12-05-2016, 6:23pm | #1 | ||||||
Barn Stall Owner #1269
Gameroom Barn Bucks: $232471
Update on the ATI 45..
I went to the range today and shot 200 rounds threw this ATI 45 made in the Philippines and the report is pretty bad. From the 200 rounds I shot about 170 were failure to feed rounds that I had to constantly slam the slide forward. At times if I shot fast all the rounds would feed but when I tried to double tap or single shot the failure to feed occurred. I have ordered from Brownells a colt defender spring and spring guide assembly and two kimber magazines. I am also in the process of polishing the ramp that leads the round to the barrel although I believe that is not the issue. I also ordered an extractor because the brass kept bouncing off my forehead and top of my head the extractor head appears to me to be too short.
On the good side when it shot rite it was great not a lot of kick because the weight of the gun and it was pretty accurate. If these adjustments fix the aforementioned issues I'll be into this thing about 370.00 more or less which is still good. |
The Following 2 Users Say Thank You to NCC-1701 For This Useful Post: |
12-05-2016, 6:25pm | #2 | ||||||
Barn Stall Owner #2112
Gameroom Barn Bucks: $3043611
Damn! No QC, hu?
12-05-2016, 6:25pm | #3 | ||||||
i was just looking at the Wilson Combat 1911 Classic - $3,030
that may wait a bit. |
12-05-2016, 6:33pm | #4 | ||||||
You covered the bases that I would have thought.
The only difference that I can see with a rapid fire is that things are heating up, perhaps causing a little expansion in key area's and allowing more freedom to the slide. |
12-05-2016, 6:34pm | #5 | ||||||
I take it that the round is almost seating, instead of stovepiping?
12-05-2016, 6:39pm | #6 | ||||||
Barn Stall Owner #49
Gameroom Barn Bucks: $1025197
170 out of 200 fail? Not too bad.... 15% success rate is an Obama Admin celebration!!!!!
If you're ever in a bad place with that gun, hopefully the perp will wait until the percentage turns in your favor! If not, it's heavy enough to smash his head in! |
12-05-2016, 6:47pm | #7 | ||||||
12-05-2016, 6:47pm | #8 | ||||||
The Following User Says Thank You to NCC-1701 For This Useful Post: |
12-05-2016, 6:49pm | #9 | ||||||
12-05-2016, 6:51pm | #10 | ||||||
Barn Stall Owner #69
Gameroom Barn Bucks: $1084134
Check your mags. They are an issue in many 1911's.
The Following 6 Users Say Thank You to VITE1 For This Useful Post: |
12-05-2016, 6:54pm | #11 | ||||||
for 45acp, factory ammo will run you about $370/1000. i can go thru 300-400 rounds in a practice session. do that once a month in warm weather, and your ammo costs quickly exceed the cost of the gun. may as well get something you like that you can afford.
12-05-2016, 7:23pm | #12 | ||||||
Barn Stall Owner #17
Sorry to hear it is giving you a hard time.
I'm also sorry I laughed when I read the above; I couldn't help it. Not that it's ever happened to me.... Scott
12-05-2016, 7:32pm | #13 | ||||||
Serves you right for not buying American.
12-05-2016, 7:51pm | #14 | ||||||
I'm willing to bet it's the Magazines. Try Chip McCormick or Wilson's and I'll bet the problem goes away.
Also, what ammo were you using? |
12-05-2016, 8:06pm | #15 | |||||||
I agree with the ammo brand, that can make a difference. Do the mags work fine in another weapon, or are they specific to this weapon? |
The Following 2 Users Say Thank You to OddBall For This Useful Post: |
12-05-2016, 8:20pm | #16 | |||||||
I know his is an ATI, but I would be willing to bet it's made in the same factory as the Rock Islands/Citadel's etc. If it's any consolation, my Colt Commander was a jam-o-matic until I put around 500 rounds through it...When I was trying to figure out what the problem was, I took it to a very well regarded Gunsmith and he was perplexed, he just told me to keep shooting it. So I did, and it's fine now. Weird. |
12-05-2016, 8:30pm | #17 | |||||||
As Chinaski wrote, sometimes simply breaking in a weapon smooths everything out. |
12-05-2016, 8:43pm | #18 | ||||||||
I've had shitty mags too, and you're right, sometimes just breaking them in does the trick. What confounds me is that the round is making it out of the mag, and I'm assuming making it most of the way into the chamber. At that point is the issue still the mag? It could be, as you suggested the timing could be skewed. Also, it could be a combo of things as well. I still keep coming back to it cycling ok during rapid fire. That still tells me that there is a lot of heat still in the weapon, expanding things just enough to allow freer movement 'twixt the parts. Maybe some more polishing is needed? Hell it could be the bullets aren't seated in the brass properly, or too little headspace in the chamber. |
12-05-2016, 8:44pm | #19 | |||||||
Barn Stall Owner #45
Gameroom Barn Bucks: $1021454
12-05-2016, 8:49pm | #20 | |||||||
