03-20-2014, 10:20am | #1 | ||||||
Barn Raising I
Gameroom Barn Bucks: $10432620
Door Controls Not Working???
The window and locks for my passenger door have stopped working. Anybody know what's going on and/or how to fix this? It's pretty irritating.
03-20-2014, 10:59am | #2 | ||||||
Two most common causes:
1. The wires/connector in the accordion tube between the door and car. The accordion can be pulled back to expose and inspect the connector for corrosion/loose connection, and/or wires that may have worn through the insulation. 2. The pass. door control module is bad. This is located in the door and contains the relays for the lock/window functions. Easily accessed with door panel removed. Though left and right door modules are different, I seem to recall they can be swapped for testing purposes. Replacement modules can be found for about $100. |
04-10-2014, 8:58am | #3 | ||||||
Gameroom Barn Bucks: $870
Smiler thing happened to me...Bad ground wire in drivers door connector on car side. Not door side. I used a pick to push the female side of the connecter back together and all is good for three years now.
The Following User Says Thank You to Shagster For This Useful Post: |
