Go Back   The Vette Barn > C5 Corvette > C5 Classifieds
C5 Classifieds Buy, sell, trade C5 cars, parts and accessories
Old 01-19-2010, 8:27pm   #1
DropTheTop
Barn Stall Owner #777
Points: 22,113, Level: 100
DropTheTop's Avatar
Gameroom Barn Bucks: $6589249
Default FS - Column Lock Bypass Module (CLB) 1997-2004
Applications:
All year C5's with MN6 transmission
All pre-2001 w/ A4 transmission
Purchased from Adaptive Performance - Brand new and never installed.
I'm including installation instructions from both Adaptive Performance, and a detailed print out from LS1howto.com
$40 shipped in the US.
Old 01-21-2010, 10:28am   #2
DropTheTop
DropTheTop's Avatar
Guess everyone smart enough to join the Barn, was also smart enough to get one of these already!
Old 01-21-2010, 9:17pm   #3
I don't have one.
Old 01-21-2010, 9:59pm   #4
DropTheTop
DropTheTop's Avatar
Originally Posted by Munch View Post
I don't have one.
Does your car have the recall done? Try turning your wheel with the key removed. Are you aware of the dreaded issues with the column lock?
Old 01-21-2010, 10:11pm   #5
I am aware of the 1 million plus posts on other forums regarding this problem and yes the steering wheel lock works so i assume the recall was not done on my car. I am just gonna chance it, it's been ten years and no problem yet.
Old 01-21-2010, 10:17pm   #6
DropTheTop
DropTheTop's Avatar
IB4Munch'sColumnLocksAndLeavesHimStrandedAsHeCursesUpAStormAndWishedHeBoughtThisCLB!
Old 01-21-2010, 10:29pm   #7
Don't you get a couple "pull key and wait 10 seconds" warnings before it completely goes?
Old 01-21-2010, 10:34pm   #8
DropTheTop
DropTheTop's Avatar
Not necessarily. Some quality reading here:
Steering Column Lock FAQs - please read before you post (sticky please) - Corvette Forum
Old 01-22-2010, 6:36pm   #9
Garb55
Points: 17,083, Level: 90
Garb55's Avatar
Gameroom Barn Bucks: $7813
So if you remove key and the steering wheel moves you are good? And if the steering wheel is still locked you take a chance? If the recall has been done then I assume the same applies????
Thanks in advance!!
Old 01-22-2010, 9:31pm   #10
DropTheTop
DropTheTop's Avatar
Thanks in advance!!
"GM installed a Steering Column Lock mechanism on all 1997 - 2004 manual (MN6) cars and on 1997 to 2000 automatic (A4) cars
There is a GM recall for this problem on affected models and years
It is one of the most problematic issues that we C5 owners deal with
It can happen to you if you have a pre-2001 A4 without the recall or CLB installed OR any year MN6 or Z06 car without a CLB installed. Age or mileage makes no difference.
Low battery voltage seems to aggravate and sometimes cause column lock failures"
"Q How can I tell if I’ve had the recall mod?
A1 If you have an A4 car, can you turn your steering wheel freely while the ignition key is removed? If so, you probably DO have the recall mod.
A2 For all cars, you can inspect your wiring by removing your knee bolster under the driver's side. Inspect your column lock harness. If the four wires in your ECL harness are Orange, Purple, Green, Black on both sides of the connector, then you DO NOT have the recall mod installed. If you have White, Purple, Green, Black on either side of the connector, then you DO have the recall mod."
"Q I have a MN6/M12 car, what will the recall do?
A IF you have a MN6/M12 car, the recall does NOT disable your column lock motor. It simply re-programs your PCM to guarantee your fuel is shut off at speeds above 2 mph so you cannot drive your car with the steering column locked. The column lock failure can still occur at any time and you will most likely be stranded somewhere needing to be towed to the nearest dealer for repair when it occurs.
Q If I have a MN6/M12 car, what should I do?
A Again this is a personal decision. Advice is to install a CLB and ignore the recall. It does nothing to prevent the problem from occurring."
The Following User Says Thank You to DropTheTop For This Useful Post:
Old 02-14-2010, 9:38am   #11
DropTheTop
DropTheTop's Avatar
- Sold -
To a smart owner over at the CF!
Old 03-11-2010, 7:02am   #12
Yamma
Points: 22,512, Level: 100
Yamma's Avatar
Gameroom Barn Bucks: $18115636
If you are lucky (like me) even after you put in the CLB you'll get this message every time you start your car for the next 2 years.
On those really good days....it won't tell you pull key, wait 10 - it'll just die at 2mph.
Yamma is offline   Reply With Quote
