02-08-2011, 11:11pm | #1 | ||||||
SPC Upper Control Arms (UCA) Installation
First, I'd like to thank Brian Cinnungham for his help on this project.
About a year ago I bought the SPC's Upper Control Arms. Few days ago I finally decided to remove them from the living room and get them installed. Lift Vette, place jackstands, remove tires, remove dust shield and remove upper ball joint Cleaned the ball joint Remove the UPC Test the new BJ bolts. Match to fit the new UPC with the old one. Using 1/8" shims, match the size of shims and spacers. I used krazy glue to keep shims together. Test to fit, Check- Installed shims, Torque UPC bolts to 40 lbs-ft. Torque BJ bolts to 13 lbs-ft Torque the three pivot bolts to 60 lbs-ftf. Grease up the UPC. Torque the upper BJ between 50~88 lbs-ft or until the cotter pin hole aligns. Drove around the neighborhood for about a mile to get things down. Quick but, not official alignment. Good enough at "-0.50" Camber to make it to the alignment shop. Very easy to make adjustments |
02-11-2011, 10:25am | #2 | ||||||
C4 Mod
Man... you have more suspension goodies on your street car than I have on the track car.
02-11-2011, 3:55pm | #3 | ||||||
Gameroom Barn Bucks: $946
Are there any benefits for using these A-arms compared to stock?
02-11-2011, 4:01pm | #4 | ||||||
PLRX, I sent you a PM with a few questions, I was hoping you could answer in regards to those control arms.
If/when you get the chance, any info you could share with me would be appreciated. |
02-11-2011, 4:28pm | #5 | |||||||
Dog: The benefit is that with a crescent wrench I get out of the car and do my own pre-set alignment sets. The one that I will have for street at -0.50 at 0 toe will be there all the time. If I'm doing a drive, I step out and give it a turn to the rear arms, that will move it to maybe -0.75~-1.0 camber and a negative toe. That will increase handling, once I'm done I would put it back to normal. The regular arm you need shims and space. Kid: Did you send the PM to a different forum? |
02-11-2011, 8:46pm | #6 | ||||||
Nope, sent it to you here at the Barn and still have the original message in my "sent" folder but no big deal, I'll just ask it here...
I actually ordered those same control arms for my '92 a few days ago. That's when I accidentally stumbled onto this forum after doing a search on google looking for anyone else who's put these arms on their C4's and could tell me what they though of them. I ordered the "race" version of these arms like you did, which I know will effect the ride quality much more so than the "standard version" with it's OE-style busings but I was curious as to just how much harsher the ride is on your car now with the race-style SPC's? Also, I see that you re-installed the factory spacers back. I was under the impression that because the arms themselves were adjustable, you would no longer have to use shims. Did you re-use them simply for "more" adjustably, or do you still have to use them regardless of the control arm settings? Finally, last question, I promise, but did you by any chance weigh the SPC arms? How much heavier/lighter are they compared to the stock arms? I'd imagine they're heavier, but I was curious to find out. My arms won't come in for another 2 weeks (more or less) so I'm anxious to find out as much about them as I can while I wait... Last edited by Corvette Kid; 02-11-2011 at 9:03pm. |
02-11-2011, 9:38pm | #7 | |||||||
My coilovers do compress my spine and I can prove it to anyone. |
02-13-2011, 11:38pm | #8 | ||||||
One last question. I noticed that SPC recommends Moog part no. K5208 for the ball joints with their control arms.
After doing a quick search on Moog's website,I discovered they do NOT list part no. K5208 ball joint as being compatible with the '84-'96 Corvette... Do these SPC arms require a different than stock, ball joint? I'd like to know 'cause I placed an order the other day for a pair of replacement ball joint for a '92 Corvette (which is Moog part no. K6346) If stock replacement ball joints wont work on these arms, I need to cancel that order and get different ball joints then.... What ball joints are you using? Thanks again... |
02-14-2011, 12:37am | #9 | |||||||
08-20-2012, 7:25pm | #10 | ||||||
I need some of those thick spacers.... if anyone wants to sell them.
thanks !! |
08-20-2012, 10:31pm | #11 | ||||||
08-21-2012, 5:23am | #12 | ||||||
They sell the aluminum spacer in NAPA, or just regular alignment shims ?????????
08-22-2012, 1:20pm | #13 | ||||||
08-22-2012, 2:00pm | #14 | ||||||
once again, I am looking for the OEM aluminum spacer, that was used in the front position of the control arm. Not the shims, but the thick spacer.
