Old 02-17-2010, 11:48pm   #1
1TZSLO
Points: 5,654, Level: 51
1TZSLO's Avatar
Gameroom Barn Bucks: $377
Default Sway bar replacement
Anyone know of a good guide for doing this. I know it is kinda straight forward but I am sure there is some torque spec they need for certain bolts upper and lower bolts on the rear I believe. Since I will be doing this myself any advice would be greatly appreciated.
Arctic White 97 C5 Coupe
NOT STOCK
Old 02-18-2010, 9:49am   #2
LS1Howto.com C5 Stabilizer Bar Swap
I just put Z06 bars on my vert a few weeks back and I've had the bars on/off my Z06 numerous times... it's a very easy job. If you're mechanically inclined you can have it all done in about 20-30 minutes.
A few tips:
1. You don't need to get a torque wrench on the end links... you really can't because you have to use an allen wrench to hold the stud and a gear wrench to tighten the nut. Just get them really tight. The how-to mentions that once they're good n' tight you may be able to put a deepwell on the nut and have it stay in place from the friction but I've never bothered and never had an issue.
2. Do not cross-thread the bolt that holds the rear bar to the rear suspension cradle. Make sure you have the bracket lined up properly and get the bolt started correctly.
3. Apply some lithium grease or teflon grease to the swaybar bushings for quiet operation especially if they're poly. If you do get poly you will need to unbolt the bars from the cradles and re-grease about once a year as they will start to squeek as the grease goes away... zero need for poly on a street car, but many people believe they're "way better" w/o understanding how a swaybar works and what the bushings are actually doing. I have a full poly bushing kit on my Z06... swaybars and all control arms.
4. Make sure you torque the nut and bolt on the rear cradle to spec... one is 50 ft/lbs and the other is 70 ft/lbs... LS1howto explains it in detail. One of them holds the lower control arm in place so if it's not torued to spec you can get some clanking in the rear.
HTH,
Brian
The Following 2 Users Say Thank You to Cobra4B For This Useful Post:
Old 02-18-2010, 11:49am   #3
1TZSLO
1TZSLO's Avatar
Good tips. Thanks
NOT STOCK
Old 02-18-2010, 1:27pm   #4
Vet4jdc
Barn Stall Owner #78
Points: 19,383, Level: 96
Vet4jdc's Avatar
Gameroom Barn Bucks: $1004569
I'm not all that mechanically inclined and I swapped out my sway bars myself!
Old 02-18-2010, 1:56pm   #5
1TZSLO
1TZSLO's Avatar
I will be doing so This sat at Oceana hobby Shop, since I live in an apartment.
NOT STOCK
Old 02-18-2010, 5:45pm   #6
1TZSLO
1TZSLO's Avatar
I am sure everyone knows how to install these but I will be taking pics of my install just because I want to document things I have done to the car.
NOT STOCK
Old 02-19-2010, 8:09am   #7
Good idea, not everyone knows how to do sway bars and stuff. That's why folks come here, for advice, and help.
I shoulda doen a write up when I did mine at Shags mancave.
Old 02-19-2010, 12:18pm   #8
No offense, but the write-up on ls1howto is comprehensive... take pics but no reason to do another "how-to".
Old 02-19-2010, 12:26pm   #9
1TZSLO
1TZSLO's Avatar
Wasn't really gonna be a How to but more of Hey I put new **** on my car.
NOT STOCK
