Old 02-11-2018, 2:52pm   #1
lspencer534
Dorkapottamus
Barn Stall Owner #52
Points: 200,076, Level: 100
Activity: 4.6%
lspencer534's Avatar
Gameroom Barn Bucks: $9339471
Default If you go North far enough...
eventually you'll be going South.
But if you go East, you can go East forever and you'll never start going West.
That is all.
Old 02-11-2018, 3:06pm   #2
NCC-1701
Barn Stall Owner #1269
Points: 47,901, Level: 100
NCC-1701's Avatar
Gameroom Barn Bucks: $232471
So if I travel NE will I eventually travel SW...
NCC-1701 is offline   Reply With Quote
Old 02-11-2018, 3:11pm   #3
Points: 223,344, Level: 100
Old 02-11-2018, 3:41pm   #4
69camfrk
Barn Stall Owner #6969
Points: 69,529, Level: 100
Activity: 6.1%
69camfrk's Avatar
Gameroom Barn Bucks: $1071547
Not sure how much Gin it took to come up with that thought....
69camfrk is offline   Reply With Quote
Old 02-11-2018, 3:50pm   #5
lspencer534
Dorkapottamus
Activity: 4.6%
More than two, less than ten.
The Following User Says Thank You to lspencer534 For This Useful Post:
Old 02-11-2018, 3:55pm   #6
Kerrmudgeon
Points: 152,726, Level: 100
Kerrmudgeon's Avatar
Gameroom Barn Bucks: $4614507
.....any more tidbits of wisdom councilor?
Kerrmudgeon is offline   Reply With Quote
Old 02-11-2018, 4:06pm   #7
Sea Six
Barn Stall Owner #16A
Barn Stall Owner #16B
NCM Supporter '11,'13
Points: 174,327, Level: 100
Activity: 1.4%
Sea Six's Avatar
Gameroom Barn Bucks: $602908
If you go straight down far enough, eventually you'll be going straight up.
Sea Six is offline   Reply With Quote
Old 02-11-2018, 4:35pm   #8
lspencer534
Dorkapottamus
Activity: 4.6%
You must not have heard: The World is flat.
Old 02-11-2018, 6:53pm   #9
DAB
Barn Stall Owner #4
Points: 172,146, Level: 100
Activity: 9.4%
DAB's Avatar
i've stood at the south pole, both the pretty ceremonial one and the actual one marked each new years day by surveyors from the USGS. and you stand there, somewhat cold, and no matter which way you look, it's all white snow and ice and it's north in all directions.
DAB is offline   Reply With Quote
Old 02-11-2018, 7:17pm   #10
OddBall
Points: 50,207, Level: 100
Activity: 36.0%
OddBall's Avatar
How far off is the actual from the ceremonial? Is it moving because the ice is moving, or is it a bit of axis wobble?
OddBall is offline   Reply With Quote
Old 02-11-2018, 7:27pm   #11
DAB
Barn Stall Owner #4
Activity: 9.4%
DAB's Avatar
the ceremonial is next to the runway, and pretty much stays put relative to the buildings and runway. the actual pole moves relative to the ice and buildings, because the ice is moving as a mass. it moves about 10 meters per year.
the year i was there was the first year (1994) they used GPS to locate the pole. previously, they had located it over the course of several days using sextants, and for the next 10 or so years, they knew how fast, and thus how far, the ice moved, and they knew the direction, so they would just measure out 10 meters in the proper direction and plant a new marker.
so i have a pic or me at the that pole, and you can see in the background the prior locations, and the GPS location was about 6 feet from the location using the old method that year (they measured and planted a marker both ways that year).
over time, the actual pole went thru one of the old buildings (pretty sure it's down now) and is moving away from the runway, so it is likely that it is not in an area not generally accessible to normal people, as it was headed to the old sewer waste pit area.
let me see if i can take a pic of my pic and post it.
brb.
The Following 2 Users Say Thank You to DAB For This Useful Post:
Old 02-11-2018, 7:40pm   #12
DAB
Barn Stall Owner #4
Activity: 9.4%
DAB's Avatar
here you go:
this is at the actual pole in 1994:
you can see other year's in the distance. the station is in front of me, behind the camera.
The Following 5 Users Say Thank You to DAB For This Useful Post:
Old 02-11-2018, 7:41pm   #13
DAB
Barn Stall Owner #4
Activity: 9.4%
DAB's Avatar
just behind the pole i have my hand on, is the other pole that year done by the old method. so about 6 feet of error over 10 years. that's pretty good accuracy.
Old 02-11-2018, 7:58pm   #14
MrPeabody
Points: 69,948, Level: 100
MrPeabody's Avatar
Gameroom Barn Bucks: $2214590
But if you go west, you will get to the far east.
MrPeabody is offline   Reply With Quote
Old 02-11-2018, 8:02pm   #15
JRD77VET
NCM Supporter '16,'17,'19,'20
Points: 116,118, Level: 100
Activity: 12.2%
JRD77VET's Avatar
here you go:
Very cool. Not too many folks can say they've been so far south that north was only direction to go.
Old 02-11-2018, 8:14pm   #16
DAB
Barn Stall Owner #4
Activity: 9.4%
DAB's Avatar
When I was there, they said fewer people had been to Pole than had been to the prior years Super Bowl.
Hard thing to do. Even when you are getting paid to do so.
Old 02-11-2018, 8:24pm   #17
Did you get dizzy from all the blood rushing to your head?
The Following 2 Users Say Thank You to Bill For This Useful Post:
