Old 01-09-2012, 7:04am   #1
Shrek
Points: 14,057, Level: 81
Shrek's Avatar
Gameroom Barn Bucks: $2387
Default The ZR-1 Track Build
Throttle body coolant elimination
Plenum
Injector Housings
DEL-A-LUM Lower Control Arm Bushings
Coilover Test Fit
Prepping for Headers
Shrek is offline   Reply With Quote
Old 01-09-2012, 10:39am   #2
RedLS1GTO
C4 Mod
Points: 59,102, Level: 100
Activity: 42.8%
RedLS1GTO's Avatar
Be sure to take your time as you are building my next track car.
RedLS1GTO is offline   Reply With Quote
Old 01-09-2012, 1:03pm   #3
thegreenman
Points: 15,494, Level: 85
thegreenman's Avatar
Which track are you heading to?
Old 01-09-2012, 4:02pm   #4
nutz4c4
Points: 5,664, Level: 51
Activity: 0.8%
nutz4c4's Avatar
Gameroom Barn Bucks: $4969152
Very Nice...
nutz4c4 is offline   Reply With Quote
Old 01-09-2012, 5:55pm   #5
PLRX
Points: 14,069, Level: 81
Activity: 13.7%
PLRX's Avatar
Very very nice
Old 01-09-2012, 7:21pm   #6
Shrek
Shrek's Avatar
Mostly VIR the first year while Georgana learns to play nice with other cars on the track. Once she gets signed off and feels comfortable with the new set up, I'll haul her around to some other venues. She's got quite a few laps under her belt at Roebling, CMP, Rockingham, and Summit Point, but none at VIR, and none with Passing involved. Our track experience was with the NCCC, and it was running balls out timed qualifying laps, but spaced enough for no passing.
Old 01-09-2012, 8:03pm   #7
thegreenman
Nice, hopefully someday I can play on the track also.
Old 01-09-2012, 8:24pm   #8
popo8
Points: 7,476, Level: 60
popo8's Avatar
Gameroom Barn Bucks: $95530
Beautiful work......
popo8 is offline   Reply With Quote
Old 01-09-2012, 11:28pm   #9
mike100
Points: 10,589, Level: 71
mike100's Avatar
Gameroom Barn Bucks: $2013824
how did you clean up the rear hubs and driveshafts?
I got mine cleaned off, but not clean-clean the last time I had the wheels off and the half shafts out.
looking forward to the first report of how it feels with coil-overs.
Old 01-10-2012, 12:01am   #10
What were you doing to the injectors? Plugging the secondary ones?
FYI I'm an instructor with NASA and have hundreds of laps around VIR I'll be instructing at VIR at the February and March events.
Looking forward to watching more of the build!
Old 01-10-2012, 12:46pm   #11
Shrek
Shrek's Avatar
A little simple green about 8 years ago! The car has maybe 100 miles on wet roads since then.
NO, I'm removing the vacuum system that controls the secondaries, along with the secondary port throttle blades and shafts. The shafts were on bearings so when I removed them it left the open bore where air can be sucked in. Therefore I'm plugging the bores where the bearings were in the heads. The ecm chip has already been tuned for their removal and will run on all 16 injectors at throttle just above idle and up.
She already hit up a co-worker that instructs and I'm attempting to get most of these mods done for the Feb event.
Old 01-10-2012, 12:54pm   #12
Very cool. How much power will it make when ready? What kind of RPM will it turn?
Old 01-10-2012, 12:59pm   #13
Shrek
Shrek's Avatar
Stock is 375, so I'm hoping for a few more ponies from the headers and removal.
My big push is to make it handle better, because it's a pig at almost 3500 lbs.
Old 01-10-2012, 1:42pm   #14
Geeze I had no idea they were that heavy. If it's a track car start removing crap. I've got my car down to 2850 with the cage, fire suppression system and cool-shirt setup.
Old 01-10-2012, 9:30pm   #15
thegreenman
Sweet, we will have to talk when I am ready.
Old 01-11-2012, 9:03pm   #16
PLRX
Activity: 13.7%
PLRX's Avatar
Old 01-16-2012, 6:42am   #17
Shrek
Shrek's Avatar
Final install of rear suspension with modified hardware!
Old 01-16-2012, 6:44am   #18
Shrek
Shrek's Avatar
Changed out a leaky rear trans seal and installed a set of Beam Plates.
Almost forgot, we also swapped in a Hurst short throw!
Old 01-16-2012, 9:17am   #19
So when are you going to wrap the car in clear bra because it's way too pretty to track
Old 02-05-2012, 4:15pm   #20
Shrek
Shrek's Avatar
Default UPDATE
Didn't get much done last weekend, roadtrip to go pick up the new trailer.
Got it rolling and running yesterday!
