09-30-2011, 4:12pm | #1 | ||||||
Barn Stall Owner #23
Barn Raising I
Gameroom Barn Bucks: $144580
Seat issues
Anyone know how to replace the lever that reclines the driver's side seat? Do I need to pull the seat out to do it?
09-30-2011, 4:23pm | #2 | ||||||
Gameroom Barn Bucks: $980
Its easier if you do!
Underneath lever is a u clip you pull it out (i use a bent hanger) then handle slides off. Install is in reverse! Mario |
09-30-2011, 4:26pm | #3 | ||||||
Seat Back Recliner Handle Replacement - Front:
1) With a suitable blunt ended tool inserted between the cushion and the handle push the handle retaining spring clip down. 2) Pull the handle from the shaft. Installation Procedure: 1) Position the handle retaining spring clip into the lock position. 2) Snap the handle onto the reclining mechanism shaft. |
10-03-2011, 7:36am | #4 | ||||||
I believe if you slide the seat all the way forward and fold it down you can work on the handle if you can get ti to work enough to fold it forward.
10-08-2011, 8:19pm | #5 | ||||||
Barn Stall Owner #1000
Gameroom Barn Bucks: $2425793
We didn't take the seat out. We used a crochet hook.
10-09-2011, 9:14am | #6 | ||||||
Gameroom Barn Bucks: $13
Not a hard job,, I agree with the posts above!
10-11-2011, 7:59am | #7 | ||||||
