Old 12-03-2019, 12:28pm   #1
Wathen1955
Points: 47,176, Level: 100
Activity: 11.2%
Wathen1955's Avatar
Gameroom Barn Bucks: $1524159
Default What happens when you put wet scrap metal in a furnace?
Maybe this guy needs to buy a lotto ticket or a change of shorts - maybe both.
Wathen1955 is offline   Reply With Quote
Old 12-03-2019, 12:57pm   #2
snide
NCM Supporter '13
Points: 216,817, Level: 100
Activity: 53.6%
Damn! That escalated quickly!
Old 12-03-2019, 1:22pm   #3
Points: 159,014, Level: 100
Activity: 23.0%
Yikes !
Old 12-03-2019, 1:25pm   #4
8Up
Points: 20,643, Level: 99
8Up's Avatar
Gameroom Barn Bucks: $11051621
Well, at least hes warm.
8Up is offline   Reply With Quote
Old 12-03-2019, 1:38pm   #5
MrPeabody
Points: 69,948, Level: 100
MrPeabody's Avatar
Gameroom Barn Bucks: $2214590
I think when you add water to a fire that hot, you get an oxygen fire, because there's oxygen in water. I worked at a print shop once where we had a small table saw that we used to trim embossing dies made out of magnesium. Over time, the five gallon bucket that caught the shavings from the mag had filled up. A spark ignited it and we quickly had a white hot fire.
One of the idiots I worked with came running around the corner with a bucket of water to throw on it. I practically tackled him to keep him from throwing it on the fire, because I think it would have had results similar to what happened in the video.
We lifted the burning bucket by getting a mop handle under the wire handle and took it out to the parking lot and let it burn itself out. It made a hole in the asphalt.
MrPeabody is offline   Reply With Quote
The Following 3 Users Say Thank You to MrPeabody For This Useful Post:
Old 12-03-2019, 2:14pm   #6
Aerovette
Barn Stall Owner #7734
Points: 106,278, Level: 100
Aerovette's Avatar
Magnesium burns damn hot and is difficult to extinguish.
The Following 2 Users Say Thank You to Aerovette For This Useful Post:
Old 12-03-2019, 2:37pm   #7
Cybercowboy
2016 Election Expert
Barn Stall Owner #64
Points: 50,697, Level: 100
Activity: 34.6%
Cybercowboy's Avatar
Solid rocket motors have fuel made from butyl rubber, aluminum, and magnesium ground up to the consistency of course gravel. And it burns good.
Cybercowboy is offline   Reply With Quote
Old 12-03-2019, 5:45pm   #8
Lakota
Points: 26,298, Level: 100
Lakota's Avatar
Gameroom Barn Bucks: $2924
Magnesium is an alkali metal and the only way to extinguish is with a "special Class D fire extinguisher" or dry sand. The Class D extinguisher or sand will act as a smothering agent on the metal fire.
Most fire extinguishers are Class A-B-C.
Lakota is offline   Reply With Quote
Old 12-03-2019, 8:56pm   #9
JRD77VET
NCM Supporter '16,'17,'19,'20
Points: 116,158, Level: 100
Activity: 9.4%
JRD77VET's Avatar
That dude was extremely lucky
It burns under water too. They showed that in science class in 7th grade.
At my previous employer, I made the compressing "jack" that filled the solid rocket boosters with a wet slurry. The base plate was a piece of 8" thick steel plate that was 48" by 60" . That's over 6500 lbs just for that plate.
Once the booster were filled with the wet slurry, they were moved to building a few miles away from anything to dry.
Once they are lit/burning, the only way they go out is when they burn up all the fuel.
Originally Posted by Lakota View Post
Magnesium is a heavy metal and the only way to extinguish is with a "special Class D fire extinguisher" or dry sand. The Class D extinguisher or sand will act as a smothering agent on the metal fire.
We had a job where we had to weld magnesium. We were REQUIRED to have someone in the welding area with a Class D fire extinguisher ready to put out a fire when the welder was welding.
Old 12-04-2019, 8:17am   #10
6spdC6
Points: 21,381, Level: 100
Activity: 34.2%
6spdC6's Avatar
Gameroom Barn Bucks: $2115673
One of the large industrial plants I worked in had stuff that water made much worse and the only thing you could do was smother it with a dry sand. The building was off to one side and there were all sorts of containers around with a shovel and sand handy. There was also a large garage type building just loaded with that sand nearby.
6spdC6 is offline   Reply With Quote
Old 12-04-2019, 7:18pm   #11
78SA
Points: 55,719, Level: 100
78SA's Avatar
Gameroom Barn Bucks: $3632152
Good thing it wasn't raining.
78SA is offline   Reply With Quote
Old 12-04-2019, 8:33pm   #12
99 pewtercoupe
Barn Stall Owner #74
Bantayan Kids '13,'17
Points: 95,036, Level: 100
Activity: 6.5%
99 pewtercoupe's Avatar
I worked in an office at one of the largest green sand foundries in NA. One day we heard a huge blast that shook the building. Later found out that as they were loading scrap metal into the furnace, evidently there was a crushed 55 gallon barrel that had a couple of gallons of water in it. Got everyone’s attention
99 pewtercoupe is online now   Reply With Quote
Old 12-05-2019, 8:37pm   #13
boracayjohnny
Points: 48,709, Level: 100
Activity: 28.6%
boracayjohnny's Avatar
Gameroom Barn Bucks: $1317070
Heh, dude backed up pretty quick. Imagine if he had used that half an atom of a brain before combining wet and molten metal.
Story time...
So there we were unloading a segment of an ICBM from a C-141 to a tractor trailer. The segment was at the pivot point of the aircraft and the trailer. All of a sudden, the sound of metal on metal screeching was heard. I began running and so did everyone else. In hindsight, I coulda saved my breath. If there had been a bang, I wouldn't have known it. Evidently, the aircraft crew member miscalculated the remaining fuel on board. When the segment reached the pivot point, the aircraft nose raised and thus the screeching.
boracayjohnny is offline   Reply With Quote
Old 12-05-2019, 9:36pm   #14
SnikPlosskin
Barn Stall Owner #93
Points: 63,649, Level: 100
Activity: 2.5%
SnikPlosskin's Avatar
I’m pretty sure he is doing it wrong. But I’m no metaloligicalistic man.
