08-18-2019, 6:21pm | #21 | ||||||
Haven't heard of them yet. I would consider a FEG if I could find one reasonably as certain models are an exact copy and Browning or aftermarket Browning parts interchange. I will do some research though!
08-18-2019, 6:26pm | #22 | ||||||
M4s sell about $17-1800 new. I assume the deerslayer is an Ithaca model 37 with a smoothbore rifle sighted barrel? PM me some pictures if it is for sale please.
08-19-2019, 12:53pm | #23 | ||||||
road trip after lunch: the MVD (motor vehicle dept) weenies need to actually see and touch the trailer and verify the VIN so i can get permanent tags. sigh.
hook it up and drag it downtown. thankfully, there is a large gas station across the street that i can get in and out of easily, as their parking lot is way to small to try dragging a trailer into it. they said they'll walk a bit if needed. good, put on your hiking boots. |
08-19-2019, 2:57pm | #24 | ||||||
and....no tags today.
they didn't have any trailer tags in stock, and my paperwork was not complete (still need the proper title from Texas). try again next week when i should have the title. had fun parking it again. |
08-19-2019, 7:38pm | #25 | |||||||
Take your time and it'll be good. Are your mirrors wide enough to see to back up? |
08-19-2019, 9:30pm | #26 | ||||||
If you bought the trailer brand new, it should come with a MSO, a manufacturer's statement of origin, not a blue Texas title. I don't see why you didn't get the MSO when you paid for the trailer, since it was going out of state.
08-20-2019, 7:36am | #27 | ||||||
When you buy from a fly-by-night outfit, you don't always get the right paperwork.
08-20-2019, 10:47am | #28 | |||||||
Gameroom Barn Bucks: $111433
Or a couple WW2 era M1 Garands to go with the 2 in the safe. |
08-20-2019, 11:02am | #29 | ||||||
Gameroom Barn Bucks: $3632152
For a 1911, check out Fusion. Owned by Bob Serva.
08-20-2019, 11:19am | #30 | ||||||
big firm. state wide in TX. once i picked it up last friday, that began an automatic process to create my title on their end, and that should arrive to me later this week or early next week per a phone call yesterday. so i'll wait for that, and try this again (after i confirm they have the tags in stock).
08-20-2019, 1:26pm | #31 | ||||||
The Following User Says Thank You to erickpl For This Useful Post: |
08-20-2019, 9:39pm | #32 | ||||||
I got one of their entry level ones and the fit and quality is as good or better than some costing twice as much. The slide is like it's on butter and the trigger is very smooth. All of them have triggers between 3.5lbs and 5lbs, I believe.
08-21-2019, 9:21am | #33 | ||||||
08-24-2019, 6:50pm | #34 | ||||||
different ball set up today (5" drop, trailer sits more level now), and so i had to try parking it a few times. getting better at hitting my mark in less than 20 steps.
need to get a load of water tomorrow AM. will check the water meter and the dip stick at the tank to get readings on how much to get. |
The Following 4 Users Say Thank You to DAB For This Useful Post: |
08-25-2019, 12:19pm | #35 | ||||||
and now i find that parking backwards (truck facing down hill, towards the gate) makes the tank more level and results in better emptying of the tank. try that next time. got the trailer properly parked....after a few tries. sigh.
so we have water for the week. yay. |
The Following 5 Users Say Thank You to DAB For This Useful Post: |
08-25-2019, 6:44pm | #36 | ||||||
Getting better at backing up? Did you try my hand position on the steering wheel suggestion? Are your mirrors adjusted so you can see the trailer tires?
08-25-2019, 6:58pm | #37 | |||||||
the trick is, i have to back it into a turn out, that's about 60 degrees from the line of the main driveway. so the hard part is getting the turn correct, both when and how much, so it ends up somewhat centered in the space for it. i have a 6x6 pinned to the ground at the back, so i can see when i'm back far enough, and can have an idea if i'm centered L/R. the truck is at an angle to the trailer when the trailer is where i want it. mostly end up looking at the pax mirror, so i can see the tires relative to the 6x6. it's not a straight back up job. |
08-25-2019, 7:37pm | #38 | ||||||
Sounds simple enough. here's where we went fishing up in Ontario Canada. Tow vehicle was a Suburban and the pontoon boat is 24' long plus the trailer it sits on. Over trailer length of at least 30', maybe 32' with a width of 8'
The blue line is where we pulled in at. At the first "bend", we would stop and put up the hardtop and soft top. Continue pulling forward ( blue line ) and then back up ( red line) down to the water. That included going between the dock with a good size cedar and the boat garage. Clearance there was 9'-6" I had an "extra" 9" on each side. You can see the dock and the boat garage roof by the red arrow in the water. Mary would be on my right side being my "eyes" on the blind spots. |
08-25-2019, 7:49pm | #39 | ||||||
The Following 3 Users Say Thank You to Y2Kvert4me For This Useful Post: |
08-25-2019, 7:51pm | #40 | ||||||
