Old 10-16-2012, 3:41pm   #1
PortDawg
Charter Member - C3 Mod
Barn Stall Owner #34
NCM Supporter '15
Points: 30,980, Level: 100
PortDawg's Avatar
Gameroom Barn Bucks: $173
Default Electrical Gremlin has the Z down.
Got the dreaded Charging System Fault.
Replaced the alternator since it was smoking. No Joy.
Took it to Advance, they ran the diagnostic.
Not getting a charge to the Battery.
Alternator was bench checked.
Checked good.
Thoughts?
Old 10-17-2012, 7:02am   #2
PortDawg
NCM Supporter '15
PortDawg's Avatar
Buehler?
Old 10-18-2012, 5:38am   #3
wwomanC6
C6 Modulator
Barn Stall Owner #27
NCM Supporter '13,'14,'15
Points: 77,846, Level: 100
Activity: 51.5%
wwomanC6's Avatar
Since it was smoking have you checked the associated wiring connected to the alternator? Battery? Belt?
Old 10-18-2012, 7:00am   #4
PortDawg
NCM Supporter '15
PortDawg's Avatar
Yeah, I'm cleaning grounds now...
When I'm not working that is.
Old 10-18-2012, 6:29pm   #5
thegreenman
Points: 15,494, Level: 85
thegreenman's Avatar
Pull the battery and check cables, maybe battery is leaking acid onto something.
Old 10-18-2012, 6:34pm   #6
RonC5
Barn Stall Owner #1969
NCM Supporter '12,'13,'14,'15,'17,'21
Points: 21,046, Level: 100
Activity: 3.2%
RonC5's Avatar
Gameroom Barn Bucks: $132003
I did get that message once, caused me to do a little research. I found this....
maybe it will work for you.
RonC5 is offline   Reply With Quote
Old 10-19-2012, 4:45pm   #7
PortDawg
NCM Supporter '15
PortDawg's Avatar
Yep..did this...didn't help
Old 10-19-2012, 4:51pm   #8
PortDawg
NCM Supporter '15
PortDawg's Avatar
Corvette DIC message CHARGING SYSTEM FAULT - YouTube
After the tow truck deposited the Z at the shop, (Don't ask), it was verified that the new generator was only producing 9 volts which isn't enough to charge jack crap. So that one will come out tomorrow and be replaced with a OEM replacement and a new battery cable is already in.
Old 10-19-2012, 6:51pm   #9
wwomanC6
C6 Modulator
Activity: 51.5%
wwomanC6's Avatar
Hey Ron or Jim, can you give us the cliff on this video? I could only make through as far as the ice cream truck music. I got side tracked and had to grab some ice cream.
Jim, hope your able to get it fixed tomorrow!
Old 10-20-2012, 8:42am   #10
PortDawg
NCM Supporter '15
PortDawg's Avatar
Among other things it explains cleaning all the grounds and the connections to the PCM....
Hopefully it'll be done in an hour....
The Following User Says Thank You to PortDawg For This Useful Post:
Old 10-20-2012, 1:23pm   #11
PortDawg
NCM Supporter '15
PortDawg's Avatar
Well, that fixed it...she's back to normal...
Old 10-20-2012, 3:00pm   #12
RonC5
Activity: 3.2%
RonC5's Avatar
It is an overly in-depth video by a slow talker. However, it is a great explaination of cleaning the PCM connection.
The Following User Says Thank You to RonC5 For This Useful Post:
Old 10-20-2012, 3:00pm   #13
RonC5
Activity: 3.2%
RonC5's Avatar
Awesome.
Old 10-20-2012, 3:44pm   #14
wwomanC6
C6 Modulator
Activity: 51.5%
wwomanC6's Avatar
WooHoo
Soooo, replaced Alternator, battery cables, cleaned all the grounds and this fixed it!?
Did I miss anything?
Old 10-25-2012, 7:55am   #15
RonC5
Activity: 3.2%
RonC5's Avatar
Indeed.
