Old 04-12-2011, 9:44pm   #1
jdel1968
Points: 4,988, Level: 48
Activity: 2.1%
jdel1968's Avatar
Gameroom Barn Bucks: $1098
Default Theft Deterrant System 2005 C6
Having some issues with the theft deterrant system. The Drivers side door opens but, can't adjust the mirrors , operate the lock/unlock switch and window switches will not work. The passenger side works fine and I can unlock drivers door using passenger side switch. The Theft deterrant light stays lit. (on dash)
Both windows were indexing just fine untill I had heard that if I disconnect the negative battery terminal for 15 minutes it would reset the computer? When I did that the window went down about an inch and I cant get it closed . (rivers side) I have checked fuses etc. Any ideas before I take it in and through myself on the mercy of the dealership?
jdel1968 is offline   Reply With Quote
Old 04-13-2011, 6:31am   #2
VatorMan
Barn Stall Owner #122
NCM Supporter '11,'13
Bantayan Kids '13,'14,'17
Points: 68,489, Level: 100
Activity: 5.8%
VatorMan's Avatar
Gameroom Barn Bucks: $1158963
Have you had any work done on that door ? Sounds like all the forward controls are disconnected. I'm not sure where the plug is for the door-I'd think under the dash.
VatorMan is offline   Reply With Quote
Old 04-13-2011, 8:12am   #3
jdel1968
Activity: 2.1%
jdel1968's Avatar
No work has been done on door at all. Crazy thing is that the window "was" indexing and the switches still light.
Old 04-13-2011, 2:49pm   #4
VatorMan
Activity: 5.8%
VatorMan's Avatar
The only other thing I can think of is look under all the DIC options and see if something got turned off.
Old 04-13-2011, 9:28pm   #5
jdel1968
Activity: 2.1%
jdel1968's Avatar
Thanks, Looked through all options on DIC and no luck. I think I have now tryed everything and will have to take it in. I really think its a short or ground somewhere but darned if I can find it.
Old 07-17-2011, 8:27pm   #6
pappytinker
Points: 2,155, Level: 29
Activity: 1.2%
pappytinker's Avatar
Gameroom Barn Bucks: $3478
Did you re-initialize the indexing feature of the windows after reconnecting the battery?
If not;
Power Window Initialize
After a power reconnect such as battery replacement, the
window index-up feature will not function until the system
is initialized. Once power is restored, do the following:
1. Close the door.
2. Raise the window by pulling up the switch.
3. Hold the up switch for three seconds after the
window is closed. Release the switch.
4. Hold the up switch again for three seconds and
release.
pappytinker is offline   Reply With Quote
Old 11-29-2011, 10:37am   #7
WarDriver
Points: 1,176, Level: 19
WarDriver's Avatar
Gameroom Barn Bucks: $945
Could be a bad Driver Door Module.
WarDriver is offline   Reply With Quote
Old 12-09-2011, 1:07pm   #8
catbert
Points: 2,524, Level: 32
Activity: 0.5%
catbert's Avatar
Gameroom Barn Bucks: $572
Also could be a bad chassis ground.
catbert is offline   Reply With Quote
Old 12-18-2011, 5:46pm   #9
jdel1968
Activity: 2.1%
jdel1968's Avatar
That is exactly what it was!
The Following User Says Thank You to jdel1968 For This Useful Post:
Old 12-18-2011, 7:41pm   #10
wwomanC6
C6 Modulator
Barn Stall Owner #27
NCM Supporter '13,'14,'15
Points: 77,846, Level: 100
Activity: 51.5%
wwomanC6's Avatar
Thanks for the update!
