10-04-2022, 4:54am | #1 | ||||||
Gameroom Barn Bucks: $1232517
Just bought a generator
During the storm in Florida, we moved to our rv garage about a 1/4 mile from my home. I had emergency power in the rv (generator) but not the rest of the garage which includes a storage area, a screened patio and garage for my two collector cars.
I could also use a generator at my home if needed. Amazon had a duromax on sale and I bought it. It is a duel fuel generator, gas and butane. I thought the butane was great as I could keep butane in it all the time. https://www.amazon.com/DuroMax-XP120...385652d5&psc=1 I then found that it would not run near as long on butane and I would need a large take for continual use. Anyone use a dual fuel generator? What do you use. |
10-04-2022, 5:34am | #2 | ||||||
Looks nice. I wish there was some way to run that on natural gas, too.
10-04-2022, 5:44am | #3 | ||||||
Daughter brought her propane/pump gas generator over for the hurricane, we never used it. I've never had one and lived through blizzards up north and 7 hurricanes in various states. If I lose power for any length of time I'm headed away in my previously filled up vehicles, screw the food in the freezer....
My niece is on a generator in Ft. Myers right now and has spent a lot of time in gas lines to get fuel for it and sometimes can't. I think they are way over-hyped as far as total benefit. |
10-04-2022, 5:53am | #4 | |||||||
10-04-2022, 7:52am | #5 | ||||||
Gameroom Barn Bucks: $4635916
We have a little one. I run it on propane. It's just enough to keep fridges and lights going when needed. If the power goes out we go into "camping" mode, propane stove, battery lights etc. It's enough for us to be comfortable
https://www.amazon.com/Champion-Powe...%2C220&sr=8-29 |
The Following User Says Thank You to MEANZ06 For This Useful Post: |
10-04-2022, 7:52am | #6 | ||||||
Most can be converted to run 3 fuel, ng, propane and gas.
Butane, propane, ng then gas as far as energy output for gen. (might be ng, propane) |
10-04-2022, 8:17am | #7 | |||||||||
For portable generators... that is the desired config these days. A gas grill 20lb bottle can run a LP generator for anywhere from 6 hours to days... Quote:
With Propane, you store the gas in your own tank; no-one other-than-you has control of it. Quote:
The Following 4 Users Say Thank You to Mike Mercury For This Useful Post: |
10-04-2022, 8:44am | #8 | ||||||
What ever you buy run it a bit then change the oil. They are not built very well anymore a lot of metal filings.
The Following 4 Users Say Thank You to Big bob For This Useful Post: |
10-04-2022, 10:26am | #9 | |||||||
@Olustee bus I have a 10000 W Duromax dual fuel and converting to NG. Ya need a new regulator and hose to the carb rendering the propane hoses/ reg inoperable. Cost is $129 from nashfuel.com. Here are the instructions http://www.nashfuel.com/instructions...STRUCTIONS.pdf When this project is complete it will be solar charged for the battery as there is no way to charge the battery in the Duromax unless YOU splice into the DC +12vdc charge stubs https://duromax-xp10000e.tumblr.com/...arging-problem The enclosure I am building w exhaust fan, grille etc looks like this I went with this exhaust kit https://genexhaust.com/generator-exh...nsion-systems/ It’s manual meaning power goes out, flip main breaker (200a) off, slide lock out bar, flip 50A gen breaker, connect cord in garage, start gen. Whole house will run of NG but pool won’t be running Total cost ~$4000 with NG pipe etc and power trenched to 2nd garage where enclosure sits behind compared to Generac quote of $24000 for auto start You do loose some wattage at peak using NG but hell of a lot better than switching tanks or filling tanks…. What else ya need to know. |
The Following 2 Users Say Thank You to MadInNc For This Useful Post: |
10-04-2022, 10:50am | #10 | ||||||
Barn Stall Owner #116
Doesn't have a big thing
10-04-2022, 11:55am | #11 | |||||||
Run time will be more or less dependent on BTU/ pound. For common fuels: Diesel 19,400 Gasoline 19,500 Natural gas 19,500-21,500 Propane 21,500 Butane 21,640 |
10-04-2022, 1:16pm | #12 | |||||||
NG is ~40% cost of propane. Key factor is volume not just BTU. NG is lower pressure compared to Propane @ regulator. As such for stoves/ grille NG has bigger jets. Vase in point if a grill is fed w NG and has a propane reg, the grille might get to 250f |
10-04-2022, 1:42pm | #13 | |||||||
I heat the house/ hot water with oil because it is cheaper than propane. |
10-05-2022, 3:47am | #14 | ||||||
I meant propane. I got my "anes" mixed up.
10-05-2022, 3:55am | #15 | ||||||
I wish propane was available in my little crossroads. Know one here has water unless they have a well.
Thanks MadinNC, for the great tips. I have saved all of this info. |
10-05-2022, 6:54am | #16 | ||||||
I'm switching a gen to gas as propane tank, delivery costs, regulators are so expensive here. Propane has gone up 2 to 300 % and throw on delivery fee since not a regular customer. Local companies balk at filling tanks not their own sometimes also even though I buy the tank(s).
In a hurricane emergency I'll stock up on gas is all. I'll get a small tank and put on my trailer. The only issue will be rotating the gas regularly. New tank will have a drain setup to drain into 5 gallon can and get burned in mower. Wish to hell NG was available here. |
10-05-2022, 8:12am | #17 | ||||||
The Following 2 Users Say Thank You to Mike Mercury For This Useful Post: |
10-05-2022, 10:46am | #18 | ||||||
10-05-2022, 5:56pm | #19 | ||||||
My brother gave me his old Troy Built 5550 Watt (8550 starting watt) gas gen for free. He bought a new one because 1st - he lives in hurricane country and B - the pull starter spring broke and he's not a mechanic.
I removed the rivets that held the pull starter and bolted a new one on. It hadn't run for years so I took the carb apart and cleaned it. Works like a champ. Now I dare the power to go out LoL. I've used it once after a microburst knocked out power for almost a day which is the longest we've ever been without power since living where we do for over 20 years. It ran like a champ and can run on gas non-stop for 18 to 20 hours. My neighbor and I were the only ones who had gens. I felt like I had to stay up and guard it as who knows who would go crazy in these situations. I kept our fridge on. Turned on the internet for entertainment and ran a few lights for everyone. I should look into converting it to multi-fuel. Seems like a good idea. I'm sort of a mini-prepper. I have 25 year shelf life 30 day food supply for 4 people stashed in the basement. I keep at least 3 tanks of propane for the grill etc. if needed during emergencies. Flashlights (even one that doesn't need batteries) plasma lighters and water proof matches in a water proof box along with a bunch of other "prepper" stuff. You can never be too prepared. |
The Following 4 Users Say Thank You to theandies For This Useful Post: |
10-05-2022, 7:07pm | #20 | ||||||
I've been through many different generators, as many racetracks don't have shore power. For portable use, the Honda EU's are hard to beat. Expensive, but quiet. Mine ran on gas. I had an Onan diesel that was pretty slick, and I could feed it off of my fuel tank.
At home, I started with a 5kW and a dead man's cord plugged into a 50A outlet I ran through a circuit breaker on the main panel. I eventually graduated to a transfer switch on the outside of the house. I bought an 8kW Ridgid back in 2012. That thing is an absolute beast. Still have it as a backup to the backup. My main backup is a 22kW Generac. I can run the whole place on it. The transfer switch has load shedding to account for high surge items operating at the same time. The whole setup, installed at the time the home was built in 2015, was about $12k. Runs on NG. While I still have dependence on the grid for gas, the only time service would be cut off is for a large fire, when I'd likely evacuate anyway. I can still hotwire the 10kW in if needed. While it seems expensive to have all the capability, it's basically a necessity when on a well and I will depend on sprinklers outside as part of the fire defense. |
The Following 3 Users Say Thank You to ZipZap For This Useful Post: |
