Old 03-16-2011, 12:35pm   #1
Ch@0s
Points: 4,595, Level: 46
Activity: 0.6%
Ch@0s's Avatar
Gameroom Barn Bucks: $3699
Default Ch@0s Is Going LSX ... My swap
Here are the specs.
built/forged 5.3 347 iron block with 241 heads
MS3 cam
237/242, .603"/.609", 113 LSA
LS6 Intake
Wiring harness and PCM from a 99 Z28 tuned for the set up.
Ch@0s is offline   Reply With Quote
The Following User Says Thank You to Ch@0s For This Useful Post:
Old 03-16-2011, 12:42pm   #2
Vette Jockey
Points: 11,138, Level: 72
Vette Jockey's Avatar
Gameroom Barn Bucks: $460853
Vette Jockey is offline   Reply With Quote
Old 03-16-2011, 1:35pm   #3
Midnight85
Points: 2,672, Level: 33
Midnight85's Avatar
Gameroom Barn Bucks: $100015
Congrats! I've wanted to do the same thing for years but $$$ just kept going elsewhere. Keep us posted w/pics.
Midnight85 is offline   Reply With Quote
Old 03-16-2011, 3:10pm   #4
Ch@0s
Activity: 0.6%
Ch@0s's Avatar
You bet! I got a good deal on it
This is an on going parts list. I will edit as I go along.
Engine, Ecu and wiring $1300
Transmission and converter $1750
Racetronix 255 Fuel pump kit $120
Speehound motor mounts $100
Advanced Adapters 4L60E to 700R4 tail shaft adapter $214
A/C compressor high mount adapter $150
Corvette power steering pump,bracket and pulley $140
Corvettte alternator $100
Powerbond balancer $145
98 Corvette Batwing oil pan and C5 manifolds $50
Oil pan gasket $50
Starter from fleabay $56
Balancer bolt $14 gm
Hoses, and fuse block $80.00
TB cable $50
Tuning $100
Two O2 sensors $120
wirring and terminals $60
Transmission cooler and lines $220
Fuel lines and fittings $70
Radom Tech Cat cons $200
I might need to get a couple of Dakota Digital boxes
A/C lines and Compressor
Spent $5089.00 and some of this stuff is optional.. for example you dont have to spend $550 on a converter
So far I have made $2945 to offset the cost from sales of my old stuff. I still have a few parts lying around.
Old 03-17-2011, 9:00am   #5
C4fan
Points: 11,943, Level: 75
C4fan's Avatar
Gameroom Barn Bucks: $882805
That will make for one bad arse ride. I will be following this one. Good luck.
Old 03-20-2011, 12:03pm   #6
Ch@0s
Activity: 0.6%
Ch@0s's Avatar
I picked up a few more things this week
Took a 3hr drive but it was worth it.
OEM exhaust and oil pan from a 98 vette. I'm not sure if the oil pan will work but it's worth a shot.
the transmission and a 3000 stall.
Old 03-21-2011, 11:40am   #7
Vette Jockey
Old 03-21-2011, 5:51pm   #8
mike100
Points: 10,589, Level: 71
mike100's Avatar
Gameroom Barn Bucks: $2013824
what displacement is it? 327 c.i. or 347? you said it is a 5.3 lower end- I would be a little hesitant to go smaller cubes unless it spins to 7500 rpm.
Old 03-21-2011, 8:57pm   #9
Ch@0s
Activity: 0.6%
Ch@0s's Avatar
It's a 5.3 iron block bored to a 347 c.i with ls1 241 heads. So it's basically an iron LS1. If it were a 5.3 i would think about a smaller cam. I may still do it to get better street manners. The fool in me says "NO"
Old 03-22-2011, 7:08pm   #10
Ch@0s
Activity: 0.6%
Ch@0s's Avatar
The parts keep coming faster that i can work
Racetronix 255 pump kit and Speehound LS1 conversion mounts.
Old 03-23-2011, 12:24pm   #11
Vette Jockey
Old 03-23-2011, 9:45pm   #12
C4fan
C4fan's Avatar
Old 03-24-2011, 9:05pm   #13
This is cool.
Subscribed.
Old 03-26-2011, 6:04pm   #14
Ch@0s
Activity: 0.6%
Ch@0s's Avatar
You wouldn't think it takes 8 hrs to clean and paint an engine but it did.
I cleaned this thing with a wheel brush and tooth brush.What I couldn't reach with those I used a screw driver with a rag. I HATE CLEANING STUFF. I painted the valve covers coil brackets and fuel rail red to give it some spice. Now it's ready to drop in.
So tomorrow the short bock comes out.
Then I have to clean the engine compartment.
Disregard the ugly truck pan its just there to keep stuff out.
Old 03-27-2011, 10:02am   #15
C4fan
C4fan's Avatar
Wow, what a difference. A little cleaning and painting goes a long way. That looks great!!
The Following User Says Thank You to C4fan For This Useful Post:
Old 04-02-2011, 7:11pm   #16
Ch@0s
Activity: 0.6%
Ch@0s's Avatar
I worked on the wiring all afternoon. The F-body wiring harness is designed to put the PCM in the pass side.I need to mount mine on the drivers side on top of the battery. My plan is to take the harness apart sensor by sensor following the wires to the PCM then labeling the pin location. All the wires on the drivers side are going to be proximately 10 inches too long. Those will be cut down and new terminals will be crimped on then they will be reconnected. The passengers side I will disconnect reroute and reconnect they should be perfect. In the processes of dis-assembly I will omit any sensor or wire I will not need. I will also hunt down the 12V commons.
The grounds I will be leaving alone so far they will ground in their original locations on the block.
Old 04-03-2011, 9:06am   #17
C4fan
C4fan's Avatar
Better you than me, I'm not good with wiring. Looks like you've got is under control, looks good.
Old 04-05-2011, 7:38am   #18
Midnight85
Midnight85's Avatar
Looking good, can't wait to see the final product. I'm glad the wiring job is yours, I'd take one look at that and think that maybe my little L98 isn't so bad after all.
Old 04-05-2011, 10:44am   #19
Ch@0s
Activity: 0.6%
Ch@0s's Avatar
The only two things that I haven't quite figured out is how to get my A/C and ABS to tie in to the new PCM.
4L60E to 700R4 tail shaft adapter came in.
Old 04-07-2011, 8:21pm   #20
Ch@0s
Activity: 0.6%
Ch@0s's Avatar
I have been working on the harness. I need to order some wire and terminals. Looks like I will be adding length to the pass side. it's all routed and mocked up now. The Camaro harness really only had two connectors I did not need. The AIR and EGR.
Now that I have the PCM connectors off I need to sort through whats left. I have identified the 12V switched wires and plan on hooking them some where fused. The ignition and coil wired share a common 12v wire. I believe I will hook these up to inj1 and inj2 in the fuse panel.
Here is whats left.
Red Connector
9 DK/GRN FUEL PUMP RELAY CONTROL = not sure
10 WHT ENG SPEED (TACH) = goes to Tach
13 CRUISE ENABLE= not needed
17 DRK GRN/WHT A/C REQUEST SIGNAL = not sure
30 VDT FUEL ENABLE = VATTS
33 DK BLUE ENG COOLING FAN RELAY 2&3 CONTROL = to cooling fan relay 2
34 EVAP PURGE VALVE CONTROL= not needed
36 AIR PUMP RELAY CONTROL= not needed
37 DK GRN CRUISE CONTROL INHIBIT= not needed
43 DK GRN/WHT A/C CLUTCH RELAY RELAY CONTROL=not sure
45 WHT EVAP CANISTER VENT VALVE CONTROL= not needed
46 BRN/WHT MALFUNCTION INDICATOR LIGHT CONTROL= MIL ck eng light
50 DK GRN/WHT VEHICLE SPEED OUTPUT CIRCUIT= to speedo
17 DRK GRN/WHT A/C REQUEST SIGNAL=not sure
53 GRA/BLK SPARK RETARD CONTROL=not sure
54 PPL FUEL LEVEL SENSOR SIGNAL= not needed
64 DK GREEN FUEL TANK PRESSURE SENSOR= not needed
Blue Connector
19 PNK IGNITION POS VOLT= to switched 12v
20 ORG BAT POS VOLT=to 12v
23 GRA FUEL SENSOR /FUEL TANK SENDER GROUND== not needed
33 PPL TCC BRAKE SWITCH= to brake switch
34 ORG/BLK PNP WITCH= to park neutral safety switch
42 COOLING FAN RELAY CONTROL= Cooling fan relay
Feel free to correct me or help me figure out the connections I'm not sure about.
My A/C high mount bracket came in.
