Old 09-19-2020, 7:21pm   #1
thecornerman
Points: 8,265, Level: 63
Activity: 1.2%
thecornerman's Avatar
Gameroom Barn Bucks: $3335
Default Busy day
Time to evict the swarm of yellow jackets
Little basterds
2002 Roadster
K&N Air Filter
Borla Exhaust
thecornerman is offline   Reply With Quote
The Following 2 Users Say Thank You to thecornerman For This Useful Post:
Old 09-19-2020, 7:23pm   #2
mrvette
Barn Stall Owner #101
Points: 133,594, Level: 100
Activity: 10.1%
mrvette's Avatar
Couple of cans of brake cleaner........air out the house.....dun......
The Following User Says Thank You to mrvette For This Useful Post:
Old 09-19-2020, 7:24pm   #3
Rodnok1
Points: 42,618, Level: 100
Activity: 52.2%
Rodnok1's Avatar
Fuk me that a big nest.... I'd be hosing them with everything i could find.
Rodnok1 is offline   Reply With Quote
The Following 2 Users Say Thank You to Rodnok1 For This Useful Post:
Old 09-19-2020, 7:32pm   #4
thecornerman
Activity: 1.2%
After wall removal and scraping out the nest I replaced the insulation and started putting osb up. Probably a good thing though since that wall was always cold in the winter anyways
2002 Roadster
K&N Air Filter
Borla Exhaust
The Following 5 Users Say Thank You to thecornerman For This Useful Post:
Old 09-20-2020, 7:56am   #5
Points: 117,787, Level: 100
Activity: 34.9%
Did you hear buzzing in the wall
04 commemorative is offline   Reply With Quote
Old 09-20-2020, 8:57am   #6
m and t's77
Points: 15,981, Level: 87
Activity: 2.5%
m and t's77's Avatar
Gameroom Barn Bucks: $3122345
The Following User Says Thank You to m and t's77 For This Useful Post:
Old 09-20-2020, 9:03am   #7
thecornerman
Activity: 1.2%
Constant activity outside the sliders
Then the smell on both sides of the wall
2002 Roadster
K&N Air Filter
Borla Exhaust
The Following User Says Thank You to thecornerman For This Useful Post:
Old 09-20-2020, 5:31pm   #8
thecornerman
Activity: 1.2%
Day 2
What a week end this turned out to bee
2002 Roadster
K&N Air Filter
Borla Exhaust
Old 09-20-2020, 5:38pm   #9
MEANZ06
Points: 46,195, Level: 100
Activity: 0.8%
MEANZ06's Avatar
Gameroom Barn Bucks: $4635916
Originally Posted by thecornerman View Post
Day 2
MEANZ06 is offline   Reply With Quote
Old 09-20-2020, 6:16pm   #10
thecornerman
Activity: 1.2%
I have a building question if any of you are or know a builder
Why so many nails to hang OSB?
I know that I didn't put them every 4 inches like some recommend
And what if I don't put in enough nails?
2002 Roadster
K&N Air Filter
Borla Exhaust
Old 09-20-2020, 9:15pm   #11
Points: 223,746, Level: 100
Day 2
[snide] wasp [snide]
Old 09-20-2020, 9:18pm   #12
JRD77VET
NCM Supporter '16,'17,'19,'20
Points: 116,158, Level: 100
Activity: 9.4%
JRD77VET's Avatar
OSB doesn't have the strength of plywood, that's why it is recommended to nail every 4"
Old 09-20-2020, 9:24pm   #13
Rodnok1
Activity: 52.2%
Rodnok1's Avatar
Depends on location and useage, for sidwalls i never go closer than 6 inches unless maybe a tall shear wall. Osb doesn't seem to have shear capabilities that plywood does. For roofing 4 inch spacing may be code for lift off protection (hurricane zones) for 100 plus mph winds.
What will happen... Nothing more than likely unless you're in a hurrizone maybe. Don't get me wrong... 6 nails for a sheet isn't good, i have found that before along with 4 nails per window. I've kicked sheeting off walls both interior and exterior they have so few nails in them.
I don't use osb for anything exterior myself, especially if going to see any moisture. If you're in the snow belt i wouldn't have used it with deck right there if possibility of snow building up.
Old 09-20-2020, 9:57pm   #14
thecornerman
Activity: 1.2%
I was assuming (oh shit, I said it) that the 12 inch flashing at the base helps keep the moisture away. I do keep the snow off from it as well.
So 12" between is ok?
I'm hoping the wrap will work as well
2002 Roadster
K&N Air Filter
Borla Exhaust
Old 09-20-2020, 10:11pm   #15
Defib1961
Barn Stall Owner #23
Barn Raising I
Points: 60,695, Level: 100
Defib1961's Avatar
Gameroom Barn Bucks: $144580
Exodus 10 The Plague of Locusts (i.e. Yellow jackets)
Defib1961 is offline   Reply With Quote
Old 09-20-2020, 10:23pm   #16
Rodnok1
Activity: 52.2%
Rodnok1's Avatar
12 inch spacing will be fin IMO.... I wouldn't have gone closer either.
Didn't see the flashing at bottom, I just worry about moisture wicking up from the bottom, think ice dams when dealing with siding. Probably won't happen especially with flashing and looks like taped it off good. Does the flashing go under edge of osb to keep moisture off it, hard to tell from pic on my phone.
Old 09-21-2020, 7:48am   #17
thecornerman
Activity: 1.2%
Flashing was put on before the deck and is 2-4 inches below
2002 Roadster
K&N Air Filter
Borla Exhaust
Old 09-21-2020, 8:38am   #18
mrvette
Activity: 10.1%
mrvette's Avatar
Many years ago a buddy worked for the local fire dept, and he told me to never allow OSB on a job site, reason was that the local FD flagged all homes built with OSB because it's a FIRE HAZARD, burns hotter than hell and very rapidly, so they not going into a house so flagged unless proven human hazard......
now a daze maybe they changed the glue, but I just use plywood.....
Old 09-21-2020, 8:46am   #19
Points: 159,014, Level: 100
Activity: 23.0%
The Following User Says Thank You to Mike Mercury For This Useful Post:
