Old 02-05-2013, 8:57pm   #81
Montehall
Points: 33,181, Level: 100
Montehall's Avatar
Gameroom Barn Bucks: $89945
I have an electric fuel pump.
my motor was TBI - Crossfire.
I think it depends on the year, IIRC, the head design changed in 86.
Montehall is offline   Reply With Quote
Old 02-05-2013, 8:59pm   #82
JRD77VET
NCM Supporter '16,'17,'19,'20
Points: 116,380, Level: 100
Activity: 8.3%
JRD77VET's Avatar
Shorty headers are inexpensive if you get a good deal on newer engine.
Old 02-05-2013, 9:46pm   #83
Fastguy
Barn Stall Owner #92
Bantayan Kids '13,'15
Points: 24,533, Level: 100
Activity: 0.8%
Fastguy's Avatar
Gameroom Barn Bucks: $7534993
The exhaust pattern didn't change, its the angle of the intake manifold and bolt pattern.
Fastguy is offline   Reply With Quote
Old 02-05-2013, 9:49pm   #84
Montehall
Montehall's Avatar
exhaust went from the square to the D pattern in some year
but the intake is the same for SBC through 86.. at least that's what that intake I bought and returned was supposed to fit.
but yeah, there's the head I have, and there camel hump heads, centerbolt heads vortec heads, bowtie heads, etc...
Old 02-05-2013, 9:55pm   #85
Midnight85
Points: 2,672, Level: 33
Midnight85's Avatar
Gameroom Barn Bucks: $100015
something like this?
350 sbc
everything else I've found is on the ground already.
That is exactly what I mean and I would bet if you show up with cash in hand he would bargain with you. As far as intake fitment there are only three intake bolt patterns for the small block. First is the original, second is identical to the original with the exception of the bolt hole angles in the center two holes and all you need to do to make it fit is elongate the center holes so the bolt will go in then use a flat washer to cover the enlarged hole. The third design however is all by itself and does take a special intake, (Vortec) this manifold only has 8 bolt holes and they are straight up with no angle at all. His asking price is not bad but if he can be talked down you would be in great shape.
Midnight85 is offline   Reply With Quote
Old 02-05-2013, 9:56pm   #86
Montehall
Montehall's Avatar
and except for the two hour drive...
Old 02-05-2013, 11:18pm   #87
RED-85-Z51
The Hooptie Whisperer
Points: 58,040, Level: 100
Activity: 5.8%
RED-85-Z51's Avatar
Gameroom Barn Bucks: $1975165
Gen 1 SBC, as far as I know, used iron heads up to mid 86 on the vette, then went to aluminum, but the intake didnt change until 02 with the LT1 (gen2 SBC).
In 87 the Trucks got TBI, and used TBI up until 96 when the Vortec 5700 came out, the vortec heads had different ports, intake mount bolts, etc..
Id think, a truck TBI 350 from 87-95 would work for you....
That said, I dont know of any TBI 4 bolt engines...
RED-85-Z51 is offline   Reply With Quote
Old 02-05-2013, 11:51pm   #88
Fastguy
Activity: 0.8%
Fastguy's Avatar
Read midnight 85's post, it covers the intake differences.
Old 02-06-2013, 12:04am   #89
RED-85-Z51
Activity: 5.8%
RED-85-Z51's Avatar
The engine is my truck is a crate reman 350, I think the guy paid like 1500 for it installed, new heads, new crank, new rods, new seals, bearings, cam, water pump...oil pump, distributor, all sensors, thermostat...and it runs great.
3.42 gears on 33" tires and it still pulls an 18 foot trailer no problem, has like 25K on it now, no leaks, or problems.
i wish it had more cam, but the previous owner opted for a stock TBI cam...
Not a bad price for reliabilty...he got it through Oreilley autoparts.
Old 02-06-2013, 12:21am   #90
island14
Bamboo Boy
Bantayan Kids '13,'14,15
Points: 67,589, Level: 100
Activity: 99.6%
island14's Avatar
That is what I was thinking BUT, keep in mind, a TBI motor uses a different cylinder head and your intake wont fit. You would need another intake. Also, I am not a SBC specialist, but that is an injected motor and I don't know if the cam has provisions for the fuel pump.
Good thinking ahead..
I doubt I would have even thought about that myself.
The block may not have even been machined for the pump completely.
It still may be OK, but would be well worth checking into before spending for parts in the wrong directions.
island14 is offline   Reply With Quote
Old 02-06-2013, 12:26am   #91
island14
Bamboo Boy
Activity: 99.6%
island14's Avatar
Just me... but I would still just clean it out well, and drop some used, or new lifters in it and try it first before spending lots of money and time fitting a new engine in there.
Old 02-06-2013, 7:54am   #92
Montehall
Montehall's Avatar
I have an in-tank electric fuel pump. that's not really an issue for me.
Old 02-06-2013, 8:44am   #93
Midnight85
Midnight85's Avatar
You are running a carb right? What are you using to get the high pressure injection fuel pump down to the 4-7 lbs of pressure that is all a carb can handle?
Old 02-06-2013, 8:49am   #94
Montehall
Montehall's Avatar
a fuel pressure regulator.
Holley adjustable with return. I have it dialed to 5.5 psi
Old 02-06-2013, 8:54am   #95
Midnight85
Midnight85's Avatar
Well I guess I worded that question in a way to show my stupidity. I asked because I have known people who tried to use the in tank pump on a carb with out a regulator. I never was much good early in the morning. What have you decided to do?
Old 02-06-2013, 8:59am   #96
Montehall
Montehall's Avatar
I'm going pull the oil pan... although it's supposed to be thunderstorming today, so I doubt it'll be today.
oddly enough, when I first got the car, the DSPO didn't have a regulator on it. he just crimped one of the hard fuel lines... I fixed all the stupid issues like when I replaced the head gaskets.
Old 02-06-2013, 9:07am   #97
Midnight85
Midnight85's Avatar
How many miles did you put on it before regulating the pressure the right way? The reason I ask is he could have been lucky enough not to have the carb leak externally but still leak down into the engine where it would have gotten past the rigs and washed the oil off everything which could bring you to where you are now. That would certainly explain the debris you found when you pulled the intake the excess gas would have been washing down the cylinders causing excess wear. This all just a guess but it is possible.
Old 02-06-2013, 9:09am   #98
Montehall
Montehall's Avatar
I probably put about 100 miles on it before I installed the regulator.
but that was probably 16 months ago.
Old 02-06-2013, 9:15am   #99
Midnight85
Midnight85's Avatar
Well, we can speculate all we want to but it won't tell us a thing so I guess it's definitely time to break out the wrenches. When you get the pan off, if there isn't anything readily visible post some pics of the inside of the pan and of the bottom end of the engine. With all the sludge you found up top the bigger shrapnel, if there is any, may be stuck in goo in the pan.
Old 02-06-2013, 5:45pm   #100
Jeff '79
Barn Stall Owner #2112
Fantasy Football Champ '14,'16,'20
Points: 162,095, Level: 100
Jeff '79's Avatar
Gameroom Barn Bucks: $3043611
Jeff '79 is offline   Reply With Quote
