02-17-2021, 11:00pm | #121 | |||||||
2020 Election Expert
Gameroom Barn Bucks: $1134156
What a shit show! |
02-17-2021, 11:03pm | #122 | |||||||
Barn Raising I
Gameroom Barn Bucks: $308343
Wish I'd though of that a few days back. I have my 4 RV giant coach batteries fully charged in my garage. I could run half the house on those with a decent inverter. |
The Following User Says Thank You to TripleBlack For This Useful Post: |
02-17-2021, 11:07pm | #123 | ||||||
My break...
02-17-2021, 11:16pm | #124 | ||||||
02-17-2021, 11:27pm | #125 | ||||||
Notice there is NOTHING around the pipe where it enters the wall. A 31 degree brick is able to transfer 31 degrees to that pipe. In looking at pictures taken during the build, that pipe has split foam around it, after it turns 90 degrees up inside the wall. That's all the protection there is.
One suggestion I read was to vent house air into the void between the studs. Like a bathroom vent. That's only effective if you have power though. The battery/inverter sounds like a solid plan except the discharge rate is WAY over the safety point of a car battery. It would run about 3 hours for a 1500W heater. I'm thinking a specific 12V heater is the answer. I can connect it to a battery and run it a LOOOOOONG time. I only need it to keep the void above freezing. I'm thinking a could fill the void with closed cell foam (R value of about 7) and at the base, open the drywall and place the 12v heater there. The wrap on the outside would be effective then. |
02-17-2021, 11:38pm | #126 | |||||||
02-17-2021, 11:41pm | #127 | ||||||
02-17-2021, 11:58pm | #128 | ||||||
02-18-2021, 12:04am | #129 | ||||||
DAMMIT !! Power is off again.
02-18-2021, 12:39am | #130 | ||||||
The Following 2 Users Say Thank You to dvarapala For This Useful Post: |
02-18-2021, 5:04am | #131 | ||||||
Goldilocks
Gameroom Barn Bucks: $1009320
02-18-2021, 7:08am | #132 | ||||||
Invertor not mesnt to power a space heater at all, sorry for confusion. Should have a kerosene heater also on standby.
That exposed water line is common in the deep South, stupid design that shoukd never be permitted regardless of area. Some frame them in and insulate the pipe with heat tape, about all you can do with that setup. That and upsize the pipe. |
02-18-2021, 8:45am | #133 | ||||||
Have power here, low water pressure and a boil water edict in place. I have an exposed pipe on the outside of the house, which I insulated with foam pipe insulation the again with another, larger diameter foam insulation, then wrapped an old blanket around the whole mess and covered that with a big contractor trash bag to keep it dry. Similar set up on the faucets.
The other thong I did was wake up every couple of hours and rule n all the faucets and flush the toilets every 2 hours during the hard freeze period. |
02-18-2021, 9:07am | #134 | ||||||
What a mess.
02-18-2021, 9:08am | #135 | ||||||
Barn Stall Owner #122
Gameroom Barn Bucks: $1158963
I do feel a bit of Karma coming for you guys posting warm weather shit while we freeze up north. lol
The Following 4 Users Say Thank You to VatorMan For This Useful Post: |
02-18-2021, 9:09am | #136 | ||||||
Gameroom Barn Bucks: $2173478
Any of you Huston guys got a line on plumbing solder and flux?
02-18-2021, 9:10am | #137 | ||||||
02-18-2021, 9:11am | #138 | ||||||
02-18-2021, 9:21am | #139 | ||||||
I wish I could help you, but plumbing is not my thing. It took me several days just to get my fridge hooked up to the water supply. I used a compression fitting, and I kept checking.....drip. Tighten, check drip, repeat, until I overtightened. I think the third fitting finally took. Ever since then, I don't do plumbing.
The Following 3 Users Say Thank You to Bill For This Useful Post: |
02-18-2021, 9:34am | #140 | ||||||
Gameroom Barn Bucks: $12721
After getting lucky earlier in the week with rain instead of ice, it is snowing now at my house. Expecting another 10+ inches which we really don't need. ****in' February.
