Old 02-11-2011, 10:41am   #1
khblair
Barn Stall Owner #57
Points: 22,234, Level: 100
khblair's Avatar
Location: The original point & click interface was a Smith & Wesson
Gameroom Barn Bucks: $8632322
Default What Mods do you have?
we need more c5 threads over here.
post up pics of your mods, from the DIY ones all the way to "i shipped it off and look what came back"
khblair is offline   Reply With Quote
Old 02-11-2011, 12:52pm   #2
Bucwheat
Points: 49,877, Level: 100
Bucwheat's Avatar
The last mod I did was the black wheels I bought from JWMOTORING seen in the avatar,the look,wifey hates it.
Old 02-12-2011, 11:34am   #3
Eagleeye
Points: 10,779, Level: 71
Eagleeye's Avatar
Gameroom Barn Bucks: $2288
Black Motorsport rims, Varam CAI, Bilstein shocks, ss X pipe, tint, tune, track alignment, all synthetic fluids, upgraded ign. wires, partition, sound deadening and lowered on stock bolts.
Old 02-12-2011, 2:54pm   #4
BarryBum
Points: 4,232, Level: 43
Activity: 1.1%
BarryBum's Avatar
Gameroom Barn Bucks: $650
Here is one of my entries........The gutter guard Cove Vent Trick. I Went to Home Depot and picked up a piece of the metal mesh gutter guard for $1.89
and a two part epoxy setup for $3.98.
Took the wheels off, loosened up the inner fender. Made a template out of cardboard then cut the gutter guard with a pair of tin snips.
Bent the mesh into the correct position, test fitted then painted it satin black. I used some type of double sided sticky stuff to hold the piece in place until I could get it epoxied. I used the 5 minute set up epoxy, so it set quick and hard in place. I think they turned out great.
BarryBum is offline   Reply With Quote
Old 02-12-2011, 2:56pm   #5
BarryBum
Activity: 1.1%
BarryBum's Avatar
Heres another one I did recently for less than $10. It lights up the area where most of us put the chrome cover for the fuel tank between the exhaust.
Here goes, hope you enjoy!!
Here is the lights as they come out of the pack
Take your tag off
Remove your back up plate assembly
Take out 1 of your tag lights
I ran a long zip tie down from the back plate down the bumper cover
Here you can see the bottom of the bumper cover where the long zip tie came out of the bottom of the cover
Pull the 51" long LED pigtail up to where the tag light is
Cut the wires going to the tag light, and using butt connectors splice the LED lights in line
Tidy the remaining wire up before buttoning everything up
Here is the LED's hanging getting ready to be installed
After wiping down the area for the LED's to be stuck, secure LED's by peeling the backing off and sticking in place
Finished job after only 30 minutes
Another finished shot
Products and equipment to be used for mod
The Following 3 Users Say Thank You to BarryBum For This Useful Post:
Old 02-12-2011, 8:23pm   #6
zz4vetteguy
Points: 19,739, Level: 97
zz4vetteguy's Avatar
Gameroom Barn Bucks: $9916
New Wheels 18 x 9.5 front, 19 x 11 rear
On the lift getting some long tubes installed
Thanks again Jeff <Shrek> for letting us play at your place that day!!!
The Following User Says Thank You to zz4vetteguy For This Useful Post:
Old 02-12-2011, 8:48pm   #7
Blue 92
Points: 5,506, Level: 50
Activity: 1.6%
Blue 92's Avatar
Gameroom Barn Bucks: $2161
2003 Convertible:
As it came to me:
Tinted windows
Blackout kit
Z06 suspension: shocks/springs/swaybars
Spec3+ clutch
Fidanza Alum flywheel
Z06 Wheels
Kumho MX tires
Stainless steel brake lines
Hawk HPS pads
TPIS headers
SLP Loudmouth mufflers
Vararam air intake
160 deg thermostat
Ported TB
MSD wires
Dyno tune
I added few more creature comforts:
HIDS
Hurst Shifter
Replaced floor mats
Replaced missing cargo compartment covers
Added rear cargo mat
Trunk popper
Trunk lid liner
Z06 FRC covers
Catch can
And Jake
Blue 92 is offline   Reply With Quote
Old 02-13-2011, 11:14am   #8
vafirevet
Points: 1,447, Level: 22
vafirevet's Avatar
Gameroom Barn Bucks: $785
Default My 01 Vert
Mods by me since May 2010:
1) Fixed OEM Head unit that was missing knob
2) Fixed non-locking door lock(Bakersfield method)
3) Replaced GY run flats with Bridgestone 050A run flats
4) New Lloyd c5 duel logo mats – Black/Millennium Yellow
5) Steering wheel decal- Millennium Yellow
6) Corsa Pace car Tiger tip exhaust with Corsa x-pipe
7) CCA Black Oil Catch Can
8) IPod/Iphone cable system with OEM head unit
9) Replaced 3.5" tweeters with JBL units
10) Vararam intake with Power Duct
11) Battery well cover made from CF template(Millennium Yellow)
12) Added yellow valve cover stripes and lettering under the hood
13) Zanio the entire car several times and many coats
14) Millennium Yellow center console pad added
15) Added a Window valet
16) Painted brake calipers gloss black
17) Replaced OEM rotors with slotted and drilled rotors and hawk pads
18) Replaced OEM gray lug nut covers with chrome covers
19) installed power antenna cut off switch
20) Tail light seals installed
21) Lowered the height all the way on stock bolts
22) Removed trunk C5 logo but had to buy a replacement to replace it
23) Va. Speed Tune
24) Racemesh Z06 black powder coated fog light/intake grilles added
25) Cleaned under hood liner with Amour All Tire Foam
26) CAGs skip shift added but later tuned out
27) Installed both types front license plate covers(a Millennium Yellow blank and a MY plate surround) Now I'm running with no front plate...
28) Replaced driver's side electrochromatic mirror glass
29) Black Fangs
30) CLB installed
31) Phantom C5 shift knob in leather with C5 logo
32) Added black pool ball shifter knob
33) Beltronics STI Driver Radar detector
34) Corvettemods radar detector mount
35) Smart power cords from the inside rearview mirror
36) Rocking seat fixed on driver’s side
37) Cut off 1” off stock C5 shifter height
38) Installed heated seats in both driver and passenger sides
39) Installed RPI yellow covers on radiator reservoir and windshield washer tank
40) Yellow C5 door decals on the door thresholds
41) New "YELOC5" Virginia license plate
[IMG][/IMG]
vafirevet is offline   Reply With Quote
Old 02-14-2011, 10:13am   #9
Bucwheat
Bucwheat's Avatar
Barry that looks pretty cool,been wanting to do something like that and now ya made me have to do it!
Old 02-14-2011, 3:09pm   #10
GB Vette
The Old Guy
Points: 62,624, Level: 100
Activity: 6.4%
GB Vette's Avatar
Gameroom Barn Bucks: $804566
I like my relocated gas filler
The Following 3 Users Say Thank You to GB Vette For This Useful Post:
Old 02-14-2011, 3:12pm   #11
khblair
khblair's Avatar
oh! you win originality. ive never seen that. very interesting. i think i like it
The Following User Says Thank You to khblair For This Useful Post:
Old 02-17-2011, 8:55am   #12
thkauffman
Barn Stall Owner #31
Points: 8,873, Level: 65
thkauffman's Avatar
Gameroom Barn Bucks: $73231
Crap! Were you also the one that did the fender flares on his own? If so, I remember those threads from CF. Man, that was nice work.
As for me, 2000 MY M6 coupe.
Halltech Stinger intake
Corsa Pace Car exhaust with Pro tips
Kook's Custom long tube headers
Still want to do skip-shift fix, shifter replacement and HID bulbs. Maybe lower it.
thkauffman is offline   Reply With Quote
Old 02-17-2011, 10:18am   #13
I'll play. The car has been kept understated and extremely mild even with 577 normally aspirated HP at the wheels and 530 RWT. Low end torque makes the car a dream to drive. It's entirely schizophrenic. Mild just driving around and violently quick when it's time to play.
Mods
Engine - By Virginia Speed
Darton Sleeved LS2 427
WCCH Stage 3 L92 heads
Custom Cam by Va Speed
Modified FAST 102
Nick Williams 107mm Throttle Body
Custom Fuel Rails and Aeromotive FP Regulator
Modified GMPP Valve Covers
Yella Terra Ultralight Rockers
Morel Link Bar Lifters
Hidden Coils
Custom 4 inch Downtube CAI Intake
DeWitts Radiator with Oil Cooler
ECS Front Cradle Assembly
All braided stainless steel hoses with AN fittings
Tuned by Ed Hutchings at VA Speed
Exhaust
American Racing 1 7/8 Long Tubes with Hi-Flow cats
LG Big 3 catback
DMH low profile electric cutouts
Drive Train
Spec 3+ Clutch with Aluminum Flywheel
Tick Master Cylinder
Z06 Torque Tube, M12 Transmission and Z06 differential with hardened shafts.
ECS Trans/Diff Brace
Tunnel Plate
Suspension
LG GT2 Coilovers
PFADT Street/Track Sway Bars
Custom Alignment
Brakes
Bear Plus 2 Eradispeed Rotors
Carbotech 1521 pads
Wheels
CCW SP500's 18x10 and 19x13
Michelin PS2's 275x35 and 345x30
Interior
Corbeau A4 Seats - all leather with lumbar support
Down South Vettes Custom Steering Wheel
Vette Essentials Console, Armrests, shifter and brake boot
Dual A Pillar Pod with WB AFR and Fuel Pressure Gauges
Lloyd Mats
30% Tint on sides and limo tint on the back window
Window Valet
CCA pedals
HVAC Neons by JW
Pillar mount WB AFR and Fule Pressure gauges
Sound System
Double Din Center Bezel
Kenwood 8140 Head Unit
JL 10w30 Sub in Stealth Box
JL ZR650 Csi in the doors - Tweeters behind door latches
Crossovers in glove box
JL HD600 amp
Dynamat
Body
MCM Carbon Fiber Hood
Tiger Shark Nose
ACS Rear Spoiler
ACP Side Skirts
Lewis Five Rear Quarters
Z06 Rear Brake Ducts
Tinted HALO LED Tail Lights
Clear Front Corners
Clear Rear Side Lights
PIAA 1100 Driving Lights
Robbins Top
Covered Lower Rear Facia
WOW! This is the first time I've actually written them down. I'm sure there are a bunch more but these are the ones I remember quickly.
Old 02-17-2011, 11:53am   #14
Lowcash
Points: 4,921, Level: 47
Lowcash's Avatar
Gameroom Barn Bucks: $2827
-Tint
-QTP cutouts
-1 3/4 American Racing headers
-Tunnel plate
-Corsa Exhaust
-Microsuede lower door panels, knee bolster, glove box
-black/tan sport seats -- from the 'barn'
-painted fuel rail covers
-Double Din setup (Double D Mods) + new speakers, tweeters and amp (note: need to stop BS'ing and ask WKMCD to help me finish the install one day)
-Pfadt Inverted shocks
-6 strobe light setup
-HID projection lamps (JW Motoring)
'I dropped the car off and they (GB) .... "
Shaved door handles and front and rear emblems
wetsanded/polished/buffed the car.
Old 02-18-2011, 6:31am   #15
Just let me know when you want to finish but you'd better hurry...coming into golf season.
Old 02-18-2011, 9:15am   #16
Lowcash
Lowcash's Avatar
Coming into golf season as my snowboarding season is winding down.
Old 02-26-2011, 8:06pm   #17
Burnt C6
Barn Stall Owner #56
Points: 18,831, Level: 94
Burnt C6's Avatar
Gameroom Barn Bucks: $6355194
RPM stage II 342 rearend
C6 Z06 suspension
C5 ZO6 Wheels
Vararam CDI
Corsa Indy's
HID lights all around
I had just got these seats from DJ motor sports on CF but traided the car in before I got them installed. C5 emblem with the Texas flag instead of the regular flag
I miss my car.
Burnt C6 is offline   Reply With Quote
Old 03-04-2011, 10:58am   #18
Toque
Points: 4,023, Level: 42
Toque's Avatar
Gameroom Barn Bucks: $1077
Too many to list here and too many pics.
See my web site...
Mark's 2004 Corvette Z06
Toque
Toque (Aka Z49 Z06)
Email : [email protected]
Web page: www.ToqueZ06.com
