Old 01-24-2011, 12:39pm   #1
Bucwheat
Points: 49,877, Level: 100
Bucwheat's Avatar
Default gas smell
Hey guys,I have a problem that started when I last filled up, the shut off on the pump was broken and the gas over filled all over the fender,The next morning I smelled gas in the garage and thought maybe some was pooled up behind the fender,eventually it went away over the next few weeks,but now when I drive the car and say go to dinner or shopping when I return the cab smells like gas everytime,any ideas?
Old 01-24-2011, 2:07pm   #2
Just guessing here. What year is your car, maybe you have the cracked crossover tube thing they just recalled?
Old 01-24-2011, 3:23pm   #3
Bucwheat
Bucwheat's Avatar
A 1998,there is a recall?
Old 01-24-2011, 3:32pm   #4
Tulsa Vette Guy
Points: 4,253, Level: 44
Tulsa Vette Guy's Avatar
Gameroom Barn Bucks: $13
I agree, check out the crossover.
Old 01-24-2011, 4:48pm   #5
Bucwheat
Bucwheat's Avatar
How hard is the cross over to get to?
Old 01-24-2011, 5:34pm   #6
It's the fuel filter!!!!!
It's located up beside the frame. They leak and collect in the tank shield and then run to the ground.
Old 01-24-2011, 6:58pm   #7
2ez 2spd
Barn Stall Owner #44
Points: 8,371, Level: 63
Activity: 1.9%
2ez 2spd's Avatar
Gameroom Barn Bucks: $30044
I had this with my 97, 97 & 98 has the same fuel filter mine was leaking at the connector a o ring or something goes bad, mine was dripping on the exhaust.
Not sure why it would start this after the over fill if it is the fuel filter.
Old 01-25-2011, 2:52pm   #8
Bucwheat
Bucwheat's Avatar
That's the first thing i checked was the filter.The last time I changed it out one of the clamps worked it's way loose and I got it taken care of quick .I checked under the hood and it's dry as a bone,the only time I smell gas is right after I drive it then park it for a few.
Old 01-25-2011, 6:33pm   #9
Pull the left side inner fender. You'll be able to see the area around the gas fill. Get in there with some Simple Green and flush the area out. I still think you're dealing with residual odor from the gas fill over-flow and draining behind the fender.
Old 01-26-2011, 12:49pm   #10
Bucwheat
Bucwheat's Avatar
I'll let you guys know what I find .
Old 02-18-2011, 1:52pm   #11
Bucwheat
Bucwheat's Avatar
Well it turned out to be a crack in the fuel line about 18" up from the fuel filter on the frame. good news if this is all it was. Better than 2400 bucks for a gas tank removal for a connector pipe change.
Old 02-18-2011, 7:49pm   #12
Eagleeye
Points: 10,779, Level: 71
Eagleeye's Avatar
Gameroom Barn Bucks: $2288
Lucky you caught it !
Old 02-22-2011, 9:26am   #13
Bucwheat
Bucwheat's Avatar
I'm glad the fuel line don't run over exhaust pipes for sure.
