02-27-2020, 12:36am | #21 | ||||||
Gameroom Barn Bucks: $4614507
What do you do for a head Jeff?
02-27-2020, 6:48am | #22 | ||||||
Barn Stall Owner #2112
Gameroom Barn Bucks: $3043611
Yes
What Jeff Said. Limited room I guess. There is a changing room/loo that emerges from the aft couch. Move the cushion, raise the tent, and there it is. |
02-27-2020, 7:32am | #23 | ||||||
Gameroom Barn Bucks: $856744
02-27-2020, 7:42am | #24 | |||||||
Gameroom Barn Bucks: $216475
I've been around boats my entire life, but not one like this, that's a huge turning radius. |
02-27-2020, 8:25am | #25 | ||||||
Banned
02-27-2020, 8:27am | #26 | ||||||
Banned
The Following User Says Thank You to Mr.Bigg For This Useful Post: |
02-27-2020, 9:13am | #27 | |||||||
Gameroom Barn Bucks: $111433
We HAD to use it when docking our 37' Beneteau. |
The Following User Says Thank You to erickpl For This Useful Post: |
02-27-2020, 7:59pm | #28 | ||||||
Looking at the prop, ( your last pic ) it looks to be stainless steel. Stainless props are about three times more expensive than aluminum.
The advantage of stainless over aluminum is they wear less in abrasive conditions. ( like running close to bottom ). Aluminum props are preferred in areas where prop strikes are likely as the softer aluminum will bend the blades instead of destroying the shafts and gears in the lower unit. Both types of props can be repaired ( correctly formed and balanced) by the Marina or a subcontractor. Your choice on what material you want to purchase for the spare. Make you you purchase the correct pitch. ( pitch is the amount of forward motion in one full turn with NO slip ) Jeff |
02-27-2020, 8:32pm | #29 | ||||||
Depending on the manufacturer's design those pontoons range in shape from simple cylinders, to cylinders with "angle iron" appended for some "bite" on the surface to pointy, canoelike profiles. All of these shapes tend to simply glide atop the surface much like a flat stone skipped across a puddle making directional control sluggish at best at slow speed. As stated as well, wind complicates things considerably if it happens to be blowing in any direction other than that you desire; adding to the fun and art of steering what is essentially 2 LP gas cylinders lashed together with an engine stuck between.
02-27-2020, 8:39pm | #30 | ||||||
Pontoon boats are bad enough with the standard profile in the wind.
Here's my '24 with the full enclosure which acts like a big sail |
02-27-2020, 8:41pm | #31 | |||||||
Gameroom Barn Bucks: $2214590
Lots of pontoon boats here on our lake. Good boat for shallow water. Very stable and smooth ride. |
02-27-2020, 9:52pm | #32 | |||||||
Barn Stall Owner #13
Gameroom Barn Bucks: $425244
02-27-2020, 9:57pm | #33 | ||||||
Someday I'd like to be baller enough to own a pontoon boat.
02-28-2020, 7:32am | #34 | |||||||
Are props all the same size? Is a plastic one ok for just emergency use or can one be used all the time ? It seems that being able to just change out a fin or two as needed is a good idea. Is that even a real thing ? |
02-28-2020, 9:05am | #35 | ||||||
Barn Stall Owner #17
Fun boats to relax or do the party thing on.
As mentioned, be aware of the wind and current; they make tight maneuvers a bitch. I wouldn't try any practice on windy or crowded days. Scott
The Following 2 Users Say Thank You to simpleman68 For This Useful Post: |
02-28-2020, 10:06am | #36 | ||||||
Gameroom Barn Bucks: $18284
first stop, yammie dealer for something a little less underpowered. that 90 wont get you going fast enough with a load of wimenz and beer, but it looks clean. Good luck!
don't listen to that first day/last day bullshit. Modern boating is fun. modern motors aren't the pain in the ass they once were. |
The Following User Says Thank You to Egnalf For This Useful Post: |
02-28-2020, 2:53pm | #37 | ||||||
Gameroom Barn Bucks: $11051621
Nice! I loves me a party barge! The only thing better than owning a boat, is having a buddy that owns a boat. My friend lives on the lake near us and we always take the pontoon out when visitors come. Enjoy!
The Following User Says Thank You to 8Up For This Useful Post: |
02-28-2020, 3:06pm | #38 | |||||||
On a serious note, that "little" 90 will scoot a 20' can boat better than you might think. Unless you're planning to get skiers up on plane quickly. Scott
02-28-2020, 4:21pm | #39 | ||||||
The Following 4 Users Say Thank You to Jeff '79 For This Useful Post: |
02-28-2020, 6:20pm | #40 | ||||||
Yes, it's a real thing. My SIL's boat came with a plastic prop and it's the only kind it's ever had.
