Old 10-11-2009, 8:40am   #1
Default Wiper udder cleaning
If you're having trouble with your wipers acting up, having a mind of their own, coming on by themselves, won't seat properly, continue running when you turn them off.....then more than likely you have moisture in your wiper motor. This is caused by the drain udders getting clogged and letting water collect around the wiper motor. When this happens, moisture seeps into the casing and shorts the circuit board.
You can access the udders from the inner fender well covers. Simple enough to do. Remove the wheels, remove the 7mm screws, pull the liner down enough to get your arm in there.
Look inside the fender and you'll see three rubber sleeves(udders) with slit openings at the bottom of them, hanging from the cowel area.
Clean out these sleeves. This is where all the crud accumulates causing them to back up and retain water.
Keep these clean and you're wipers should be trouble free for many years.
Old 10-11-2009, 8:45am   #2
Those udders are much larger than I expected! Just sayin.
Great tip by the way.
Old 10-11-2009, 11:25am   #3
And they can hold a lot of crud. Stuff you never would have thought would be in there.
Old 10-11-2009, 12:08pm   #4
thegreenman
Points: 15,494, Level: 85
thegreenman's Avatar
I have wipers on my Vette??? I am heading to the garage to check.
Old 10-11-2009, 1:17pm   #5
PortDawg
Charter Member - C3 Mod
Barn Stall Owner #34
NCM Supporter '15
Points: 30,980, Level: 100
PortDawg's Avatar
Gameroom Barn Bucks: $173
Crazy amounts of junk..stuff you don't remember hitting the car...
Old 10-11-2009, 4:45pm   #6
Unless your name is Shagster, I'm betting you do.
Old 10-12-2009, 2:15pm   #7
[email protected]
Charter Member - Vendor
Points: 2,960, Level: 35
JW@JWMotoring.com's Avatar
Gameroom Barn Bucks: $590
I clipped the ends of mine last year. I never have to worry about that junk piling up again.
JW@JWMotoring.com is offline   Reply With Quote
Old 10-12-2009, 2:22pm   #8
I actually siliconed pieces of PVC pipe inside mine to keep them straight and open. Then I snipped the ends off.
Old 10-12-2009, 6:18pm   #9
Dougzilla
Points: 3,777, Level: 40
Dougzilla's Avatar
Gameroom Barn Bucks: $27
Great tip !
Dougzilla is offline   Reply With Quote
Old 10-13-2009, 2:14pm   #10
DropTheTop
Barn Stall Owner #777
Points: 22,113, Level: 100
DropTheTop's Avatar
Gameroom Barn Bucks: $6589249
Thanks for the tip.
Old 10-14-2009, 2:32pm   #11
Culookin
Points: 5,156, Level: 49
Culookin's Avatar
Gameroom Barn Bucks: $802
Originally Posted by DropTheTop View Post
Thanks for the tip.
x2
Culookin is offline   Reply With Quote
Old 10-16-2009, 5:47pm   #12
Bill Curlee
Points: 1,839, Level: 26
Bill Curlee's Avatar
If your interested,,,,,,,,,,,,,,they look just like this!!
Heres what was in mine. YUM!!
BC
Bill Curlee is offline   Reply With Quote
Old 10-16-2009, 6:06pm   #13
Thanks for the pics Bill. You're always a great help.
Matter of fact. I think you should be the tech mod.
