Old 03-29-2011, 3:14pm   #121
Eagleeye
Points: 10,779, Level: 71
Eagleeye's Avatar
Gameroom Barn Bucks: $2288
Brian...will you retain the stock door glass ? BTW-I've got B-pillar wind noise so was that part of the trim any issue to remove ? Really enjoy your pics !
Old 03-29-2011, 4:03pm   #122
No I won't ben keeping the door glass. Due to my size I need all the room I can get for the cage and still be able to drive the car comfortably.
The trim isn't too bad to removed, but you will end up tearing the weather strip in the areas it's held on with adhesive so best to buy new ones if you have to remove. After that there is a metal run channel and the plastic trim part. For this I didn't really take my time and ripped it all off, but when I did my trarga I took lots of care to remove w/o breaking anything.
It can be hard to w/o bending or cracking anything. And then there's a very specific procedure for putting it all back together with various adhesives in various areas to ensure no leaks!
Old 04-02-2011, 6:47pm   #123
Re-did the doors taking a little more off and the door beams out. Also removed the forward section of rocker in prep for trimming the A-pillars and installing the cage.
Oh... and I effed up on one of them... oh well it's a race car and I can fix it...
Old 04-06-2011, 12:46am   #124
No more dash or HVAC box etc. Spent some time labeling the entire wiring harness and re-taping everything. Anything not being used I wrapped out of the way into another pat of the harness to clean it up. Normally there's a foam wrap on much of it that has a really sticky nasty adhesive... peeled all of that off and wiped it down with goo-gone and a rag. Also cut out the horizontal brackets on the center consold support that used to hold the radio and HVAC module. It'll become one large switch panel.
Old 04-06-2011, 3:45pm   #125
Damn, she's gutted!
With the new weight reduction does that mean you can up the HP if you choose?
Old 04-06-2011, 6:03pm   #126
Originally Posted by Munch View Post
Damn, she's gutted!
Works the other way... Less weight = less power to meet the min 8.7 lbs/horse requirement. I'm prepping for the cage which will add around 125lbs to the car. Plus some other equipment etc I have to meet a minimum competition weight of 3118lbs with me in the car.
Old 04-09-2011, 6:18pm   #127
Fabbed up some panels for the holes in the firewall. Sealed with RTV and riveted in place.
The real fun of the day was pulling the fuel tanks. Gravity drained the fuel then got to work. Like anything if I had to do it again I could do it in 1/2 the time. There were a few quick-disconnect fittings for the evap system that were a pita to get to and get the right angle on.
Old 04-09-2011, 6:54pm   #128
mariofromnewyork
Points: 1,993, Level: 27
mariofromnewyork's Avatar
Gameroom Barn Bucks: $980
Brian,
Awesome work!
I have no problem taking mine apart, its when i put it back together I run into problems. I usually have a few pieces left over which i just call weight reduction! I guess this would be the correct way!
Mario
Old 04-11-2011, 1:11pm   #129
She's a convertible for the time being...
Old 04-14-2011, 8:34am   #130
Finally got the OEM "rollbar" seperated from the roof. Took a cable saw, lots of silicone spray, and a buddy to help hold the roof on the sawhorses. Just have to finish triming the side support ribs off of the roof panel.
I wanted it out in one piece because it makes the perfect guide for the cage builder to do the main hoop
Old 04-14-2011, 11:20pm   #131
Roof panel trimming done.. much more room for the cage....
Old 04-17-2011, 9:30pm   #132
Cut the top layer of the floor out and gained 5/8" of headroom vs. the standard hardware that came with my Hardbar seat rail kit. The kit was designed to use with a stock floor and with the OEM carpet still in place. Car's ready to head in for the cage!
Old 04-18-2011, 6:38pm   #133
Damn! It's like a real live race car, nice work.
Will you be putting anything back in once the cage is installed or is that how it's going to roll?
Old 04-18-2011, 8:20pm   #134
Fire system, cool-shirt system, and the passenger seat... oh and the center console support will have a new switch panel to control it all... that's it. No dash pad going back in. Will paint the cage, door shells, roof underside, trans tunnel, and "wall" behind the seats white.
Old 04-18-2011, 8:56pm   #135
2ez 2spd
Barn Stall Owner #44
Points: 8,371, Level: 63
Activity: 1.9%
2ez 2spd's Avatar
Gameroom Barn Bucks: $30044
Why do you put the passenger seat back in, will you be selling tickets to ride to pay for your hobby?? if so sign me up it looks like a blast.
Nice work!!
Old 04-18-2011, 11:50pm   #136
Nice work!!
Something like that When I'm instructing it's nice to be able to give students rides. Also I can go out in any HPDE session so I can give friends/family a real ride vs. the watered down touring laps they sometime do at lunch.
When I eventually do wheel to wheel racing vs. the TimeTrials and instructing the seat will be removed.
Old 04-20-2011, 9:02pm   #137
Fabbed up a bracket to hold the cool shirt cooler. Just need to get a strap for the cooler etc. Will worry about that when it comes back from the cage install.
Old 04-20-2011, 10:23pm   #138
illmac77
The Chief
Barn Stall Owner #77
Points: 7,813, Level: 61
illmac77's Avatar
Gameroom Barn Bucks: $434
Love the beer cooler. Good call!
illmac77 is offline   Reply With Quote
Old 04-21-2011, 8:57am   #139
Shhhhh.... it's a cool shirt cooler! So what if I use cold beers to keep the water cold
Old 05-20-2011, 1:30pm   #140
Woohoo! Just received some pictures of the progress from Carlos @ Autodynamix. It's exactly what I envisioned for the roomiest C5 cage ever
