03-14-2016, 3:21pm | #1 | ||||||
VB Dad of the Year
[vid] Help me diagnose problem in my Vette.
A new noise has started, but it's not 100%. In the video, fast forward to 1:40 and you'll hear the noise kick in. It goes away at 2:20 when I come to a stop and make the u-turn, the noise goes away.
The noise is clearly very near the wheel, and because it's not all the time, and not a MAJOR grinding, I don't think it's the differential, as I know what that's like from it going out in the Z06. Having said that, I CAN feel a vibration in my butt-o-meter. My best guess is the bearing / hub assembly has gone bad. Thoughts? TIA. |
03-14-2016, 3:28pm | #2 | ||||||
Are your sway bars tight? And are they the adjustable links attaching them?
This is my signature |
03-14-2016, 3:33pm | #3 | ||||||
VB Dad of the Year
Stock Z06 swaybar, and it's tight.
03-14-2016, 3:52pm | #4 | ||||||
Gameroom Barn Bucks: $1005893
CV joint...............grease gone?
could be hub bearings too TPMS working ok? How many miles Have to lift and yank to know |
03-14-2016, 4:03pm | #5 | |||||||
VB Dad of the Year
85K+ miles. both dust boots on the axle are in tact, no cracks or leaks, so the joints in the axle should be fine. Guess I'll have to do trial and error. Will replace both rear hubs, since they aren't too expensive. I've replaced them on my Z06, I can't remember if I've done them on the C6. I did them on my neighbor's C6 for sure. |
03-14-2016, 4:06pm | #6 | ||||||
Gameroom Barn Bucks: $11051621
If you think its a bearing you should take off the wheel and inspect. That thing will lock up solid on you at an unpredetermined time, and you will end up replacing everything from the wheel on back because it will weld itself to the axel. And depending on how fast you are going when it decides to lock up you may be replacing a flatspoted tire as well.
Oh, Have you jumped any bridges lately? Could also be a bend half shaft from a hard landing. |
03-14-2016, 4:07pm | #7 | ||||||
Gameroom Barn Bucks: $313284
Could it be a brake pad rattling around in the caliper?
03-14-2016, 4:08pm | #8 | |||||||
VB Dad of the Year
I'll replace the bearings first and go from there. My daughter autocrossed this car for the entire 2015 season, and that's pretty rough on the bearings for sure. |
03-14-2016, 4:27pm | #9 | ||||||
03-14-2016, 4:36pm | #10 | ||||||
Barn Stall Owner #68
It doesn't sound like a bearing. It sounds like a caliper issue. If it was a bearing starting to go there may or may not be a lot of heat build up. Easy check to do though.
03-14-2016, 4:37pm | #11 | ||||||
VB Dad of the Year
I also thought caliper, and thought maybe there was some movement, but it doesn't appear to be the case. You think I should maybe change the brake pads out?
03-14-2016, 5:06pm | #12 | |||||||
Once you have the tire off. Look around for anything hanging in there. Anything loose. That was a very rhythmic, speed based sound going on. Almost like rocks in hub cap is the closest thing I could think of. |
03-14-2016, 5:18pm | #13 | ||||||
Barn Stall Owner #2112
Gameroom Barn Bucks: $3043611
Is there a hole in your foot?
03-14-2016, 5:54pm | #14 | ||||||
Barn Stall Owner #92
Bantayan Kids '13,'15
Gameroom Barn Bucks: $7534993
I'm guessing parking brake assembly. It's inside the rotor hat. If a retainer broke or if there is a lot of flexing it will make some weird noises.
The parking brake is like a giant C-shaped brake shoe, similar to the 63-82 Corvettes. The rear rotor has a deep hat that acts like a brake drum. If you have a sticky cable or something out of alignment, that will make noise. I have seen people cook bearings by setting the shoe too tight. |
The Following User Says Thank You to Fastguy For This Useful Post: |
03-14-2016, 6:13pm | #15 | |||||||
VB Dad of the Year
03-15-2016, 9:19am | #16 | ||||||
Barn Stall Owner #75
Gameroom Barn Bucks: $15302323
03-15-2016, 12:46pm | #17 | |||||||
03-15-2016, 4:21pm | #18 | ||||||
All will be revealed soon enough...........
03-15-2016, 8:34pm | #19 | ||||||
VB Dad of the Year
Leaving Thursday morning to race an Audi R8 in Georgia over the weekend, but now that I have a lift, it not only solves putting the monster engine in the race car, it makes fixing crap like this on the black C6 so much more tolerable. My gut tells me that the parking brake is the culprit. I'm pretty confident that Fastguy nailed it.
I've heard the noise from bad bearings and replaced them. I've heard the noise from a blown diff and replaced it. I've never heard "this" noise before, and it's only on the driver's side, but it's so far outside, close to the wheel, that his suggestion holds water. Won't know for awhile, as work is insane, and the lift won't be installed until Easter Sunday. I have the Tundra to drive daily, so the rush to solve it is reduced. |
03-15-2016, 11:42pm | #20 | ||||||
Gameroom Barn Bucks: $4614507
Almost sounded like the body or something rubbing against the half shafts sometimes. It's only intermittent, like somethings moving around once in a while???
