Old 06-30-2011, 10:18am   #1
Stangkiller
Barn Stall Owner #5
Barn Raising I,II,III,IV
NCM Supporter '11,'12,'13,'14,'16,'17,'19,'20,'21
Points: 50,885, Level: 100
Activity: 1.4%
Stangkiller's Avatar
Gameroom Barn Bucks: $2173478
Default Who's Grilling Ribs this 4th of July
I plan to cook/grill some Baby Back ribs <If I can find them>.
It's been a while since I've done cooked ribs, but I think I'm going to soak the ribs in beer/whiskey tonight, <after peeling off that tough thin layer of fat> then dry rub tomorrow and bake over some juice & beer, at about 200* for 3-4 hrs. Refrigerate over night and grill with BBQ on Saturday for about 30minutes or till it's warm.
What ya'll think, how are ya'll going to do it?
Stangkiller is offline   Reply With Quote
Old 06-30-2011, 10:33am   #2
DropTheTop
Barn Stall Owner #777
Points: 22,113, Level: 100
DropTheTop's Avatar
Gameroom Barn Bucks: $6589249
I'm taking some to a party, so I'm gonna cheap out a little and do St. Louis style spare ribs. Around here, that translates to $2.49/lb versus $4.99 for baby backs.
Anywho, I'll trim 'em up proper, then marinade them in some cider and OJ, etc... overnight. Then pat dry and smear 'em with mustard, and then rub 'em down with a sweet/hot rub I make. The I'll start smoking 'em around 250 deg., spraying them with apple juice every 1/2 hour. I also like to keep a light smoke going for the first couple hours, starting with mesquite then finishing with apple wood. I'll do the Texas crutch a few hours in, then finish 'em up until I'm satisfied they're done and the meat's pulled back off the bones enough.
I personally prefer smoking baby backs with a dry rub, and just leave 'em alone for 6 hours. In this case, I know the group will be made up of people that don't really know what they're getting, and think that all ribs should have the meat falling off the bone. That's why I chose this method.
The Following User Says Thank You to DropTheTop For This Useful Post:
Old 07-02-2011, 11:14pm   #3
R.I.B.S.
Points: 7,257, Level: 59
Activity: 4.1%
R.I.B.S.'s Avatar
Location: Living in the South Pacific on a Tropical Island
Gameroom Barn Bucks: $885
Those sound GREAT...
Im planning on PR....
R.I.B.S. is offline   Reply With Quote
The Following User Says Thank You to R.I.B.S. For This Useful Post:
Old 07-05-2011, 3:27pm   #4
Stangkiller
Barn Stall Owner #5
Activity: 1.4%
Overall they came out ok...they weren't fall of the bone, not sure what else I could have done. We wound up baking for 4 hours, refrigerating overnight, we put them in a smoker for about 45 minutes, then put on BBQ sauce and caramelized the sauce <5 minutes maybe>.
The flavor was great, the texture was great, they just weren't falling off the bone :-(
Did I need to cook them longer? Did I cook them at too high a temp?
Old 07-05-2011, 3:47pm   #5
Z06David
Points: 11,742, Level: 74
Activity: 0.6%
Z06David's Avatar
Gameroom Barn Bucks: $1009022
200 degrees is fine, they should have just cooked longer
Z06David is offline   Reply With Quote
The Following User Says Thank You to Z06David For This Useful Post:
Old 07-09-2011, 7:11am   #6
Stangkiller
Barn Stall Owner #5
Activity: 1.4%
How long do y'all cook your ribs?
Old 07-09-2011, 7:44am   #7
RonC5
Barn Stall Owner #1969
NCM Supporter '12,'13,'14,'15,'17,'21
Points: 21,234, Level: 100
RonC5's Avatar
Gameroom Barn Bucks: $132003
Babybacks for around 4-4.5 hours at around 220. Just at the point where they pull off the bone very easily.
RonC5 is offline   Reply With Quote
Old 07-09-2011, 7:53am   #8
Stangkiller
Barn Stall Owner #5
Activity: 1.4%
I must've been close.
Old 07-09-2011, 8:05am   #9
Stangkiller
Barn Stall Owner #5
Activity: 1.4%
Or did I need a stronger marinade the night before?
Old 07-09-2011, 11:07am   #10
Kerrmudgeon
Points: 152,726, Level: 100
Kerrmudgeon's Avatar
Gameroom Barn Bucks: $4614507
Easy way to check. if they break when you try to fold the rack they're done.
Kerrmudgeon is offline   Reply With Quote
Old 07-09-2011, 4:23pm   #11
Stangkiller
Barn Stall Owner #5
Activity: 1.4%
So internal temp really doesn't matter...they must maintain that temp for a few hours?
Old 07-09-2011, 9:45pm   #12
Kerrmudgeon
6 of one, half doz of the other, when they break, they've reached the right temp!, unless you want mush, or don't have any teef!
Old 07-10-2011, 2:36pm   #13
kingpin
SnowJob
Barn Stall Owner #999
Points: 83,194, Level: 100
Activity: 4.0%
kingpin's Avatar
Gameroom Barn Bucks: $8052038
I don't go by the fall off the bone. I remember watching a big bbq rib contest in Texas and the judges all said that the meat should come clean off the bone when you bite it. Fall off the bone is overcooked.
You can also tell the ribs are ready when the ends of the bones are black and dried out.
kingpin is offline   Reply With Quote
The Following User Says Thank You to kingpin For This Useful Post:
Old 07-10-2011, 9:21pm   #14
Stangkiller
Barn Stall Owner #5
Activity: 1.4%
By that definition I nailed it.
The Following User Says Thank You to Stangkiller For This Useful Post:
Old 07-11-2011, 7:45am   #15
DropTheTop
DropTheTop's Avatar
You got it. It's a matter of preference, so I gauge the crowd.
Fall off the bone is easy, raise your temps. Just don't go over 275.
Easiest way to raise consistent temps on a smoker, is to use lump charcoal rather than charcoal brickettes. Lump burns hotter and longer with less ash, just have plenty on hand. Brickettes burn cooler, and all that ash claps up the air flow after a while, making temp adjustments a real PITA.
Old 07-01-2012, 5:54pm   #16
Stangkiller
Barn Stall Owner #5
Activity: 1.4%
Well it's 4th of July again, and I'll be grillin ribs! Hahaha , if I cut the racks in half prior to cooking, will it cause any changes with cooking times?
Old 07-01-2012, 6:31pm   #17
MikeB
Barn Stall Owner #115
Points: 22,512, Level: 100
Activity: 8.3%
MikeB's Avatar
Gameroom Barn Bucks: $610854
I got 2 packages of baby backs yesterday, $2.88/lb, so they're scheduled to be smoked on Wednesday.
I do this a few times each year.
On occassion, I'll throw a whole chicken in with the ribs:
Hand rub applied (Paprika, garlic powder (not salt) and pepper. Minimum 3 hour set time, longer is better)
Hickory chips, soaked in water for 3 hours, 3 burner grill, center burner off, 2 outside burners at low with inverted tents that hold the chips(indirect heat). I put a hand-full of chips in every 15 minutes over a two hour period.
Pot of salt potatoes (sp ) , 30 minutes over direct (low) heat with a slathering of BBQ sauce,
2.5 hrs cooking time, not much work, turns out great:
Wednesday can't get here fast enough:
MikeB is offline   Reply With Quote
Old 07-01-2012, 7:51pm   #18
smokestack
Barn Stall Owner #71
Points: 859, Level: 16
smokestack's Avatar
Gameroom Barn Bucks: $570
Default Re: Who's Grilling Ribs this 4th of July
That seems easy enough. Im going to use your grill method. First time rib chef here lol
smokestack is offline   Reply With Quote
Old 07-01-2012, 8:50pm   #19
Stangkiller
Barn Stall Owner #5
Activity: 1.4%
Make sure the broiler pan is tightly wrapped with tin foil, it won't hurt to cook more like 5 hours in the oven,
Old 07-01-2012, 9:42pm   #20
smokestack
smokestack's Avatar
Its been so hot i want to use the grill. Do you need to use the oven too or just the grill? I really need to find all the info somewhere online i guess lol. Wife and i really want ribs. Neither of us have ever made them from scratch. We have just got the premade store deals where you just warm them up. Really burnt out on those.
