Old 01-20-2010, 7:37pm   #1
2ez 2spd
Barn Stall Owner #44
Points: 8,371, Level: 63
Activity: 1.9%
2ez 2spd's Avatar
Gameroom Barn Bucks: $30044
Default Code question?
When I was out driving this past weekend there were 2 times when I cut my car off I THINK I heard my horn chirp at a low volume, has anyone ever heard of this? or am I losing my mind.
I did check my codes and I had some history codes, no current. I cleaned them out and drove some to see what would come back and only 1 came back PCM P1571H - ASR Desired Torque. Can someone give some info about this code is it something that I need to check into?
C5 97 Arctic White A4
Old 01-21-2010, 8:34am   #2
P1571 is a stored history code that cannot be cleared off the 97's, and only the 97's for some reason.
It doesn't actually mean you have a malfunction, it is just there. So long as you aren't getting any other TC codes(traction control) or EBCM codes, or the code isn't a current one, then you are just fine.
Can't help you with the horn chirp.
Old 01-21-2010, 7:01pm   #3
2ez 2spd
Activity: 1.9%
2ez 2spd's Avatar
Thanks for that info that makes me feel better. As far as the horn chirp that might be just me I will see what happens this weekend if I go anywhere.
