Old 05-25-2023, 12:40pm   #1
Olustee bus
Points: 39,853, Level: 100
Activity: 4.1%
Olustee bus's Avatar
Gameroom Barn Bucks: $1232517
Default I need to torque something 300 foot pounds. Very hard to find a wrench.
Anyone have any suggestions? I don't suppose a parts store will loan one like that.
What I am doing is putting new struts on my 2004 f150. I am figuring on buying an inexpensive air wrench, a heavy duty torque wrench, sockets. I gotta torque to 300 foot pounds. I don't want to spend near what I could get it done for.
Another thing, the last time I had mechanic work, they charged me about 30% higher for parts above what I could by at the store. Are mechanics charging above retail for parts.
Olustee bus is offline   Reply With Quote
Old 05-25-2023, 12:42pm   #2
PLRX
Points: 9,132, Level: 66
Activity: 32.9%
PLRX's Avatar
Rent it from an airport.
Old 05-25-2023, 12:49pm   #3
Steve_R
Points: 60,836, Level: 100
Activity: 82.9%
Steve_R's Avatar
All shops put a markup on parts, nothing new there.
Steve_R is offline   Reply With Quote
Old 05-25-2023, 12:52pm   #4
Rodnok1
Points: 31,373, Level: 100
Rodnok1's Avatar
Skip the inexpensive air impact, it'll never get you close.
Best bet is 1 inch drive socket set and a cheater bar. HF set has never failed me and I've used 6 ft bars on it. I did snap an extension tip off and it left a mark...
I have a beast of air impact and it won't goto 300 without some serious pressure and flow from a large compressor.
Anything over @200 will destroy most tools. A 300ft lb torque wrench should be 3/4 inch drive also.
Parts are always over retail when a shop charges you, we used to include recommended prices on invoices when sold them the parts.
Rodnok1 is online now   Reply With Quote
The Following 2 Users Say Thank You to Rodnok1 For This Useful Post:
Old 05-25-2023, 1:00pm   #5
ptindall
Points: 11,248, Level: 73
Activity: 11.8%
ptindall's Avatar
Gameroom Barn Bucks: $56446
Is this for the top nut or the bolts/nuts that hold the strut to the spindle? If the latter, just use a 2' breaker bar and tighten until you can stand on the end of the bar. If you wiegh 200 lbs and stand 6" inboard from the end of the breaker bar, you got 300 ft-lbs. If you only weight 150 lbs, you would have to stand right at the end. If its for the top nut, you can do the same thing by mounting it sideways in a vise. Hang from the breaker bar or whatever you need to do to get your bodyweight on it. 3/4" drive or 1" drive is not needed. 1/2" drive breaker bar and sockets can handle this no problem.
ptindall is offline   Reply With Quote
Old 05-25-2023, 1:01pm   #6
mrvette
Barn Stall Owner #101
Points: 115,169, Level: 100
Activity: 24.1%
mrvette's Avatar
No damn strut needs anything close to 300 ft lbs......think it's a combat tank or some aircraft or something maybe nuclear powered???
mrvette is online now   Reply With Quote
Old 05-25-2023, 1:01pm   #7
bill_daniels
Points: 176,116, Level: 100
Activity: 99.5%
bill_daniels's Avatar
Use a torque wrench that goes to 150, max it out, torque it, then do it again. 150+150=300
This is why it's impo'tant to know maffs.
bill_daniels is online now   Reply With Quote
The Following 7 Users Say Thank You to bill_daniels For This Useful Post:
Old 05-25-2023, 1:05pm   #8
Taurus
Points: 22,269, Level: 100
Taurus's Avatar
Gameroom Barn Bucks: $3895593
Mac had on while I was there, I think the part number was TWZ600 because it goes to 600lbs. Pretty pricey, if I remember right one of my distributors sold one to a local construction company for over $1K.
Taurus is online now   Reply With Quote
Old 05-25-2023, 1:10pm   #9
DJ_Critterus
Stall Owner #1120.2520
DJ_Critterus's Avatar
Yes... it's called LIST PRICE and they get the part at a discount below what you can get it for.
As for the torque problem, do like Porter would do. Torque everything to 150. Next reset your torque wrench to 0 then dial it back up to 150. Go over all bolts again. 150 + 150 = 300
There you go. Problem solved
DJ_Critterus is offline   Reply With Quote
The Following 4 Users Say Thank You to DJ_Critterus For This Useful Post:
Old 05-25-2023, 1:15pm   #10
Taurus
Taurus's Avatar
I retired in 2021 as the VP of Store Operations for a large national parts firm and yes they do. Much of it has to do with the pricing structure at the store. I would typically give the shop a 10% to 20% discount from list depending on the line. Most shops use a 50% mark up, do the math. The tariff war with China didn't help either with them slapping a 10% to 30% tariff on products out of China. Companies got scared and started protecting their margins.
Fortunately I still have my contacts at GM and ACDelco, they've helped me out on the vettes many times, especially in new old product.
Old 05-25-2023, 1:19pm   #11
Points: 142,521, Level: 100
Activity: 35.3%
Mike Mercury is online now   Reply With Quote
The Following 9 Users Say Thank You to Mike Mercury For This Useful Post:
Old 05-25-2023, 1:38pm   #12
GTOguy
Points: 18,711, Level: 94
Activity: 77.6%
GTOguy's Avatar
Jesus.350 foot pounds. Fucking Ford. They ought to be ashamed of themselves. When I was a tech, NOBODY had a 400 foot pound torque wrench. 250 was about the max. After that, things tended to break, stretch, and crystalize. And human limbs started to fail as well. What piss poor engineering.
GTOguy is offline   Reply With Quote
Old 05-25-2023, 1:42pm   #13
DAB
Barn Stall Owner #4
Points: 161,341, Level: 100
Activity: 51.2%
DAB's Avatar
18" breaker bar, 200 pound helper, done.
DAB is online now   Reply With Quote
The Following 2 Users Say Thank You to DAB For This Useful Post:
Old 05-25-2023, 2:21pm   #14
Yadkin
Points: 21,616, Level: 100
Activity: 99.9%
Yadkin's Avatar
It's not Ford but the market. Trucks are huge today. All those alphas gotta prove themselves. And IQs keep getting smaller.
To access the transmission drain on my Porsche (80k service), first remove a frame cross member. Five good size bolts. The spec to reinstall is something like 75#-ft, then turn an additional 3/4 turn. So a common torque wrench, mark the bolt, then uses a cheap breaker bar.
Reasonably sized vehicle, serviced with reasonably sized tools.
Yadkin is online now   Reply With Quote
Old 05-25-2023, 2:45pm   #15
PLRX
Activity: 32.9%
PLRX's Avatar
Originally Posted by mrvette View Post
No damn strut needs anything close to 300 ft lbs......think it's a combat tank or some aircraft or something maybe nuclear-powered???
When I posted, I saw 300 and told him to go to an airport. Now I read your post, and you are 100% correct. I searched and found this:
..and this:
https://ford-specs.com/cars/2004/f15...ecs_engine.php
YOU, OP, read it all wrong, it requires 222 lb-ft, but you read 300 NM
Name:  OP Thread Starter.jpg
The Following User Says Thank You to PLRX For This Useful Post:
Old 05-25-2023, 3:08pm   #16
GTOguy
Activity: 77.6%
GTOguy's Avatar
I'm seeing 351 foot pounds for the lower bolt on your illustration. Not 222.
What a bunch of crap.
The Following User Says Thank You to GTOguy For This Useful Post:
Old 05-25-2023, 3:19pm   #17
theandies
Points: 5,764, Level: 52
Activity: 12.9%
theandies's Avatar
I have a 200lb/foot one in my toolbox. Yes, the airport would be a good place. I worked on aircraft for a while and we had a 1500lb/foot to torque the cone mount bolt that mounts the jet engine to the pylon. Took two people to get it to click.
theandies is offline   Reply With Quote
Old 05-25-2023, 3:49pm   #18
ptindall
Activity: 11.8%
ptindall's Avatar
Um, #16 nut on #17 bolt?
Also, if this is the suspsension, that would make it a shock, not a strut.
Old 05-25-2023, 4:00pm   #19
Points: 109,569, Level: 100
Truck envy.
LATB is online now   Reply With Quote
The Following User Says Thank You to LATB For This Useful Post:
Old 05-25-2023, 4:03pm   #20
Datawiz
VB Dad of the Year
RDBM
Barn Stall Owner #9
Points: 113,230, Level: 100
Activity: 20.0%
Datawiz's Avatar
A 1/4" driver and socket should suffice.
Datawiz is offline   Reply With Quote
The Following 5 Users Say Thank You to Datawiz For This Useful Post:
