Old 07-10-2019, 3:59pm   #1
DAB
Barn Stall Owner #4
Points: 172,146, Level: 100
Activity: 9.4%
DAB's Avatar
Default trailer harness wiring question
this gang has to know the answer:
have a 2013 chevy silverado 2500hd truck, it came with the Heavy Duty Trailer Wiring Harness Package, so I have an installed harness and electric brake controller on the lower dash board. the manual says it's all good to go...except that the wires for the Battery Feed (Red) and for the Trailer Brake (Dark Blue) are not connected to the fuse box, but the fuses are installed (page 9-96 of owner's manual).
i'm getting a trailer shortly, with electric brakes, and i need this mess to work properly first time out.
do i need to have the dealer do the final wiring connections, or is that something I could do? tried searching youtube, but didn't find any videos with this covered.
DAB is online now   Reply With Quote
Old 07-10-2019, 4:19pm   #2
Black94lt1
Barn Stall Owner #13
NCM Supporter '13,'14,'16,'17,'19,'20
Points: 24,895, Level: 100
Activity: 1.4%
Black94lt1's Avatar
Gameroom Barn Bucks: $425244
I'm no trailer expert and I did not stay at a Holiday Inn Express last night, so how about asking the trailer place
Black94lt1 is offline   Reply With Quote
Old 07-10-2019, 5:51pm   #3
MrPeabody
Points: 69,948, Level: 100
MrPeabody's Avatar
Gameroom Barn Bucks: $2214590
Yes, if you are buying the trailer from a dealer of any kind, make the sale contingent on them doing this for you.
MrPeabody is offline   Reply With Quote
Old 07-10-2019, 6:03pm   #4
DAB
Barn Stall Owner #4
Activity: 9.4%
DAB's Avatar
this is a question about the truck wiring. apparently, GM leaves 2 wires unconnected, so you later have to have them connect them for you.
Old 07-10-2019, 6:10pm   #5
MrPeabody
MrPeabody's Avatar
I know, but if the dealer you are buying it from has a service dept., they have the expertise to handle this for you. My dad bought several RV trailers over the years and every time he made the sale contingent on them doing all the necessary work on his truck, even a full hitch install one time. When I sold cars, once I sold a used Duramax one ton Dually and the guy made us pull all the fifth wheel stuff out of his trade and install it in the DMax at no charge. Dealers do what they have to do, within reason, to make a sale happen. Your issue is relatively minor.
The Following 2 Users Say Thank You to MrPeabody For This Useful Post:
Old 07-10-2019, 6:43pm   #6
JRD77VET
NCM Supporter '16,'17,'19,'20
Points: 116,118, Level: 100
Activity: 12.2%
JRD77VET's Avatar
My previous Suburban ( 2001 2500 with towing package ) had a plug to connect to the fuse box where the brake controller wiring was connected to.
Mine worked perfectly.
You could look at https://www.gm-trucks.com/forums/ , they have been helpful.
Old 07-10-2019, 6:58pm   #7
DAB
Barn Stall Owner #4
Activity: 9.4%
DAB's Avatar
i'm buying a water hauling trailer/tank combo from a place in TX. I want the truck to be ready to go when i go to pick up the trailer.
i'll check out the truck forum later (dinner time now). thanks.
The Following User Says Thank You to DAB For This Useful Post:
Old 07-10-2019, 7:00pm   #8
JRD77VET
Activity: 12.2%
JRD77VET's Avatar
What brake controller do you have? ( make and model)
Old 07-10-2019, 8:05pm   #9
snide
NCM Supporter '13
Points: 216,817, Level: 100
Activity: 53.6%
Reckon your truck was the last one down the line on Friday afternoon...
Old 07-10-2019, 8:19pm   #10
GRN ENVY
Barn Stall Owner #82
BR Car Washer II,III
NCM Supporter '11,'12,'13
Points: 35,028, Level: 100
Activity: 2.2%
GRN ENVY's Avatar
Gameroom Barn Bucks: $5504001
What kind of trailer harness do you have at the back. You should have a 4/5 pin and a 7 pin. Your 7 pin will have you standard, running, brake, L and R signals, and brake inputs. If there is an 8th pin it's for reverse. Most newer trucks have an option for factory brake controller. This could be why you have two wires with no connectors. You should be able follow those two empty wires to your 7 pin. You can wire in but it may not allow for your trailer to signal the brakes until an actual trailer is connected in the pin receiver in the bumper.
Hope this helps
GRN ENVY is offline   Reply With Quote
Old 07-10-2019, 8:37pm   #11
DAB
Barn Stall Owner #4
Activity: 9.4%
DAB's Avatar
Hope this helps
it's the factory brake controller. 7 pin. but the manual, as noted above, says 2 wires are run to the fuse box, but not connected.
Old 07-10-2019, 8:44pm   #12
GRN ENVY
Activity: 2.2%
GRN ENVY's Avatar
https://www.etrailer.com/tv-install-...ado-90195.aspx
At the end of this video it shows needing to connect the wire in the fuse. The first half of the video doesn't seem to apply as youbhave a controller already. I believe you just need to get power to it.
Old 07-10-2019, 8:51pm   #13
GRN ENVY
Activity: 2.2%
GRN ENVY's Avatar
https://chevroletforum.com/forum/sil...y-55257/page2/
Found this too.
Old 07-10-2019, 8:53pm   #14
JRD77VET
Activity: 12.2%
JRD77VET's Avatar
That is the exact same video I found.
Old 07-11-2019, 4:34am   #15
Points: 35,030, Level: 100
Imagine the potential liability an automaker would face supplying a vehicle optioned out for towing, with a factory-installed brake controller *but not connected to power*, with only a brief mention of that rather critical detail buried in the owner's manual.
This thread seems to confirm that suspicion:
https://www.silveradosierra.com/towi...on-t53137.html
I'm willing to bet you're already good to go. But even if not, unless you're hauling it back from TX full of water, I can't imagine the empty weight of the trailer being significant enough to need trailer braking for that trip anyways.
Like towing an empty car hauler, you'll basically need to dial the braking down to zero to not watch the trailer tires lock up and go up in smoke every time you tap the brakes.
The Following 2 Users Say Thank You to Y2Kvert4me For This Useful Post:
Old 07-11-2019, 7:52am   #16
DAB
Barn Stall Owner #4
Activity: 9.4%
DAB's Avatar
I’ll test the circuits today with a multimeter
Old 07-11-2019, 10:11am   #17
Points: 223,526, Level: 100
I agree. Perhaps the two unattached wires are for some specific thing, like providing charging for a breakaway battery or for full time power for a RV.
I bet the trailer lights and brakes work right now as is.
Bill is online now   Reply With Quote
Old 07-11-2019, 11:09am   #18
Points: 158,920, Level: 100
Activity: 27.0%
Old 07-11-2019, 12:04pm   #19
erickpl
Points: 14,817, Level: 83
Activity: 2.2%
erickpl's Avatar
Gameroom Barn Bucks: $111433
I had a 2005 Avalanche and when I added an aftermarket module, it just plugged into a spot on the panel below the dash. Plug and go. Everything worked, including the electric brakes.
Not sure how a factory controller would be LESS plug and play... but I bet it is already working.
Hope it all works for ya.
erickpl is offline   Reply With Quote
The Following User Says Thank You to erickpl For This Useful Post:
Old 07-11-2019, 12:23pm   #20
Here's another thread that suggests the unconnected wires mentioned in the manual lead to the under-dash pigtail meant to connect to an aftermarket brake controller.
With the OE controller, any reasonable person would expect it to be functional as delivered. If that's not the case, I wouldn't hesitate in raising hell with the dealer and for damn sure wouldn't pay anything for them to make it operational. You already paid for that option when you bought the truck.
