Old 06-17-2022, 7:38pm   #21
MikeB
Barn Stall Owner #115
Points: 22,485, Level: 100
Activity: 9.0%
MikeB's Avatar
Gameroom Barn Bucks: $610854
Originally Posted by Sea Six View Post
Nice find!
I’ll bet you a dozen donuts the dead thing is a mouse or a rat inside the heater core.
Heater core removed when engine upgades were done.
Had the seats out today. Foam looks good, but smell is emminating from seats. ???
I'm thinking now I have a crate engine upgrade. Perhaps Edlebrock.
Heads and block are clean, no gunk whatsoever. Painted black, and stampings are clear as day.
It's not an L48. Bolts in exhaust manifold are still shiny.
Block stamping on right front of block is 1110326 with 9H04 underneath the top set of numbers.
More pix of block tomorrow.
MikeB is offline   Reply With Quote
The Following User Says Thank You to MikeB For This Useful Post:
Old 06-17-2022, 7:43pm   #22
MikeB
Activity: 9.0%
MikeB's Avatar
Originally Posted by aerovette View Post
FM not working may be as simple as the antenna being disconnected.
First thing I checked.
Slide bar to FM, green light comes on. FM signal received, but no sound.
Ordered a Classic sound exact fit today to replace it. Some assembly required.
Old 06-17-2022, 7:44pm   #23
Rikki Z-06
Barn Stall Owner #747-400
Points: 78,321, Level: 100
Activity: 19.8%
Rikki Z-06's Avatar
Very cool Mike.
Rikki Z-06 is offline   Reply With Quote
The Following User Says Thank You to Rikki Z-06 For This Useful Post:
Old 06-17-2022, 8:01pm   #24
Chuck A
Points: 40,099, Level: 100
Activity: 2.2%
Chuck A's Avatar
Gameroom Barn Bucks: $2601174
Very nice indeed
The Following 2 Users Say Thank You to Chuck A For This Useful Post:
Old 06-18-2022, 6:37am   #25
Torqaholic
Points: 30,897, Level: 100
Activity: 21.2%
Torqaholic's Avatar
If it's not the carpet causing the smell could be something crawled up inside a seat?
Had a mouse nest inside the blower motor of my Z06 that needed to be cleaned out once. Fan was making all kinds of racket
Torqaholic is offline   Reply With Quote
The Following User Says Thank You to Torqaholic For This Useful Post:
Old 06-18-2022, 6:42am   #26
Norm
Barn Stall Owner #1776
Bantayan Kids '13,'17
Points: 88,143, Level: 100
Activity: 29.2%
Norm's Avatar
Fun project, it's going to look good, don't look too bad now.
JCS USA USN USMC USCG USAF USSF USAR USNR USMCR USCGR USAFR ARNG ANG USPHS NOAA USMM AUS CSA Police/Fire/EMS/EMT
Thank You For Your Service
The Following User Says Thank You to Norm For This Useful Post:
Old 06-18-2022, 7:33am   #27
MikeB
Activity: 9.0%
MikeB's Avatar
Thanks Norm.
It's a 20 footer right now.
Old 06-18-2022, 10:33am   #28
MikeB
Activity: 9.0%
MikeB's Avatar
Default Update, Block stampings
Got a pic of the RF side and LR side.
All I can confirm is that it's a 350 block.
There was a paper tag/bar code on the right side of the oil pan.
I took a rag to wipe the built up oil & grease off the tag so I could read it better,
and the ink came off with the grease. Damn!
RF block 1M0326-9H04
LR block 10066036
Any ideas as to what I got here?
Block, timing chain cover and heads are painted satin black.
The Following 2 Users Say Thank You to MikeB For This Useful Post:
Old 06-18-2022, 10:46am   #29
ToolMaker
Barn Stall Owner #97
Points: 12,395, Level: 76
Activity: 1.4%
ToolMaker's Avatar
Went over to search in the other place, and your other thread is the only one that popped up!
ToolMaker is offline   Reply With Quote
The Following User Says Thank You to ToolMaker For This Useful Post:
Old 06-18-2022, 2:19pm   #30
MikeB
Activity: 9.0%
MikeB's Avatar
Yeah, no help yet over there.....
Old 06-18-2022, 7:51pm   #31
Grey Ghost
Points: 47,736, Level: 100
Grey Ghost's Avatar
You have a GM Target Master/Goodwrench crate motor engine code.
10066036 is the casting number and that indicates a 1986 or newer.
0326 = March, 26th ?
Don't know about that suffix code.
The Following User Says Thank You to Grey Ghost For This Useful Post:
Old 06-18-2022, 8:00pm   #32
09CTSV
Points: 22,442, Level: 100
09CTSV's Avatar
Gameroom Barn Bucks: $2106426
Digging thru the web, http://www.castingnumbers.info/site/detail/120/10066036
it looks like the one casting number 10066036 identifies it as a GM Goodwrench 4 bolt, crate engine with a 2 piece rear main seal.
09CTSV is offline   Reply With Quote
The Following User Says Thank You to 09CTSV For This Useful Post:
Old 06-19-2022, 10:19am   #33
MikeB
Activity: 9.0%
MikeB's Avatar
Friday and Saturday was carpet trimming and install of the storage deck lid.
PO just shoved the carpeting in and laid the storage cover over the top.
I shampooed, then trimmed the carpet, spray glued the back portion by the light,
then used 3 body style push pins to retain to the black plate.
Installed the storage cover with sheet metal screws.
sunlight doesn't help it, but all 3 pieces of carpeting are the same color.
Now, on to the seat. This is the passenger seat.
The tag on the bottom is "LSIM 44984 2375, with 368377 above it."
Ordered correct color seat covers, and will redo these cushionssometime when it cools off.
Old 06-22-2022, 12:56pm   #34
MikeB
Activity: 9.0%
MikeB's Avatar
Got some work done today on the rear bumper cover.
Before pic.
After pic.
Had to drill 3 holes in the cover, and remove a cover brace attached
to the top inside on top of the bumper to attach the speed nutz. 3 bolts holding the brace, 2 hard to get at,
and I busted the head off of one.
Old 06-22-2022, 1:01pm   #35
Learpilot
Points: 19,067, Level: 95
Learpilot's Avatar
Gameroom Barn Bucks: $685
looks like fun
Learpilot is offline   Reply With Quote
Old 06-26-2022, 9:44am   #36
MikeB
Activity: 9.0%
MikeB's Avatar
Default Interior work staarted
Got the console pieces dyed today.
Will work on Retro Radio install after I finish the seat re-covers.
Old 06-27-2022, 7:51am   #37
MikeB
Activity: 9.0%
MikeB's Avatar
Got the seats recovered Saturday & yesterday.
Ready for install, but working on radio and console install first.
Before:
After:
I got some wrinkles in the side bolsters that I hope leaving out in the sun will shrink them.
I couldn't stretch the sides anymore.
The Following 3 Users Say Thank You to MikeB For This Useful Post:
Old 06-28-2022, 2:06pm   #38
MikeB
Activity: 9.0%
MikeB's Avatar
Default Sound bar Install...
Put the radio in Sunday, and today I installed the rear sound bar.
before installing
Installed
I had one of these in my previous '76, and liked it, so I got a similar set-up for this one too.
Sounds good, but needs an amp. Sometime in the future.
Old 07-01-2022, 12:44pm   #39
MikeB
Activity: 9.0%
MikeB's Avatar
Default Finishing the interior...
Been busy over the past week plus, working on the interior
Before pic:
Many black parts needing dye and/or replacement.
Progress after I took the interior out, dyed the console, rebuilt the E-Brake housing internals (nothing inside) and redid the seats:
i only have minor work left in the interior I'll get to as soon as I find the parts
I'm missing (heater core, fan, spacer between radio and dash) but it's mostly done for now.
Mechanical work next (E-brake, leak in rear master cylinder, gas line, fan shroud), and maybe look into paint later this summer.
For now, it's ready to drive a bit.
Old 07-01-2022, 12:55pm   #40
snide
NCM Supporter '13
Points: 216,817, Level: 100
Activity: 53.6%
Looks great, Mike. Don't forget to swap out that Vega wheel.
The Following 3 Users Say Thank You to snide For This Useful Post:
