Old 07-03-2011, 11:07pm   #1
MattW
Barn Stall Owner #81
Points: 4,813, Level: 47
Activity: 19.1%
MattW's Avatar
Gameroom Barn Bucks: $5242
Default The Age-Old Question... High Volume or High Pressure?
If you had the opportunity to upgrade the oil pump on your LS1, would you (1) just use an OEM pump again; (2) Go with a high-volume pump or (3) go with a high-pressure pump?
Knowing the car will be mostly a sunny-day back-road car with maybe - MAYBE - one HPDE event a year?
MattW is offline   Reply With Quote
Old 07-11-2011, 10:21am   #2
simpleman68
Barn Stall Owner #17
NCM Supporter '12,'14,'15,'16,'17,'19
Points: 42,226, Level: 100
Activity: 6.5%
simpleman68's Avatar
High volume every day of the week.
The LSX motors don't seem to do well with higher pressures at all. I think they were built to run on lower pressure and at fairly high temps.
I've been running a 384 stroker for several years now at 11.6-1 compression with an LS6/LS2 oil pump (forget which) and on Summer days, I'll sit at 20 psi at idle.
I asked several reputable builders if that was an issue and they said not at all.
I know guys that run these in track events on hot Summer days and their oil temps will push near 300.
Scott
Vette-less but not without toys
simpleman68 is offline   Reply With Quote
The Following User Says Thank You to simpleman68 For This Useful Post:
Old 07-13-2011, 11:18pm   #3
slant
Banned
Points: 1,417, Level: 22
Activity: 60.3%
slant's Avatar
Gameroom Barn Bucks: $1507
volume , hands down
slant is offline   Reply With Quote
The Following User Says Thank You to slant For This Useful Post:
Old 07-26-2011, 8:46pm   #4
Eagleeye
Points: 10,779, Level: 71
Eagleeye's Avatar
Gameroom Barn Bucks: $2288
Stock or VOLUME...
