ||||||
The Following 2 Users Say Thank You to Sweet 90 For This Useful Post: |
06-06-2012, 9:53pm | #39 | ||||||
Yes, few Michigan residents got butt-hurt when I expressed myself about their roadways. Remember, I'm driving The Ghost and that thing is not built for the road. Now I know why I always see Bryan hauling his C4 Vette.
06-06-2012, 9:56pm | #40 | ||||||
