Old 04-26-2023, 9:45am   #1
Yadkin
Points: 47,134, Level: 100
Yadkin's Avatar
Default Manufacturing defect on my "Porch Makin'"
This diagram shows the rear sway bar, left side. There is a welded tab on the subframe that extends over the bar clamp (red circle). Thus the upper bolt passes through the tab, through the cast aluminum clamp, then threads into the subframe; making a very rigid "sandwich".
This seems to be a bit of overkill by the designer, but then again this is one of the best handling SUVs on the planet.
The car developed a rattle over time and I finally traced it to the tab on the passenger side. It was bent up and out of the way and was making intermittent contact, usually on low speed roads with rough pavement, and more so with four passengers.
My guess is that the tab didn't line up on the assembly line so the worker bent it out of the way and sent the vehicle down the line. Over time the rubber in the bar links and clamps deformed to where the parts started to make contact.
This was driving me nuts to the point where I brought it to the dealer in Asheville to diagnose. The mechanic thought it might be the bar links- the bent tab is nearly invisible even on a lift. I only found this when I was replacing the links, as the clamps have to be removed in order to do so.
Yadkin is offline   Reply With Quote
Old 04-26-2023, 10:54am   #2
MadInNc
Points: 195,342, Level: 100
Activity: 21.9%
MadInNc's Avatar
Porsche Forum 覧覧>
Bored Troll Forum. 覧覧->
MadInNc is online now   Reply With Quote
The Following User Says Thank You to MadInNc For This Useful Post:
Old 04-26-2023, 11:30am   #3
Aerovette
Barn Stall Owner #7734
Points: 106,583, Level: 100
Aerovette's Avatar
Originally Posted by MadInNc View Post
Porsche Forum 覧覧>
I'm a better Engineer than Porsche has Forum -------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------->
The Following User Says Thank You to Aerovette For This Useful Post:
Old 04-26-2023, 12:29pm   #4
Yadkin
Yadkin's Avatar
Old 05-09-2023, 1:03pm   #5
MadInNc
Activity: 21.9%
MadInNc's Avatar
Summary of Mackan quality
Old 05-09-2023, 3:30pm   #6
Points: 224,706, Level: 100
So, what was the outcome? Did the dealer fix it, or did OP fix it, or did OP just leave it in a bad area with the keys in it and the door open, then call the insurance company?
Old 05-09-2023, 4:47pm   #7
Yadkin
Yadkin's Avatar
The dealer told me that it might be the bar links. When I replaced those I also disconnected the clamps, and when I did, found the defect. Bent the tab back into place, ran the bolts through and problem solved.
Copyright ゥ 2009 - 2024 The Vette Barn
