Go Back   The Vette Barn > C1 & C2 Corvette > C1 & C2 Corvette Open Discussion
C1 & C2 Corvette Open Discussion General and technical C1 & C2 Corvette discussion - ownership, maintenance, repairs, modifications, restoration
Old 08-01-2022, 11:51am   #1
Don Rickles
Mr. Warmth
Points: 36,986, Level: 100
Activity: 52.9%
Don Rickles's Avatar
Gameroom Barn Bucks: $2001216
Default '67 Wheel Bearing Seal Question
Posted over there but no replies.....
An after the fact question,......What direction is the correct way to install the inner front wheel bearing seal? Let me try to explain....The seal I removed from the rotor has its "rubber" centered in the metal ring, the aftermarket National Brand seal had the "rubber" offset in the metal ring. Should the rubber seal go in closer to the bearing or further from the bearing (which would ultimately sit further on the rotor lip). Does that make sense????
Don Rickles is offline   Reply With Quote
Old 08-01-2022, 1:58pm   #2
GTOguy
Points: 38,797, Level: 100
GTOguy's Avatar
Post a photo of the seal and I'll see if I can clear it up.
GTOguy is offline   Reply With Quote
Old 08-01-2022, 2:21pm   #3
Don Rickles
Mr. Warmth
Activity: 52.9%
This is how I chose to install it putting the so called rubber seal closer to the bearing. You can see the larger side of the metal part of the seal would be heading towards the engine compartment.
I am posting while driving please forgive me
Old 08-01-2022, 6:07pm   #4
GTOguy
GTOguy's Avatar
That's one of the original type single lip seals. The deeper side should be facing the bearing, but due to its design, it really doesn't matter and will function either way.
The Following User Says Thank You to GTOguy For This Useful Post:
Old 08-02-2022, 7:52am   #5
Don Rickles
Mr. Warmth
Activity: 52.9%
Take notice of the small bevel on the edge of the rubber. This what swayed me towards installing it this way. It slides onto the metal ring on the spindle....? IDK, I'm getting contradicting info now.....
Old 08-02-2022, 9:58am   #6
GTOguy
GTOguy's Avatar
I missed that! You have it installed correctly!!! Tapered side should always face the spindle/stub axle.
