02-06-2013, 5:51pm | #101 | ||||||
Gameroom Barn Bucks: $89945
02-06-2013, 6:22pm | #102 | ||||||
Barn Stall Owner #2112
Gameroom Barn Bucks: $3043611
02-06-2013, 6:33pm | #103 | ||||||
I appreciate that! Hopefully it'll be dry tomorrow. I miss my garage
02-07-2013, 4:40pm | #104 | ||||||
Got the pan off... starter broke in the process
I'm going out a limb, and I'm gonna say I'm pretty ****ed and I was trying to pick up the metal flakes, and dropped the magnet. all that crap has that metal in it. |
02-07-2013, 4:43pm | #105 | ||||||
Barn Stall Owner #17
Sorry about all that shrapnel That wreaks havoc on bearings among other things.
That little crate motor you were talking about sounds like a good option. Hard to beat a good build backed by a warranty. I've had plenty of shoddy work come back from "good shops". Heads that were incorrectly milled, damaged cam lobes and incorrect sizes on everything from pistons and rings. Scott
02-07-2013, 5:01pm | #106 | ||||||
how do I pull the shield that sits ext to the oil pump? I removed all the nuts, and pulled the oil pump, but I cannot get that stupid plate of. there is metal hanging off the side of the #7 and I want to pull off the bearing. but I can;t get it with that plate in the way
02-07-2013, 5:03pm | #107 | |||||||
Barn Stall Owner #0
Gameroom Barn Bucks: $1576624
Is it the windage tray? Picture? |
02-07-2013, 5:09pm | #108 | ||||||
02-07-2013, 5:19pm | #109 | ||||||
Gameroom Barn Bucks: $612110
It will come, you need to fight with it a little.
02-07-2013, 5:22pm | #110 | ||||||
Barn Stall Owner #0
windage tray, it stops the crank from churning up the oil.
It should pull right off once the nuts are removed. If you are going with a new short or long block, you can FUBAR the tray, your new engine will come with a new tray. |
02-07-2013, 5:57pm | #111 | ||||||
yes... I was able to remove it. with sheer anger.
02-07-2013, 6:02pm | #112 | ||||||
and this is my issue
its better without sound) |
02-07-2013, 6:05pm | #113 | ||||||
it's hard to see in the pic the it's all eaten up and here's why: Bearing for #8 and #7 |
02-07-2013, 6:10pm | #114 | ||||||
02-07-2013, 6:19pm | #115 | ||||||
RIP
02-07-2013, 6:25pm | #116 | ||||||
Barn Stall Owner #1962
Gameroom Barn Bucks: $251407
That sucks.
02-07-2013, 6:34pm | #117 | ||||||
Barn Stall Owner #113
Gameroom Barn Bucks: $306898
At least you didn't buy more parts for it yet.
02-07-2013, 6:38pm | #118 | ||||||
Gameroom Barn Bucks: $100015
Yep, spun bearing. You can bet the pieces from it has gotten to every rod & main journal too so I would say there is no need for further disassembly. The crank is probably too far gone to be turned and all the rods would need to be resized, then with that many miles it may need to have a bore cleanup of .030 which means new pistons. It's all your decision now, brand new or good used. If you plan on keeping the car a long time then a new engine would probably be your best option. If you don't plan on keeping it then a good used would be my choice. I wish you luck.
02-07-2013, 6:53pm | #119 | ||||||
Gameroom Barn Bucks: $188
02-07-2013, 6:56pm | #120 | ||||||
Gameroom Barn Bucks: $2173478
Sorry man, that sucks.
