Old 02-20-2010, 5:12pm   #1
1TZSLO
Points: 5,654, Level: 51
1TZSLO's Avatar
Gameroom Barn Bucks: $377
Default Guess what's inside!
Fidenza Al Flwheel/Textralia Z-Grip
Arctic White 97 C5 Coupe
NOT STOCK
Old 02-20-2010, 5:33pm   #2
03SlowZ06
Points: 3,068, Level: 36
03SlowZ06's Avatar
Gameroom Barn Bucks: $100431
Make sure you call them and get the torque specs for the pressure plate. It was a pain getting ahold of them last minute to get the specs and pattern.
50th Anniv. Quick Silver Z06
OBX LT's, Haltech Stinger
P1SC waiting to go on
The Following User Says Thank You to 03SlowZ06 For This Useful Post:
Old 02-20-2010, 9:03pm   #3
1TZSLO
1TZSLO's Avatar
good heads up thanks
NOT STOCK
Old 02-20-2010, 9:32pm   #4
Garb55
Points: 17,083, Level: 90
Garb55's Avatar
Gameroom Barn Bucks: $7813
Old 02-21-2010, 11:27am   #5
Peter Pan
Barn Stall Owner #58
Points: 9,221, Level: 66
Peter Pan's Avatar
Gameroom Barn Bucks: $13154
Nice looking clutch flywheel combo you have going in
Old 02-21-2010, 11:55am   #6
If you want to ensure zero vibration issues have the new clutch assembly match-balanced to the stocker that youre taking out.
Old 02-21-2010, 9:08pm   #7
YorkL8apex
Charter Member - C4 Mod
Barn Stall Owner #91
Points: 5,706, Level: 51
YorkL8apex's Avatar
Gameroom Barn Bucks: $2164
What Brian said
I did the same combo on the '04 Z06 I had and it really made the car come to life
1991 SGC ZR-1
YorkL8apex is offline   Reply With Quote
Old 02-21-2010, 9:51pm   #8
1TZSLO
1TZSLO's Avatar
Not sure even how to do that or where.
I couldnt pass this up 800 bucks for both pieces. Clutch brand new is 980
NOT STOCK
Old 02-21-2010, 9:54pm   #9
When you take the stock stuff out take it along w/ the new to a machine shop. I used Gregorys Driveline/Machine on Cleveland Street.
You have them spin the stock flywheel and pressure plate and see how it balances out. Then theyll match the new flywheel/pressure plate assembly to what they recorded for the stock stuff. If your stock suff is off-balanced theyll match it.
Reason for this is some cars come w/ a purposfully off-balanced clutch assembly. They do this to bring the engine assemblies in spec on the production line.
Old 02-22-2010, 5:37pm   #10
1TZSLO
1TZSLO's Avatar
Thanks for the information. Might have to do that when installing my S/C might as well throw in the Clutch and Sway bars
NOT STOCK
Old 02-22-2010, 6:01pm   #11
Shagster
Points: 3,577, Level: 39
Activity: 0.5%
Shagster's Avatar
Gameroom Barn Bucks: $870
Trans brace and rear end brace also... The trans is coming out anyways and most shops don't charge to put them in for you.
Shagster is offline   Reply With Quote
