Old 08-27-2019, 9:09pm   #1
carlton_fritz
Barn Stall Owner #1991
Points: 74,431, Level: 100
Activity: 2.9%
carlton_fritz's Avatar
Default Which computer genius wants to help me tonight?
Trying to get a new build using my old SSD that has Win 10 on it. New build doesn't recognize the SSD. I cannot change anything in BIOS either. I tried loading Windows 7 from the DVD drive, but the keyboard quits working when I try that.
carlton_fritz is offline   Reply With Quote
Old 08-27-2019, 9:16pm   #2
snide
NCM Supporter '13
Points: 216,817, Level: 100
Activity: 53.6%
Here you go.
Old 08-27-2019, 9:31pm   #3
JRD77VET
NCM Supporter '16,'17,'19,'20
Points: 115,957, Level: 100
Activity: 13.3%
JRD77VET's Avatar
Originally Posted by snide View Post
Here you go.
The Following 4 Users Say Thank You to JRD77VET For This Useful Post:
Old 08-27-2019, 9:39pm   #4
Wathen1955
Points: 46,943, Level: 100
Activity: 11.2%
Wathen1955's Avatar
Gameroom Barn Bucks: $1524159
By chance, do you have any other drives connected?
Was the original SSD wiped before starting your new build?
Wathen1955 is offline   Reply With Quote
Old 08-27-2019, 9:44pm   #5
carlton_fritz
Activity: 2.9%
The SSD has all old info, including Win 10, on it. The other drives are a Seagate Back-Ups +, an M.s and a DVD drive. Currently trying to install Win 10 from disc, but not sure if it's working.
Old 08-27-2019, 9:55pm   #6
Wathen1955
Activity: 11.2%
Wathen1955's Avatar
Can you install 10 from a USB flash drive?
Have you tried different cables? I've had to replace them once when the drive was not recognized.
Old 08-27-2019, 9:57pm   #7
carlton_fritz
Activity: 2.9%
Is it the newer version of 10?
I don't have it on USB. The SSD Win 10 was the upgrade and updated version when I had Win 7.
Old 08-27-2019, 10:08pm   #8
carlton_fritz
Activity: 2.9%
Unhooked everything but the DVD and M.2. Installing Windows 10, maybe.
Old 08-27-2019, 10:27pm   #9
Wathen1955
Activity: 11.2%
Wathen1955's Avatar
The upgrade only works once on existing hardware. You need to get a new copy of 10 for new hardware. I would suggest getting the PRO version so you can delay updates; otherwise, you are at the mercy of MS and their questionable updates.
The Following User Says Thank You to Wathen1955 For This Useful Post:
Old 08-27-2019, 11:26pm   #10
carlton_fritz
Activity: 2.9%
It's late enough. I will finish fighting it after I get sleep.
Old 08-28-2019, 7:43am   #11
Points: 158,533, Level: 100
Activity: 30.2%
contact these guys:
The Following 2 Users Say Thank You to Mike Mercury For This Useful Post:
Old 09-02-2019, 11:04pm   #12
carlton_fritz
Activity: 2.9%
New CPU is running, but old SSD and internal HD not showing in the list of drives. Been spending a lot of time downloading pron, I mean mods for Skyrim.
Old 09-03-2019, 3:02am   #13
snide
NCM Supporter '13
Activity: 53.6%
SSDs don't last forever. It is possible that it shit the bed.
Old 09-03-2019, 8:26am   #14
Cybercowboy
2016 Election Expert
Barn Stall Owner #64
Points: 50,697, Level: 100
Activity: 34.6%
Cybercowboy's Avatar
Yeah, in my experience if a new computer doesn't recognize an old drive, and you've done the obvious like try a different cable and motherboard connector, the drive is either dead or incompatible somehow. But probably just dead. SSD's go from working to brick in a heartbeat, there is usually no warning. I'd just use the opportunity to get a bigger better new SSD.
Cybercowboy is offline   Reply With Quote
Old 09-03-2019, 10:55am   #15
carlton_fritz
Activity: 2.9%
What are the odds that the SSD died exactly as I changed out MB, CPU and RAM? The power was unplugged and the switch turned off when I did everything.
Old 09-03-2019, 12:23pm   #16
Cybercowboy
Activity: 34.6%
ESD damage most likely. You're shocked that you shocked it? Shocking.
I learned a long time ago that if you are working on computers and don't account for static electricity it will absolutely bite you in the ass. And it will bite you even if you take precautions sometimes.
The Following User Says Thank You to Cybercowboy For This Useful Post:
Old 09-03-2019, 12:26pm   #17
carlton_fritz
Activity: 2.9%
Done that before, but there was no sign of it this build. I deliberately tried to avoid it.
Old 09-03-2019, 1:28pm   #18
Points: 56,774, Level: 100
Activity: 47.1%
It's not unheard of.
I run a Linux machine as my Internet gateway. It normally runs 24/7, but at one point I had to power it down to swap out a cable modem. When I tried to power it back up it was completely dead.
The Following User Says Thank You to dvarapala For This Useful Post:
Old 09-03-2019, 10:44pm   #19
Wathen1955
Activity: 11.2%
Wathen1955's Avatar
I sent you a PM response. As others have said, it's possible it was DOA. It does happen, even with mechanical drives. My suggestion is to slave it with an adapter that you can hook up via USB on another pc.
