08-30-2019, 10:18am | #1 | ||||||
Barn Stall Owner #93
TeleBeast from the depths of Mordor build thread
Hoo boy. Let me start by saying I’m not a guitar collector. I have exactly three guitars - two custom made Strats and a one owner (me) 75 Les Paul.
I want a Telecaster with a fast neck and some noiseless, vintage sounding pickups. But I don’t want an off the shelf Tele - for less money I can assemble one that is better than what I can get from the Fender custom shop. So I’ll buy unfinished components, do my own lacquer finish in butterscotch and get high end hardware. This will be the build thread. Out of the gate I just heard from Fishman. They are cutting me an endorser price on a very cool active electronics that were really expensive. Super company and amazing products. Next I’ll order up the body. Can’t do the neck right now need to space out the cash outlays. I’m going with roasted swamp ash and I’ll spray organic nitrocellulose lacquer like they did in the old days using Leo Fenders paint recipe. The neck will be unfinished so while I’m saving my allowance I’ll work on getting it finished and assembled. I need to decide which neck profile and fret wire - not sure. Warmoth Guitars has a zillion options on custom bodies and necks. Body is straight fifties Telecaster. Neck is vintage/modern featuring a compound radius. That means the fret board is rounder at the headstock and flatter closer to the body. Cut from a cone instead of a cylinder. I also need to order lacquer and get it out sitting in the sun in a clear jar for a few weeks. That will yellow it to an amber color. Or explode and burn my house down. Not sure which. |
08-30-2019, 10:22am | #2 | ||||||
Pics of wife? Oh, wrong forum. Carry on.
08-30-2019, 11:14am | #3 | ||||||
Gameroom Barn Bucks: $7601
What happened to the Enterprise build? Is that played out?
08-30-2019, 11:26am | #4 | ||||||
Friend of mine, who is a very good player, just built a Stratocaster. He bought a one piece swamp ash body, sent it back East somewhre to have it painted in 2 or 3 tone Sunburst with a nitrocellulose lacquer. He had a Fender neck laying around, and had a luthier do it up the way he likes them. Pickups? Can't remember what he did, but they are apparently really good.
Guitar looks, and sounds amazing. |
08-30-2019, 1:37pm | #5 | ||||||
Barn Stall Owner #79
Gameroom Barn Bucks: $955
08-30-2019, 1:44pm | #6 | ||||||
08-30-2019, 4:20pm | #7 | ||||||
Unless you are dead set on replicating the exact brittle, easily scratched and difficult to repair nitrocellulose you might consider these two finishes.
Boiled Linseed Oil... a natural product which is naturally amber and is applied by rubbing it into raw wood with your fingertips. Slow to dry it might take several weeks to achieve a fully grain filled, soft glowing finish which is easily repaired simply by reapplication of the oil. Birchwood Casey Tru Oil gunstock finish... Also applied with the fingertips this one is less amber and dries overnight allowing many coats to be applied fairly quickly. This one will build into a high gloss, perfectly smooth finish if left untreated. It can be wet sanded and polished just like lacquer after full cure making maintenance possible. Get a big gouge/ simply sand flat and blend it in with your fingers. It can also be worked into a softer sheen using 4 aught steel wool and either a patinating or Butcher's wax as a lubricant. Easily refreshed or softened further with another application. You can also go matte or flat using various grades of rottenstone while still allowing the underlying grain to show in all its glory. A quick reapplication and you're back to glossy if you wish. Available at the"W" store and fine gunshops everywhere. |
08-30-2019, 5:56pm | #8 | ||||||
Location: So far East in TN that I can see NC from my house.
Gameroom Barn Bucks: $424870
If you want a custom Tele, check out Lucky Dog Guitars. Located in East TN. All hand built, and absolutely beautiful. They're expensive but worth it.
Corvette: Anything else is just transportation. |
08-30-2019, 6:23pm | #9 | |||||||
The Following 2 Users Say Thank You to SnikPlosskin For This Useful Post: |
08-30-2019, 6:24pm | #10 | ||||||
I’ll be able to build one as good or better for a fraction of the price. Lucky Dog is awesome though. I also don’t want to wait six months.
08-30-2019, 6:26pm | #11 | ||||||
Oh no. Very much ongoing. I just lost a month from surgery where I was just too wasted to work on it. Starting up again this weekend. There is a puzzle going on with one of the circuits and I hate puzzles. It’s tedious and slow going at this stage but I should have that done within the month.
08-30-2019, 7:17pm | #12 | ||||||
looking forward to seeing your handiwork
08-30-2019, 10:47pm | #13 | ||||||
Not too much to do except fill sand fill sand fill sand spray sand spray sand buff buff buff buff. Solder. Screw together. Drop off at luthier to have set up by pro.
I think the challenge will be in reproducing that finish but aged. It’s a weird color sort of amber but browner. One thing I’ll do is use dark filler for the grain. Then it will pop from the white ash. Body is made of what they call swamp ash. It’s similar to baseball bats but a bit sponge-ey-er. Spongeyer. Yep. That’s it. |
08-31-2019, 7:56am | #14 | |||||||
I never understood the modern trend of buying new guitars that have been faux aged/weathered. Buy a fuggin guitar, play the shit out of it OR buy an actual used/vintage instrument that has gone through the natural process. |
08-31-2019, 10:39am | #15 | |||||||
I will likely spray a bit lighter in certain places to make the wear a bit more rapid. I don’t put much finish on fretboards and none on the back of the neck. |
08-31-2019, 10:47am | #16 | ||||||
I have an old American Standard Stratocaster that hasn’t seen daylight in 30 years. It’s never been played. I wonder how naturally aged it is.
The Following User Says Thank You to Nox For This Useful Post: |
08-31-2019, 10:49am | #17 | |||||||
Anyway, he said that he always looked for the guitars that were a bit beat up, as by his logic it meant they were "well favored" He compared it to looking inside a restaurant...if there are a lot of people inside, the food is probably good...if it's empty, not so much. |
08-31-2019, 3:57pm | #18 | ||||||
Probably not that much. Friend of mines dad has a late 50's Stratocaster that's been sitting under his bed since probably 1965. It's absolutely MINT. Still has the original receipt, hang tags etc. I'd imagine it's worth a small fortune.
08-31-2019, 4:06pm | #19 | ||||||
I got mine at a celebrity auction for the Make-A-Wish foundation back in the 80’s. The guitar wasn’t getting a whole lot of bids so I bid. Surprised when I won it. I’m not a guitar player. It came in a Fender hardcase. It’s been sitting in my closet ever since. I should go dust it off.
08-31-2019, 4:29pm | #20 | |||||||
