Old 02-08-2011, 8:34am   #1
NEVRL8T
Barn Stall Owner #25
Points: 27,763, Level: 100
Activity: 0.5%
NEVRL8T's Avatar
Default Alternator help
I replaced the alternator on my 2002 Chevy Silverado Z71 5.3 1500 p/u. Now my lights (exterior and interior) flicker or surge at idle. Everything looks to be in order. I replaced it with a 105 amp alternator which should be correct. Any ideas?
NEVRL8T is offline   Reply With Quote
Old 02-08-2011, 9:04am   #2
03SlowZ06
Points: 3,068, Level: 36
03SlowZ06's Avatar
Gameroom Barn Bucks: $100431
Higher output alt. No joke. They do it slightly from the factory and if you have the electronics package it is worse. I would go 120 amp. I think it may be a 120 stock actually.
The Following User Says Thank You to 03SlowZ06 For This Useful Post:
Old 02-08-2011, 5:16pm   #3
Points: 35,032, Level: 100
Check the tightness/cleanliness of the battery terminals, and have the battery tested too.
The positive terminal on my 04 Silverado loves to gradually work it's way slightly loose about twice a year, and the dash lights flickering is always my first clue it's happened again.
It never "seems" loose, never not starts, and usually only takes ~1/4 turn to make it fully tight again, but each time I've retightened it has 100% eliminated the dimming dash lights issue.
Never once had this problem with the side battery connections loosening on the Vette, but it's gotten me about 5 times on the truck over the years.
Old 02-10-2011, 5:04pm   #4
F40
Barn Stall Owner #17
Points: 4,521, Level: 45
F40's Avatar
Gameroom Barn Bucks: $2311
I think they don't even make any power at low Idle. I would put a volt meter on it to see where it starts to charge.
F40 is offline   Reply With Quote
