Go Back   The Vette Barn > C7 Corvette > C7 Open Discussion
C7 Open Discussion General and technical C7 Corvette discussion - ownership, maintenance, repairs, modifications, tuning
Old 05-28-2013, 11:44am   #1
Will
Barn Stall Owner #15
Fantasy Football Champ '11,'13,'17
Points: 49,374, Level: 100
Will's Avatar
Location: Somewhere between mild insanity and complete psychosis.
Gameroom Barn Bucks: $1050381
Arrow 2014 Corvette LT1: 460 HP @ 6,000 RPM, 465 FT-LB @ 4,600 RPM
The 2014 Corvette Stingray’s all-new LT1 6.2L V-8 engine is SAE-certified at 460 horsepower (343 kW) at 6,000 rpm and 465 lb-ft of torque (630 Nm) at 4,600 rpm, with the available performance exhaust system, Chevrolet announced today.
The Stingray is SAE-certified at 455 horsepower (339 kW) and 460 lb-ft (624 Nm) with the standard exhaust system. They are the highest standard power ratings ever for the Corvette, delivered with efficiency that is expected to exceed 26 mpg on the highway.
“The 2014 Corvette Stingray’s LT1 engine is a triumph of advanced technology, delivering more power and torque than ever before with greater efficiency,” said Jordan Lee, Small Block chief engineer.
“The LT1’s performance complements the Corvette’s low mass with a tremendous feeling of power that builds as the rpm climbs. Drivers will experience more power and acceleration than ever before with the standard engine – in fact, its power and torque surpass many uplevel engines offered by competitors.”
At 74 horsepower per liter, the LT1 has greater power density than the C6 Corvette’s LS3 6.2L engine and even the C6 Z06’s racing-derived 7.0L LS7. It also produces comparable torque to the LS7 – up to 4,700 rpm – and its peak torque is within 5 lb-ft of the 7.0L engine. That torque is generated early and sustained across the rpm band, with 316 lb-ft available at only 1,000 rpm and 90 percent of peak torque available from 3,000 rpm to 5,500 rpm – giving the lightweight Corvette Stingray excellent acceleration at all speeds.
Chevrolet estimates the Corvette will run from 0 to 60 mph in less than four seconds.
Kerbeck Corvette: 2014 Corvette Stingray Cranks Out 460 Horsepower
. . . the LT1 . . . produces comparable torque to the LS7 – up to 4,700 rpm – and its peak torque is within 5 lb-ft of the 7.0L engine. That torque is generated early and sustained across the rpm band, with 316 lb-ft available at only 1,000 rpm and 90 percent of peak torque available from 3,000 rpm to 5,500 rpm . . .
FaceBook: will.bridges.16
GAB: @Will_Bridges
MeWe: willbridges1
Parler: @CarlosDanger
Twitter: @_Will_Bridges_
Will is offline   Reply With Quote
