Go Back   The Vette Barn > C1 & C2 Corvette > C1 & C2 Corvette Open Discussion
C1 & C2 Corvette Open Discussion General and technical C1 & C2 Corvette discussion - ownership, maintenance, repairs, modifications, restoration
Old 08-13-2023, 3:54pm   #1
Dreaming 60's
Points: 340, Level: 6
Activity: 1.6%
Dreaming 60's's Avatar
Default C2 Door Adjustment
New to the forum and I have a new to me 66 Coupe that need the doors adjusted. Former owner(s) just used the striker to hold the door in correct alignment and you had to close them harder than I think you should. This might be a straight forward simple project, but I don't want to open a Pandoras box, thinking it's simpler than it is.
I have an AIM and maintenance books, but I would still like to hear some comments from those who've done it and any photos taken while accomplishing this (inside the door) would be icing on the cake. I won't mind, talk to me like a 6 year old.
Dreaming 60's is offline   Reply With Quote
Old 08-13-2023, 4:37pm   #2
roadpilot
Barn Stall Owner #121
Points: 2,440, Level: 31
Activity: 11.5%
roadpilot's Avatar
For complete instructions on your door adjustment, and stricker adjustment
buy Body by Fisher 1966 Service Manuel. You can find this manuel on
Ebay. Good luck
roadpilot is offline   Reply With Quote
Old 08-13-2023, 5:10pm   #3
Yadkin
Points: 47,134, Level: 100
Yadkin's Avatar
I believe the C2 is the same chassis as the C3, so the procedure should be similar. When I did my C3 I had the door mostly open, supported by a floor jack on the far edge and a rope tied to the ceiling to keep it from leaning over. Then I removed one hinge, installed new bushings, reinstalled then did the second hinge. Final adjustment was using the jack to raise in small increments.
Yadkin is offline   Reply With Quote
Old 08-13-2023, 7:34pm   #4
RatDog
Barn Stall Owner #114
Points: 2,202, Level: 30
RatDog's Avatar
That’s brilliant! I’m blown away.
I may do my ‘67’s doors just to try out that technique even though my doors are fine.
Take care,
Steve
RatDog is offline   Reply With Quote
The Following User Says Thank You to RatDog For This Useful Post:
Old 08-14-2023, 8:04am   #5
Dreaming 60's
Activity: 1.6%
Luckily I don't need new hinge bushing or pins, just adjustment of the existing hinges inside the door..............so I've been told.
Old 08-14-2023, 9:37am   #6
Yadkin
Yadkin's Avatar
The bushings are cheap and easy to replace. I'd be surprised if the old ones aren't worn out.
Old 08-14-2023, 12:06pm   #7
Dreaming 60's
Activity: 1.6%
I just use the old trick from the 60's when looking to buy another car. You open and lift the door up from the outer end. If you can rock/lift the side of the car up and down, without any play, your hinges and bushings are most likely good. Not scientific but is worked well for the 50's and 60's Chevys (metal bodies) I bought in the 60's.
Old 08-14-2023, 3:28pm   #8
roadpilot
Activity: 11.5%
roadpilot's Avatar
I agree, but we were not buying 50 and 60 year old cars back then.
Old 08-15-2023, 8:28am   #9
Dreaming 60's
Activity: 1.6%
Nod
Yeah, but the hinges are the same and if they're worn out or showing wear this test should still be valid.
The Following User Says Thank You to Dreaming 60's For This Useful Post:
